It is currently Tue Aug 11, 2026 3:59 am
Post new topic Reply to topic  [ 252 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
PostPosted: Mon Dec 12, 2011 11:51 pm
lovely work and at this point i got to ask what do you do for a living and is that your own personal garage and machine shop?
PostPosted: Fri Dec 16, 2011 4:54 pm
@eogbaker
He does shitty work :lol: (literally, working with robots that clean the floors in cow stables)
The garage is ours (est. 65square mtr) and nope we don't have a machine shop of our own, yet.
Anyhow;
Small update, the intake is back one including a fresh new gasket. We are going to use the GTX intake,
which is shorter and it already has the intake manifold temp. sensor in it for the MegaSquirt to operate correctly.
The 590cc Delphi injectors from the GTX are being used to have sufficient throughput ;)
Tomorrow the rebuilded waterpump back on it, including the rockercover and the trigger wheel at the crank.
Maybe if I have some time left I will refurb the stock oilcooler as well.
PostPosted: Sat Dec 24, 2011 5:15 pm
Updates;
Exhaust manifold, pre-fit. Needs some work at the bottom
Waterpump on, camgears on, cambelt rollers? on, rockercover with new gasket put on, waterpump outlet with new gasket; check
New thermo and gasket
Old versus new... and what do you know; a golden lodge :lol:
New cambelt, Gates Powergrip
Acc. belt and waterpump pulley on, including the engine mount and the alternator. Even de toothed wheel and crank pulley bolted on.
So, it is almost ready to go in the car :D
PostPosted: Sat Dec 24, 2011 5:18 pm
:D looking great
PostPosted: Sat Dec 24, 2011 8:55 pm
Indeed it is, looking forward to seeing the results as it'll make a difference to what I do when I eventually fit my GT engine :D
PostPosted: Sun Dec 25, 2011 1:44 pm
what will you do with your gt engine andy?
H-P-C.NL
M O T O R S P O R T
Soon webshop and shop available
HPCmotorsport ; Mazda Racing, Products, Research and development
PostPosted: Tue Dec 27, 2011 5:32 pm
Well, the plan is to stick it in Meanie, however, at the moment, I'm doing 500 miles and more a week and you know how much fuel costs over here now :?
So, while I wait for fuel prices to fall (hell to freeze over) or move closer to work, I'm just trying to get all the bits I'll need together.
The engine is in a post ford 1.8 BA at the mo, but I need to find the entire engine loom and ECU from a pre ford 1.8 to do the transplant :) I'm not planning on doing much to it internally at the moment, its only got just over 30,00 miles on it, so its barely run in :D Eventually though, I'd like sports CAT, possibly piggy back ECU to get the magic 145hp (pre CAT BG) from it, and then maybe a supercharger, turbo's are so eighties :p
PostPosted: Sun Jan 08, 2012 11:23 am
Updates on the car.
We found out the reason(s) why the turbo engine died.
A faulty wastegate. The valve was not moving a single bit. With some heavy use of a hammer it came undone. It had been rusting badly :evil:
As for the rest, the leftovers in the oil in the sump was telling us that there is coolant in it. Headgasket failure as it seems , it probably died because it was
running with an very high pressure (1.2bar/17psi and more (quick scan in the megasquirt logs)) of the turbo with the faulty wastegate.
Anyhow, on to the new , non-turbo engine 8)
Engine mounted in the car, wiring loom connected and some hoses
Inlet and all the hoses/electrical wiring connected, oil and coolant is already in
Placed the battery finalised some bits and the exhaust refitted
Starting will be done maybe today, maybe tomorrow. We are planning to get some spare ignition parts to be sure (coilpack and edis4 module).
Monday a package will arrive with some heatwrap in it for the exhaust manifold. Will be put on next week. It needs to run first.
H-P-C.NL
M O T O R S P O R T
PostPosted: Sun Jan 08, 2012 11:25 am
Looking good dude :D
PostPosted: Sun Jan 08, 2012 1:16 pm
Absolutely amazing.... How's about hiring me to come work for you lol
PostPosted: Sun Jan 08, 2012 3:38 pm
great work! :D
still using the inlet manifold from the turbo? is that because it has better flow?
The 323F GTR 1.8 Turbo
PostPosted: Mon Jan 09, 2012 4:27 pm
Thanks guys 8)
Inlet is somewhat shorter, maybe it helps. But mostly the TPS is different and will not fit the GT inlet and the inlet temp. sensor is already placed in it.. Keeps the wiring loom the same :D
H-P-C.NL
M O T O R S P O R T
epiphone
PostPosted: Mon Jan 09, 2012 6:53 pm
Hi mate, can i ask what front splitter you have and where you got it?
ChrisL323f
PostPosted: Mon Jan 09, 2012 7:11 pm
Good work guys!
PostPosted: Mon Jan 09, 2012 10:19 pm
bougth it at a breaker, its from a Renault Senic
Extra update ;
just bougth not one but two Edis coilpacks :D so mayby tomorrow the new engine will be running 8)
H-P-C.NL
M O T O R S P O R T
RHRH
PostPosted: Wed Jan 11, 2012 3:56 pm
You should get it dyno'd see what happens...
