It is currently Tue Aug 11, 2026 12:37 am
Post new topic Reply to topic  [ 252 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
PostPosted: Mon Jun 06, 2011 8:29 pm
where did you get the oil and water feed from? can I have a link.
Also have a look at filterdot.co.uk if youve a magnetic sump plug this will be a great addition.
The Mighty BeeJay
Shayne
PostPosted: Mon Jun 06, 2011 9:02 pm
barreljan wrote:
Yes indeed, it will be something like this (quick piccie from the net)
Thats the way to go, one that will not break and a nice looking part to.
New beginnings.
PostPosted: Mon Jun 06, 2011 9:26 pm
this one got off ebay and is exactly the one i've ordered:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170649981555
it has no water lines because the turbo is only oil cooled/lubricated
PostPosted: Mon Sep 26, 2011 6:54 pm
And again....
No diagnose yet, but seems no sparking or no compression
Motivation is sinking rapidly :cry:
H-P-C.NL
M O T O R S P O R T
Soon webshop and shop available
HPCmotorsport ; Mazda Racing, Products, Research and development
Andy S
PostPosted: Tue Sep 27, 2011 3:32 pm
Sorry to hear your having all these problems mate :(
Have you not got another engine you can swap in?
PostPosted: Tue Sep 27, 2011 4:06 pm
I don't need to list these for you guys, as you've probably checked already but just incase:
Ignition coil/distributor working? If it is working, is it strong enough? Check with a multimeter to be doubly sure
Bad earth from engine to chassis?
Not enough battery power to produce big enough spark? Jump from a running car, see if that helps (~14v would produce larger spark than ~12v)
Timing belt ok? Not slipped any teeth?
Valve clearances?
Camshaft snapped again?
Total headgasket failure?
PostPosted: Thu Sep 29, 2011 12:18 pm
It happend on the road while cruising.
yesterday we checked a few things;
compression on all 4 cilinders
all 4 leads and sparkplugs work, all 4 spark
fuel is no problem
timing is still correct, belt is fine
camshafts in 1 piece
valvesprings intact
ECU shows all the correct settings
Only the middle 2 cilinders are firing... Maybe the spark is to weak, but why did that happen on the middle of the road during cruising?
H-P-C.NL
M O T O R S P O R T
PostPosted: Thu Sep 29, 2011 12:23 pm
Hmm i would guess that maybe sparks 1 and 4 are too weak :dontknow: this was why my skoda didn't start, all 4 were sparking outside the cylinder, but not firing inside it. New ignition coil fixed that.
I'd try a new distributor (or at least a new cap).
PostPosted: Thu Sep 29, 2011 12:34 pm
nooo not again! it can only be something simple! such as distributer or coil!
you'll get her fixed in a jiffy!
The 323F GTR 1.8 Turbo
PostPosted: Thu Sep 29, 2011 1:12 pm
it has no distributor, it a EDIS4 system from Frod ;)
'New' second hand unit will be around 40-50 pounds, but the motivation of spending more money is gone. It keeps breaking down and why shouldn't I get back to N/A ?
H-P-C.NL
M O T O R S P O R T
PostPosted: Thu Sep 29, 2011 1:14 pm
herp derp derp :lol: shows how much i remember :lol:
That's how much my ignition coil for the shitty Skoda cost :lol: no chance of trying it, if it doesn't work you could return it? You can't give up on my favourite BG :p
PostPosted: Thu Sep 29, 2011 1:23 pm
yeah, go back to N/A...then send me all your turbo parts :lol:
hope you can get it sorted mate, I love this car...
Stuz
PostPosted: Thu Sep 29, 2011 1:34 pm
I too hope you can get it sorted. . . . . I love this car too :)
PostPosted: Wed Dec 07, 2011 7:26 pm
little update :
The story continues, i removed the GTXR engine from the BG, and i'm now rebuilding a N/A GT engine. It will have some of the GTXR engine like the megasquirt systeem, Edis ignition, injectors,fuelrail, turbo intake manifold, fidanza flywheel, stage 3 cintherbronze clutch, gearbox (willbe fitted with a phantomgrip diff)
and i will add a 4-2-1 Ford RS2000 header and make the exhaust a bit shorter to make a diffusor
pictures will follow, my goal is japfest second try :P
H-P-C.NL
M O T O R S P O R T
PostPosted: Thu Dec 08, 2011 12:25 am
Nothing wrong with N/A chap, wish I could afford to fit my BG GT engine :?
