It is currently Sun Oct 04, 2026 1:35 pm
GUIDES ONLY please.
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
Artermis
PostPosted: Thu Mar 30, 2006 6:46 pm
rite then kiddies, me n joe manage to grab ourselves a couple of bargains so we fitted some 6x9s to both of our front doors this mornin, putting the standard 5x7s in the back doors, and heres how!
First phase
first step make sure the windows are down (important), then remove the door cards. this aint hard. dont forget to disconnect the plugs that connect the mirrors and windows controls.
screws:
1x top front corner
1x door handle
1x ash tray
1x top back corner of pocket
that should see the door card off (dont be afraid to give it a bit of a tug ;) ) if i missed any screws i apologies. you may have to open the door handle on the inside to get the card off.
this should leave you confronted with this.
step two
offer up the speaker to check for clearance on the window. this is why you need the window down.
not the best pic but you can see the plastic cup the magnet sits in, its pretty close but it dont touch it! (if it does then its down to you to make an approprite spacer, probably out of MDF)
step two A
clearance checked, you can mark the holes you will need to drill for the 6x9s (the standard holes aint ever gonna line up)
just in case you cant see the mark, here is joe's finger!
ahhh, top hole! repeat process for remaining three screw holes. remember these are only pilot holes
step three
next the wiring. you could just hack up the original clip, but why not make a lil bit of wire that plugs into the standard clip using spade bits. so should you require to revert to standard for whatever reason, your wires fit.
plug into the standard connector and plug into the speaker.
screw the speaker in and your done. a good self taping screw is required for this. dont over tighten the screws, wouldnt like you to damage the speaker! however some work must be done on the door card.
step four
the door cards as you can see has a plastic rim round the inside of it to sit on the speakers, which must be removed in order for the new ones to fit.
as you can see, using a good knife cut slits into the ring
then bend the pladtic back and score it till it comes off. the end result should be a little like this:
replace the door cards repeat for the other side. then advance forward one place :D
first phase complete
____________________________________________________________
second phase
however now the more complex part of gettin the 5x7s that were in the front, in the back.
step one
first of removing the door card. there again is one screw in the door handle and another in the ash tray sort of bit.
you must also remove the winding handle (if you have one). these have a metal clip in them:
which must be removed in order to take the handle off. can be popped out with a flat head screwdriver (though be prepared to catch it!)
card off you have this poxy thing:
step two
as you can see the hole it leaves is nothing like large enough, so it has to be enlarged
have the speaker out and offer up the 5x7 to work out what needs cutting.
i should mention at this point that the pastic guard on the back of the 5x7 has been removed! this can be removed with a knife cutting the glue off and just pulling.
should have it marked something alone the lines of
step three
now you have the cut marked, its time to attack it. we used a jigsaw to do this, anything else would probably take an age. it is at this point we must remind everyone using any power tool to wear the correct safety equipment
kitted up hack away (filing down sharp edges) till you are left with an enlarged hole:
now simple repeat the abox steps regarding the marking and fixing of the speaker and you should have a cracking sound system.
do not forget to do the same to the rear door cards as you did to the front, to avoid damaging the speaker.
phase two complete
now feel free to giggle with delight at how fantastic your car sounds
Image (or bounce around like extatic apes too, cheers Rich!)
Joe and Ben
ZerweX
PostPosted: Thu Mar 30, 2006 8:31 pm
nice work there :thumbright:
but I don't understand why people want 6x9's when a cheap comp. system sounds way much better.. just my opinion tho.
PostPosted: Thu Mar 30, 2006 8:38 pm
Hmmmmm - now where did you learn how to do that?!?!?!?!?
Seems like monkey business to me......
Dai
PostPosted: Thu Mar 30, 2006 8:47 pm
chuckle chuckle vision chuckle vision
to me to you to me to you
nice guide lads :D looks handy
PostPosted: Thu Mar 30, 2006 9:27 pm
Top goggles there boys :D:D:D:D:D
JAM
PostPosted: Thu Mar 30, 2006 9:43 pm
LMFAO @ Andy
PMSL :D
Good Guide tho :thumbright:
PostPosted: Thu Mar 30, 2006 9:48 pm
I wonder if they were fire retardent?!?!?!?!? :bom:
JAM
PostPosted: Thu Mar 30, 2006 9:49 pm
:laughing3::laughing3::laughing3:
Ouch :D
PostPosted: Thu Mar 30, 2006 10:01 pm
Ben, you really have a gay cum face...................
