Club323F • View topic - Handbrake light again
It is currently Thu Nov 12, 2026 9:48 pm
corelasino
 Post subject: Handbrake light again
PostPosted: Thu Jan 12, 2006 8:37 pm
Listen now my situation!
My light was lighted all time about few days!
I check my brake fluid and it was on min. and I put some fluid into car, so my fliud is on max.!
AND you can't belive light was stooped lighted! I am driveing two one whole day and it again beging light, and whole today's day it light!!!
Fluid is on max!
What you think what can be possible????
I think it must be something with fluid!!
Thank You
PostPosted: Thu Jan 12, 2006 8:48 pm
My light has turned on twice since i had the car... both times the pads had worn out so i simply replaced them and that solved the problem :D
PostPosted: Thu Jan 12, 2006 8:51 pm
VERY VERY simple answer.....................
Your handbrake switch has become dislodged................
Inside the centre console is a switch that - when the handbrake is released presses it and disconnects the circuit.
I bet if you remove the centre console around the handbrake, you will see the switch loose and away from its clip........:thumbright:
PostPosted: Thu Jan 12, 2006 8:57 pm
If it it's the brake pads, you may need to remove some brake fluid - be careful that it doesn't over flow when you're changing the pads.
Stuart McB
PostPosted: Thu Jan 12, 2006 9:09 pm
Hand brake center consol is sooooo easy to remove. There's a guide on the site for it. Takes minutes.
corelasino
PostPosted: Wed Jan 18, 2006 10:28 pm
Yesterday I was changed pads and the light was gone!
Thanks god!
