Club323F • View topic - Throttle lag, anyone else have this ?
It is currently Fri Nov 13, 2026 11:18 pm
sam2mazdas
PostPosted: Fri Jan 06, 2006 3:54 pm
Does anyone else have this ?, on my 1800 exec ba, I get a slight delay in throttle response, ie when I press the throttle pedal there is around a 1 to 2 second delay before revs pick up, and conversely when I come off the throttle there is a similar lag before the revs drop, can make for messy gear changes.! ! !.
Anyone know why this could be? :oops: :oops:
fil_auto
PostPosted: Fri Jan 06, 2006 3:59 pm
[quote="sam2mazdas"]Does anyone else have this ?, on my 1800 exec ba, I get a slight delay in throttle response, ie when I press the throttle pedal there is around a 1 to 2 second delay before revs pick up, and conversely when I come off the throttle there is a similar lag before the revs drop, can make for messy gear changes.! ! !.
Anyone know why this could be? :oops: :oops:[/quote]
... sticky throttle cable ?? :cyclopsani:
sam2mazdas
PostPosted: Fri Jan 06, 2006 4:02 pm
Nah, throttle linkages, cable are all lubed up and free running, thanks for the suggestion, but it aint that.
fil_auto
PostPosted: Fri Jan 06, 2006 4:21 pm
[quote="sam2mazdas"]Nah, throttle linkages, cable are all lubed up and free running, thanks for the suggestion, but it aint that.[/quote]
fairdoes ... I suppose its down the line of plugs, leads, air filter etc then ??? :cyclopsani:
PostPosted: Fri Jan 06, 2006 4:36 pm
Try checking your shpark plugs :cheers:
May be missfiring...
Artermis
PostPosted: Fri Jan 06, 2006 7:46 pm
i would make sure that you have the throttle cable nice and tight onto the air intake.
also check your airways. induction kits do tend to improve throttle response as the air flows quicker through them!
Arty
JDM
PostPosted: Sat Jan 07, 2006 12:05 am
mine does the same really but not that bad a delay, i think the throttle cable is abit loose and needs tightening... lets hope i dont over do it and snap it :D