PostPosted: Thu Mar 30, 2006 10:06 pm
Is that an invite stu? ;)
*******R.I.P - The Mystery Machine BA TURBO *******
PostPosted: Thu Mar 30, 2006 10:11 pm
It looks like it to me, a right pair of 'come to the bath' eyes hes got huh.......
maylander739
PostPosted: Thu Mar 30, 2006 10:22 pm
haha, pics made me laugh
well done guys :D
PostPosted: Thu Mar 30, 2006 10:29 pm
ROTFLMFAO @ u all :D:D:D
Ohhh, the little monkeys :D:D:D
do i sense a touch of Softball here ;)
Dai
PostPosted: Thu Mar 30, 2006 10:30 pm
have a shave lads :D
"come to the banana tree" more like ;) PMSL
PostPosted: Thu Mar 30, 2006 10:34 pm
......even sporting a set of 'his and his' matching deflectors :evil4: :evil4: :evil4:
Top furry guide though gents...................furry................ :laughing6:
PostPosted: Thu Mar 30, 2006 10:36 pm
I surely detect a little monkey magic was needed to get 6 x 9's in the front doors.......
Dai
PostPosted: Thu Mar 30, 2006 10:38 pm
what sort of music should one listen too when checking the quality of the new install??
something by the Monkees perhaps??
PostPosted: Thu Mar 30, 2006 10:43 pm
" Hey Hey were the monkeys ;) for F's sake were only .....
PostPosted: Fri Mar 31, 2006 7:58 am
Well, what can I say ... :roll:
:thumbleft:
Hugh Lamont
PostPosted: Sat Aug 26, 2006 6:40 pm
if mine give me any more grief, im going to rip the door off completely and hit it with a hammer >: (
Jason
PostPosted: Mon Aug 28, 2006 7:11 pm
never mind fire retardent do u realise u luk like retards in them glasses i hope ur birds (if u got any ) dont c them pics !!!!!!!!!!!!!!!!!!!
Joe
PostPosted: Mon Aug 28, 2006 9:01 pm
Must admit mate, we were trying to look sexy in them. Now you've pointed it out i realise that you're quite right. I must always concider that my girlfriend, who also has no sense of humor, just like you, will finish with me because of that terrible picture.
Basically, to sum up what i've put above. YOU PRICK! don't come in here with your 13 posts and ruin the hole meaning of Club 323. If you're not going to input anything meaningul or useful or even good humored to the site then don't bother using it.
Joe
Artermis
PostPosted: Mon Aug 28, 2006 9:19 pm
thats ok, Jason, whilst we may only look retarded, you just possibly are.
see, you obviously were interested in this mod, so read the thread, which without us, you wouldnt have a clue about doing.
so when you go out and get metal shards in your eyes cutting up your doors, my brother and I will continue to have a laugh modding our cars, only this time at your expense, whilst still wearing our most sexy (and highly protective) safety goggles.
good day,
Ben
Hugh Lamont
PostPosted: Mon Aug 28, 2006 9:56 pm
hahaha, i have 500 posts!! more than that i think, how did i get that many...
i still havent managed to get my speekers in and im getting more and more annoyed.
bit of mdf on the parcel shelf me thinks :(
Joe
PostPosted: Mon Aug 28, 2006 10:38 pm
How come? The magnet too big?
Joe
CraZe_EntERtaInMEnT
PostPosted: Tue Aug 29, 2006 12:33 am
woah thats crazy!! my car dont have round speakers they're like 6x9's or 5x7's and thats in all the doors... then again myns japo it came with alloys and a spoiler similar to robs and chrome door sills i must take some pics and add my car to the site but ill wait till i change the spare wheel first lol.
besides my cars different-ness id say top guide!
Hazardous
PostPosted: Tue Aug 29, 2006 12:54 am
oh yeh im lovin the googles!!! what would the world be if we had no sense of humour?
Artermis
PostPosted: Tue Aug 29, 2006 6:32 am
probably fairly similar to jason!
well i raided a type R at a scrappy and i know it had 5x7s in the front, would be interesting to see what u got in the back of yours!
does your jap import / type R have the centre dash lil speaker then?
Ben
Hazardous
PostPosted: Tue Aug 29, 2006 8:01 am
yeh just imagine everyone like jason....
dont like that thought.... and yep my cars a japo... it has the speaker grill in the dash but no speaker lol...(thats weird who does that??)
