It is currently Thu Aug 27, 2026 8:12 am
ecosse
PostPosted: Sun May 06, 2012 6:31 pm
Ok, now I've done it. Today I tried to remove the factory radio to install an ipod adaptor in the back after watching a youtube tutorial with no luck. Worse still, now my cel light is on. Basically, I removed the side plastic trim lining along the sides and I put a thin pointed prod in the holes covered by the trim, to wriggle it free. Don't know what I did, but now the radio doesn't work (absolutely no power is going to it) and the cel light is on. I also noticed my trip mileage in the odometer reset to 0, but the car runs fine. So now, what the f*** did I do? Any advice will be appreciated and if you want to scold me for this, I don't blame you.
Rob H
PostPosted: Sun May 06, 2012 7:40 pm
Did this to mine last week try 10amp fuse in footwell fuse box, called room fuse its the raised one.
Rob H
PostPosted: Sun May 06, 2012 7:42 pm
viewtopic.php?f=39&t=50535
ecosse
PostPosted: Sun May 06, 2012 9:03 pm
Checked the fuses, sure enough, it was blown. Now for the next question how do you remove that damn radio, and how the hell did I blow a fuse trying to remove it. Anyway, Mr Rob H, I owe you a pint. :D
PostPosted: Sun May 06, 2012 9:35 pm
removal keys http://www.ebay.co.uk/itm/PC5-83-Mazda- ... 23153e5605
easiest way. :thumbright:
The Mighty BeeJay
Rob H
PostPosted: Sun May 06, 2012 9:46 pm
Radio keys are the easiest i removed mine by putting thin screwdrivers in the holes not the very top one though and give it a good tug to the left or right one side will come out. then try the other side. then disconnect the plug and radio ariel.
ecosse
PostPosted: Mon May 07, 2012 9:00 am
Cheers, I'll give it a try today.
lewp91
PostPosted: Mon May 07, 2012 10:01 am
i used paint brushes if they are the small circular holes?
i have quite a few radio keys but none of the circular ones...
and i do quite a few radio swaps and installs for friends, family and people at the pub :)