Also does the BP from the BG GT have VICS? MS supports the VICS valve! You can adjust the
working of it. Or well I've got that module on mine... Wasn't an addon was already there.
Quite interested in knowing some hard figures from this setup... might be 150 somewhere...
PostPosted: Wed Jan 11, 2012 7:53 pm
yes a bg gt engine have VICS and mine MS systeem supports that as well ;)
H-P-C.NL
M O T O R S P O R T
RHRH
PostPosted: Thu Jan 12, 2012 11:13 am
Wouldn't it be better to use the N/a intake then and play arround with the VICS settings?
PostPosted: Mon Apr 09, 2012 11:50 am
Right,
Some updates frome the NL. The whole megasquirt setup did not wanted to work on the new 1.8 engine as well. Only 2 cilinders firing, outer two drenched... So the time kept on ticking and the first round of Time Attack here in The Netherlands was closing up on us we decided to go further on the N/A part. And that in the shape of a V6! 2 Weeks for the first round we have thrown in an 2.5 from the Xedos9 (Millenia) which had stock figures of around 170bhp. Did need to buy a complete MX-3 for it but does it matter ? :lol:
And it worked! The engine keeps on running and holds nicely even after the Time Attack round.
Some engine specs;
2.5 V6 KLDE @ 170pk stock (kl31 heads/curved-neck intake)
KL07 ecu (chipped by DTA Motorsports)
JE50 VAF
M2 Performance exhaust headers
K8 flywheel
6-puck stage3 clutch frictionplate
255l/ph Walbro pump
Estimated power output @ 180-185 bhp
And the rest ? Original Mazda! Alright, the suspension and so not, but engine-wise there is not much changed.
Photo time:) Click on it to get it bigger.
Adri's "office"
Functional switches
The engine
Exhaust manifold, stunning colors
The car itself 8-)
@ Circuit TT-Assen , 1 april Time Attack. With a different set of popup (or stay-down) lights (the other with the lights can't close because of the radiator) and running on the Yokohama Advan AD048 tires @ 15" Borbet alloys.
The BA in front of me is Max, not to be confused with Barreljan ;)
And I even did make it to the finals in the Semi-Pro street class! Overall standings after the first round is 5th of an amazing field of 27 cars running for the championship!
Now hope it's not going to breakdown. If all keeps well, we even can make progress for a long time with all the engine troubles. First progress is already made, I've ordered some new brake pads (EBC Yellowstuff) because I can't keep up with braking...
:D :D
H-P-C.NL
M O T O R S P O R T
PostPosted: Mon Apr 09, 2012 11:55 am
wow amazing work... Do you find it better now with the v6? Also do you know if the car is faster around the track with the v6 or not?
PostPosted: Mon Apr 09, 2012 11:58 am
Thnx!
Better, yes; it doesn't brake down on me ;) If it is better on the tracks? I guess yes because of the usable torque but I really? Don't know. When the turbo engine was running it didn't kept me going (intercooler piping kept on getting off) so I don't have any comparison. So in that case, yes faster but did not had the full potential of the turbo back then.
H-P-C.NL
M O T O R S P O R T
PostPosted: Mon Apr 09, 2012 12:01 pm
I had to do a double take looking at your photo's.
Amazing work with the V6 Hellraiser :thumbright:
PostPosted: Mon Apr 09, 2012 12:11 pm
well I guess at the end of the day when racing reliability is much more important than overall power and speed. Either way your guys work is amazing :D
PostPosted: Mon Apr 09, 2012 12:21 pm
It is a very good competitor on the track this BG with the V6. With just a small margin lets say, 2.11.99 for me and a 2.12.09 for the BG, a tenth of a second... Hmm, and that with shitty brakes... :shock: ohmy
ps. on the last picture you'll see me right, the taillight is the only thing to see and next to it, me in the green shirt waiting for the Semi-pro street to do their inlap, hotlap and outlap 8)
PostPosted: Tue Apr 24, 2012 10:18 pm
Before the first time attack round I already had some gear changing issues. It was sometimes there, sometimes not. We had the idea that the shiftrod underneath the car (modified BG one) was not the correct length. So tried a good MX3 v6 one; no change in the problem.
Tried to sort it out today by guessing the gearbox was dying and removed the MX3 gearbox. With the prepping of the MX6 gearbox we had in the shop and swapping some sensors I found out what the actual problem was.
Sorry for the crappy picture quality
It seems the differential had eaten the gear on the speedo sensor....... :shock:
So, time to get it a part
Well, there's your problem! I can seeeee you
Broken versus good
It's good it didn't smashed up the whole gearbox :lol:
H-P-C.NL
M O T O R S P O R T
PostPosted: Wed Apr 25, 2012 7:23 am
Jesus you got lucky there! :shock: good work as always chaps!
PostPosted: Wed Apr 25, 2012 8:23 am
woah you lucky bugger! :D
glad you got it fixed up nice and quick!
PostPosted: Wed Apr 25, 2012 9:18 am
:shock:
Lucky you got to it in time
PostPosted: Sat Apr 28, 2012 9:29 am
And, will you are at it, lets replace the synchromesh rings as well
If shifts again like a charm! All gears are selectable without any fuzz
PostPosted: Sat Apr 28, 2012 10:41 am
yeah I thought there was going to be a bit more wrong than just the speedo drive... good find