Mr. Ali
PostPosted: Thu Dec 08, 2011 2:36 am
Do you want to fit a turbo on the GT when it runs smooth? I know..you've tried before..but a normal GT hasn't got that much power for the circuit ;)
PostPosted: Thu Dec 08, 2011 8:16 pm
it won't be a normal gt engine, its just now for the time beeing, the GTXR engine will be rebuild later on. but i need to drive my bg as it is now... i think it will have 160 mayby 170bhp and that on 900kg... better to handle than 320bhp :P
Update :
'new' GT in on the engine stand, (is it called this way?) ready to get some new gaskets, seals and new parts :) still dont have any photos (BARRELJAN had made some)
H-P-C.NL
M O T O R S P O R T
PostPosted: Thu Dec 08, 2011 9:45 pm
Out with the busted engine
Here some low-qual piccies of the most greasiest 1.8 GT engine. Ready to be cleaned
PostPosted: Thu Dec 08, 2011 9:47 pm
so i am guessing you never found the problem?
PostPosted: Thu Dec 08, 2011 9:59 pm
Not yet, probably the head itself or the gasket of maybe some internal problem we guess :roll:
When the car is running again the GTX engine wil be taken a part to check all the internal components and rebuild.
PostPosted: Thu Dec 08, 2011 10:09 pm
thnx for the pictures :) 8) next saturday i will continue rebuilding refurbishing this engine ;)
H-P-C.NL
M O T O R S P O R T
PostPosted: Thu Dec 08, 2011 10:52 pm
well i am really glad you guys are not giving up with this car :D :D
PostPosted: Fri Dec 09, 2011 12:34 pm
We have plenty of engines standing in the workshop, so no we are not giving up this car 8) The only thing for now we give up is turbo'ing.
Quick list: 1 gt (as seen above), 1 gtx dead (as mentioned earlier), 1 gtx spare, 1 2.0 kf, 1 gt (headgasket failure), 2 gt's in parts, 1 2.5 kldze :lol:
Andy S
PostPosted: Fri Dec 09, 2011 2:08 pm
Good to hear that she's still up living on mate. And Barreljan, I know where to come if my engine dies to get a new one ;) :lol:
Mr. Ali
PostPosted: Sat Dec 10, 2011 1:14 am
A total rebuild will be expensive! But I hope that you'll get the GTR in de F, running without problems :D
What have you done with this GT to get the 160 - 170 BHP? :D
PostPosted: Sun Dec 11, 2011 12:19 pm
The outside of the engine is completely degreased
And later on, several old gaskets removed and some oilseals around the crankshaft and camshafts. Waterpump is removed and so on..
H-P-C.NL
M O T O R S P O R T
ChrisL323f
PostPosted: Mon Dec 12, 2011 12:13 am
Sorry to hear about you guys giving up on the forced induction... :(
But still, awesome NA engine there!
Maybe ITBs??
PostPosted: Mon Dec 12, 2011 12:44 am
@Chris, giving up.... for now ;) in the future it will be back
Nope, no ITB's. Keeping it simple is the magic word. Not trying to mess around too much and ending up with a similar problem which is a dead engine. Most interesting part of this will be the stand-alone ECU (megasquirt) and see how far we come without any internal mods or for example regrinds of cams.
lewp91
PostPosted: Mon Dec 12, 2011 12:14 pm
isnt edis wasted spark? implying that 2 cylinders will always fire at the same time (the ford firing order)??
arnt 1 and 4, and 2 and 3 paired? just a thought..?
PostPosted: Mon Dec 12, 2011 11:19 pm
@lewp91; you are correct, it is a wasted spark system. We do keep in mind that the ignition or coilpack is damaged some how. We'll see.
Updates for now:
Arrived friday's, the new Mazda OEM rockercover gasket
'New' oil pan since the old one was busted (see here)
And degreased it
Inside all spankin' fresh
New oil sump including a fresh new gasket. The one on the right is the old one including a piece of the old oilpan
Next, sanded down the block , cleaned it and put on the heat-resistant paint to tidy it up. The oilpan is already in place and do not mind the ugly rockercover :oops: There will be an original black one on it tomorrow.
The dizzy plug. Perfect machined stop to block of the original hole for the distributor
New cam seals
Hopefully some more updates tomorrow.
H-P-C.NL
M O T O R S P O R T
