It is currently Mon Aug 10, 2026 3:46 am
Post new topic Reply to topic  [ 451 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 16  Next
PostPosted: Sun Mar 08, 2015 6:22 pm
Pre-foaming is badass!!! Cant wait to see the next update photos dude :)
PostPosted: Sun Mar 22, 2015 8:26 am
Only a small update this time round, new fogs(pre-ford) are all fitted and looking the part very nicely, and so glad we are starting to get the better weather as she stays clean for more than 3hrs at a time :D.
Ive also got a new spoiler which i might fit...........
was a bit of a drunken buy, id been watching the GT, and was presented with an absolute bargin, needs a fixing kit as it didnt come with any..... :oops:
PostPosted: Sun Mar 22, 2015 8:37 am
Look mah, no legs!!!
Ages and ages ago I had a spoiler with no legs, so I bought a piece of A3 sized 5mm thick aluminium, and started cutting a pair of legs out. Cheapest option! If you have a big hacksaw or grinder, and a drill, and some patience :lol:
PostPosted: Sun Mar 22, 2015 8:42 am
ha ha, it could be worth a go, its got the fixing pionts on the underside, one of my brothers works with CAD CAM, so i might try a custom design for a set......
cant complain though as it cost very little, but it needs a bloody good clean and compound so that should keep me busy for a while.
Got in touch with Lerch about the shocks too 8)
PostPosted: Sun Mar 22, 2015 8:54 am
Ooo get your brother to do it then, much nicer end result! Make a cardboard template and give it to him saying "ere lad, make this in 5mm aluminium" :thumbleft:
Nice work, I'll nudge him today :lol:
PostPosted: Sun Mar 22, 2015 12:50 pm
Cool, that should look good Paul!
Oi, leave ne alone Hughie, stop bothering me :p
PostPosted: Sun Mar 29, 2015 1:26 am
just got myself a new set of springs n shocks courtesy of Lerch :D
whirlwind deal between the two of us, but a nightmare with getting them here, the courier lost them.......but then found them :shock:
just waiting for a break in the weather then i can get the car up on the stands and swapped over.
they have a -60mm drop and from having a look at the way Vulcan sat on them im getting quite excited about fitting them.
so if anyone fancies any -40mm springs i may have a set for sale soon :D
PostPosted: Sun Mar 29, 2015 1:42 am
Just a quick question: when going to -60mm lowering does you need shorter shocks or you can go with the standart ones? What about -40mm?
PostPosted: Sun Mar 29, 2015 1:51 am
no these springs are fitted to standard, unchanged shocks. The same for the -40mm springs too :D
i was a little dubious about going lower than -40 as i have a full car at times and a little worried that even an extra -20mm might be too much of a problem, but after a few chats im quite happy with dropping that extra little bit
PostPosted: Sun Mar 29, 2015 9:21 am
Are they fitted yet? :p
scalman
PostPosted: Sun Mar 29, 2015 10:29 am
smurf182, nice. red ones must be stiff as chair thou .. :badgrin: i still thinking to put or not to put green ones, dont like too stiff car, then its like wood. who would like to ride on tree :lol: so its 60mm .. hmmm :doubt: its low man...show us pics soon. i wanna see it with my own eyes how 60mm looks. :shock:
in my country ...roads are not perfect. :oops: would be cool thing to try ride F's with different type of springs and compare... 8)
PostPosted: Sun Mar 29, 2015 10:42 am
Mine was on -60mm for quite a while and they were no harder than the -40's I had on Maddy :) never had any problems with the -60's
scalman
PostPosted: Sun Mar 29, 2015 10:58 am
Lerch, so how harder they are compared to default ones ? so its not tree hard ? :)
p.s. wonder why my empty cars front its higher then rear ... :| but allready ,my espace lip is touching lots things were i take car .. so wouldnt be possible even drive with lowered ones i guess.. good that lip is soft so its not braking. 8)
PostPosted: Mon Mar 30, 2015 5:15 pm
