Club323F • View topic - 1995 Mazda 323f v6 problem non starter
It is currently Tue Nov 03, 2026 5:47 pm
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3  Next
zutekh
PostPosted: Fri Jan 07, 2011 12:56 pm
lol, what's the cost of getting the CPS replaced?? If that is the problem
PostPosted: Fri Jan 07, 2011 12:59 pm
I think the sensor is about £60-£70 on fordprobestore.co.uk. They're easily damaged so it's probably best to buy a new one rather than get a used one from a breaker.
Roc
PostPosted: Fri Jan 07, 2011 2:40 pm
I've got one in stock too.
zutekh
PostPosted: Fri Jan 07, 2011 3:29 pm
Good stuff, hoping that's all i'm going to need. If ordered on Monday, is it next day delivery?
col
PostPosted: Fri Jan 07, 2011 3:50 pm
:D :thumbleft:
[img]http://i196.photobucket.com/albums/aa84/coli230/col-signature1.jpg[/img]
ITS JUST NOT CRICKET
Roc
PostPosted: Fri Jan 07, 2011 4:17 pm
[quote="zutekh"]Good stuff, hoping that's all i'm going to need. If ordered on Monday, is it next day delivery?[/quote]
Next day is one of the choices available.
I only have one in stock, should still have it on Monday though, I don't sell them every day.
It's a pretty easy part to fit too.
zutekh
PostPosted: Fri Jan 07, 2011 4:27 pm
Thanks, let's just hope that's all I need. Fingers crossed
Roc
PostPosted: Fri Jan 07, 2011 4:41 pm
[quote="zutekh"]Thanks, let's just hope that's all I need. Fingers crossed[/quote]
If it's not, it could be the distributor, which I shift loads of, so they are a weak point.
The Crank Sensor will usually set a fault code.
PostPosted: Fri Jan 07, 2011 4:51 pm
Read through the thread someone posted above mate - there's instructions on checking fault codes in there. If you search the forum for "fault codes", you should find some more detailed instructions too.
Rather than buy random parts until you fix the problem, it would do you good to read the whole thread of someone who had the EXACT same symptoms, so you know what they did to diagnose and solve the problem :thumbleft:
zutekh
PostPosted: Fri Jan 07, 2011 4:52 pm
[quote="Roc"][quote="zutekh"]Thanks, let's just hope that's all I need. Fingers crossed[/quote]
The Crank Sensor will usually set a fault code.[/quote]
Ok, is the distributor around the same cost? How much labour would that take to replace?
Roc
PostPosted: Fri Jan 07, 2011 4:54 pm
[quote="zutekh"][quote="Roc"][quote="zutekh"]Thanks, let's just hope that's all I need. Fingers crossed[/quote]
Ok, is the distributor around the same cost? How much labour would that take to replace?[/quote]
Brand new distributors with 3 YEAR warranty are £199. Dead easy to fit, 5 mins.
zutekh
[quote="HughieW"]Read through the thread someone posted above mate - there's instructions on checking fault codes in there. If you search the forum for "fault codes", you should find some more detailed instructions too.
Rather than buy random parts until you fix the problem, it would do you good to read the whole thread of someone who had the EXACT same symptoms, so you know what they did to diagnose and solve the problem :thumbleft:[/quote]
Yeah I did read through it but must of missed how to actually check the fault codes. I'll go back through and read the whole thread :)
col
PostPosted: Fri Jan 07, 2011 5:03 pm
viewtopic.php?f=18&t=37354
read this one
zutekh
PostPosted: Fri Jan 07, 2011 5:40 pm
Col, he had the same problem as me - I know it has a slight oil leak from a rocker cover gasket and has done for a few years. Sounds like it could of caused the problem. Hopefully we're getting somewhere
col
PostPosted: Fri Jan 07, 2011 5:56 pm
i still have a post ford dizzy that works fine
but hopefully you wont need it
zutekh
PostPosted: Tue Jan 11, 2011 9:03 am
The CPS has been replaced but still nothing happening? :(
Stuz
PostPosted: Tue Jan 11, 2011 12:51 pm
Sounds like a distributor related probkem if you don't have a spark, have you removed the dizzy cap and checked the arm and all the contacts inside ?
AlanK
PostPosted: Tue Jan 11, 2011 10:00 pm
i would guess at the dizzy,, i have had 2 gone in about 3 years
zutekh
PostPosted: Wed Jan 12, 2011 1:38 pm
Trying to find a cheap dizzy now.
col
PostPosted: Wed Jan 12, 2011 1:56 pm
maybe check the mx3 just someone mentioned they are the same as preford
zutekh
PostPosted: Wed Jan 12, 2011 2:21 pm
think i've found one. just checking the part number on the current one to see if it's right. £35 not bad!
col
PostPosted: Wed Jan 12, 2011 2:25 pm
good price
zutekh
PostPosted: Wed Jan 12, 2011 4:47 pm
£56 delivered by Friday - not bad, just hope that it solves the bloody problem!
col
PostPosted: Wed Jan 12, 2011 5:33 pm
hope so
zutekh
PostPosted: Fri Jan 14, 2011 2:36 pm
What would a white 1995 Mazda 323f v6 be worth as spares or repairs? Just in case after trying the distributor it won't start I'll have to get rid as I desperately need a car for work.
Really enjoyed driving it for a couple of days and would love another one
PostPosted: Fri Jan 14, 2011 2:57 pm
A white one you say? That means you have the second one to have popped up recently, white V6 = not very common at all.
Hopefully the dizzy will sort it for you :thumbright:
zutekh
PostPosted: Fri Jan 14, 2011 3:47 pm
I hope so too!
It's in mint condition. How do I post up pics on here?
PostPosted: Fri Jan 14, 2011 3:50 pm
Either upload as an attachment when you post a reply/thread (although they can only be up to a certain size) or easier - get a photobucket / Google Picasa / other online photo sharing account, upload them to that and then copy the link to each picture and put it inside some
[ IMG] http:// link goes here [ /IMG] tags.
Look forward to seeing it!
zutekh
PostPosted: Fri Jan 14, 2011 4:11 pm
Trying the tag but it's not working?
You can check the images from photo bucket
http://s1132.photobucket.com/albums/m569/richzutekh/
zutekh
PostPosted: Fri Jan 14, 2011 4:15 pm
Ahh here we go
[img]http://i1132.photobucket.com/albums/m569/richzutekh/DSC00519.jpg[/img]
