Club323F • View topic - gearbox
It is currently Wed Nov 11, 2026 3:27 pm
 Post subject: gearbox
PostPosted: Sat Oct 30, 2004 1:59 pm
Ever since i got the car...the gearstick has been really stiff.
It shifts perfectly but just requires a bit of effort....any ideas on what the problem is...
PostPosted: Sat Oct 30, 2004 2:21 pm
If you check back through the posts you may find one froma while back - think it could just be new rubbers needed - check with Smotter I think
PostPosted: Sat Oct 30, 2004 11:33 pm
Hi Maz - One thing you can check quickly - nylon bushes in the gear shift linkages - jack up your car and give them a wiggle - if you see ANY play on the bushes, they need replacing - I had the problem at aroun 160,000 kms (about 100,000 miles). See http://www.maz323f.co.uk/forum/viewtopic.php4?t=1248 for details ...
PostPosted: Sun Oct 31, 2004 2:51 pm
How long did it take you to change and how easy is it...Do you have to realign anything afterwards....im a crap mechanic.. :D...Any special tools??
Where did you get that diagram from in that other post??
Sos for the questions...wanna be sure its an easy job...
PostPosted: Mon Nov 01, 2004 3:13 pm
Hi - I got the diagram from my Haynes "Mazda 323/Protege" (American Version) manual - covers most things for mt '96 1.8 16v.
It took literally about 10 minutes to do - I needed two spanners (12mm, I think, or maybe 13 or 14). It took longer to jack the car up and settle her on axle stands than to change the bushes !
No alignment is required - everything will only go in one place.
Just check that the bushes are loose first before you buy replacements; there are various other things that can also cause stiff gears ...
pop twang
PostPosted: Thu Nov 04, 2004 1:07 pm
A friend informed me that my reversing light was not working so off i went to get a new bulb. new bulb fitted and reverse light still not working. So now i'm thinking reverse light switch problems, maybe just a dodgy connection but can you tell me where it is?
Is it where i think, next to the gear lever under the central housing for the gear lever and handbrake? This would make sense as the cig lighter ain't working either and i think that was caused by disconnection when who ever it was fitted the stereo.
Or, is it under the car?
Or, even plugged into the gearbox itself?
Smotter,