Not yet Lee, will be very soon tho, ive got the long weekend off and some cover sorted should it pour down....at least its not blowing a gale...got a new set of drop links and borrowed the grinder from work to get one of them off :D
so all will be revealed friday...cant wait 8)
PostPosted: Mon Mar 30, 2015 9:53 pm
Rear drop links might be the sticking point mate, id get a set if you can :)
PostPosted: Mon Mar 30, 2015 11:17 pm
Aye, they are an absolute pain, in theory the easiest job in the book :(
grinder will sort them no worries :D
PostPosted: Tue Mar 31, 2015 8:17 am
Awesome! looking forward to seeing the results matey :)
PostPosted: Sat Apr 04, 2015 8:23 pm
Finally a day if sunshine.......woo hoo :D
the rear suspension is all swapped over now, not too bad a job really, just a bit fiddly and an appearance from 'that f*****g nut'
will give Womble time to settle into the new springs before i get any pics as at the moment there is no noticable lowering, but she feels tight as a drum when i took her out for a drive, just the fronts to sort out tomorrow, and the weather is set to be good again too :D 8)
scalman
PostPosted: Sat Apr 04, 2015 9:22 pm
so when pics coming. and if possible show it from side how low it is . 8)
PostPosted: Sat Apr 04, 2015 10:01 pm
ill give it the weekend before i get some after shots as the car/springs need to settle it which will take a day or two :D
PostPosted: Sun Apr 05, 2015 12:11 am
Give us "before" and "after" shots..
PostPosted: Sun Apr 05, 2015 9:45 am
Yep will do, though dont expect a dramatic drop tho, dont forget i already have -40mm drop so there will only be an extra -20mm drop
scalman
PostPosted: Sun Apr 05, 2015 10:39 am
so just.. drop it like its hot ... :lol: and if you would be so kind.. show gap between ground and car...
is this pic -40mm ? ..its kinda high
PostPosted: Sun Apr 05, 2015 2:02 pm
yeah this is -40mm drop, though with me just fitting them, they actually sit higher at the moment, the springs need time to settle for a little while, ill get some pics taken soon so you can see the difference
the difference in the handling is already there though, tight as a drum all round. a little bit stiffer, but i like it like that, even better on the twisty's now too 8) :D
scalman
PostPosted: Sun Apr 05, 2015 2:55 pm
good then. and about that stiffness.. how about other passengers in car, would they feel that stiffness like if road is bumby and stuff ? i mean how you feel yourself road now ? 8) i mean bad road
by cars high i cant actualy see what those -40mm did there. so 60 mm should be more visiable i guess
what about this kinda vilage road
or this
:badgrin: :badgrin:
PostPosted: Sun Apr 05, 2015 2:59 pm
can feel the bumps a little bit more due to the stiffness, will see how the G/F feels as only been me out on my own for now.
yeah i cant wait till the car settles into the new springs, looked very nice on Lerch's pics 8)
scalman
PostPosted: Sun Apr 05, 2015 3:03 pm
yes that lerch one looks great surely . but maybe some thing is about wheels themself too
PostPosted: Sun Apr 05, 2015 6:42 pm
yes this is true, i only have tiny wheels, 15inch, with a bigger wheel it plays a trick on the eye making them fill the arches better, but the bigger the wheel the smaller the sidewall on the tyre, so too big a wheel with to thin a tyre, plus stiffer suspension would make for a horrible ride for a daily driver, im very happy with the results though :D
scalman
PostPosted: Mon Apr 06, 2015 4:53 am
Sure. Some cars are made for look or performance here. and some need daily driving and comfort. like in summer traveling long distances to sea, rivers or lakes, in forest. So yes low's great for city and perfect roads. And in some roads where I was last summer just wouldnt be possible with low car.
PostPosted: Tue Apr 07, 2015 12:09 am
Quick pic of the old gal, new suspension added,given a damn good clean(Meg's of course) and also with the 'pre ford' fog lights fitted.
Just need to fit the new spoiler now :D
