Club323F • View topic - Problem with Automatic Gearbox - 1.8 323
It is currently Wed Nov 11, 2026 6:51 am
prashan
PostPosted: Tue Oct 12, 2004 9:35 am
Hi All,
Having replaced my expensive headlamp.... I now seem to have a problem with my auto box.... initially I thought it was caused by the new 16" alloy install, but no... its definitely the gearbox.
The problem - a severe judder when pulling away in first gear or kicking down - car fine when cruising at high speeds.
Has anyone had an auto gearbox overhaul ? I know that there aren't many auto owners on this forum.
Can anyone recommend a good place to get the overhaul done ? My Mazda dealer is quoting something like £1k for the work..
Prashan
PostPosted: Tue Oct 12, 2004 11:40 am
You will usually find a good second hand gearbox for far less than an overhaul ....
KBS
PostPosted: Wed Oct 13, 2004 12:38 pm
My manual gearbox from a scrapyard was £180 so look for about that price, the most i was quoted was £250 all manual and for a 1.5
so good luck on your search
John
Wai.Cheung
PostPosted: Wed Oct 13, 2004 12:47 pm
Has your car been fixed now?
KBS
PostPosted: Thu Oct 14, 2004 7:36 am
yes car now fixed, it needed all told a gearbox, clutch (as old one covered in oil) and replacment air filtre to throtel housing hose as old one was split, also oil seals X2 replaced on box and replaced oil in box, all told an expensive operation :shock: if you add up all the costs with labour, but now running ok :D
John
PostPosted: Thu Oct 14, 2004 9:22 am
where did you get and how much did it cost for the replacment air filtre to throtel housing hose - mine has split too. my car is currently at a Mazda garage and no doubt they will tell me it needs replacing.
PostPosted: Thu Oct 14, 2004 10:54 am
Ooh, ooh, I need one too!
KBS
PostPosted: Thu Oct 14, 2004 3:30 pm
brought the hose and clutch and gearbox all from the same scrapyard (fenland breakers ian on 01354651949 )
But got origial link from this company :)
http://www.breakerlink.com
you put up your request for parts and quite a few scrapyards get postings from them i had 2 replys in 1/2 hour, i took cheepest quote for parts as box only done 48k
John
prashan
PostPosted: Sat Oct 16, 2004 3:18 pm
Thanks for the help guys... am going to a place called Stevens Engineering in Palmers Green, London - they're an Auto gearbox specialist... as my problem is intermittant, they're going to do a gearbox service - £100 - oil and filter change.... they say that should give them an idea if the problem requires an overhaul or not - overhaul cost is £1k....
PostPosted: Sat Oct 16, 2004 11:26 pm
Hey guys, I've been thinking.
I'm not sure about over there, but here in SA, the Astina is based on the running gear of the Mazda Etude, which is pretty much the family 4 door saloon equivalent of the Astina. I know they make a 1.8 16v version of the Etude which has exactly the same motor as the 1.8 16v Astina, with the exception of a heavier fly wheel (more torque but less power ...) so I expect it has the same gearbox. So - you might be able to get a good second hand gearbox from an "Etude" (or whatever they are called over there) fairly easily ???
