Club323F • View topic - mazda 6 brake conversion bj2j48 4+5 stud
It is currently Sun Nov 01, 2026 4:25 am
JDM323
PostPosted: Sat Sep 22, 2012 10:32 pm
i have just done the conversion datails in link
http://www.astinagt.com/forums/showthread.php?t=19832
TheMAN
PostPosted: Sat Sep 29, 2012 2:18 am
it's easier to just get the FL 323F Sport calipers in the UK instead of the Mazda6 ones :)
PostPosted: Sat Sep 29, 2012 7:11 pm
Yup, we already have big brakes. :D
Nice job though. :wink:
JDM323
PostPosted: Sat Sep 29, 2012 10:10 pm
so does that mean the uk rear backing plates will clear 279mm rotors without modification? if so does anyone have a spare set? :)
TheMAN
PostPosted: Sun Sep 30, 2012 5:52 am
the Aussie SP20 dust shields will clear 280mm discs just fine
how do I know? I did the EDM conversion myself!
JDM323
PostPosted: Sun Sep 30, 2012 7:21 am
mine did not clear but mine is a 1.8l protege not sp20.
oscar bj
PostPosted: Sun Sep 30, 2012 8:47 am
so does this conversion not work on fl sports?
TheMAN
PostPosted: Sun Sep 30, 2012 9:28 am
it's not needed for FL sport
for for 1.5 and 1.8s, upgrading is possible using FL sport rear mounting bracket (UK rear caliper same as FL sport), and front caliper from the FL sport
the discs? MX-5 ones or something else better perhaps
JDM323
PostPosted: Sun Aug 21, 2016 1:19 am
I have increased the front brakes to 300mm using Gh mazda6 calipers, renault scenic 300mm rotors, hubcentric rings (od=60.8mm to id=54.9mm - 7mm thick, 2mm spacer between caliper and stub assy.
Holding the pedal down stops the master cylinder draining while lines are undone.
[url=http://s1285.photobucket.com/user/sarexrandall/media/Brake%20upgrade%20300mm%201_zpsgvja2xuo.jpg.html][img]http://i1285.photobucket.com/albums/a600/sarexrandall/Brake%20upgrade%20300mm%201_zpsgvja2xuo.jpg[/img][/url]
The rings sort out the hub center bore differences.
[url=http://s1285.photobucket.com/user/sarexrandall/media/Brake%20upgrade%20300mm%202_zpsxxgco6lb.jpg.html][img]http://i1285.photobucket.com/albums/a600/sarexrandall/Brake%20upgrade%20300mm%202_zpsxxgco6lb.jpg[/img][/url]
Shown here with rotor on.
[url=http://s1285.photobucket.com/user/sarexrandall/media/Brake%20upgrade%20300mm%203_zpsx0prhnpf.jpg.html][img]http://i1285.photobucket.com/albums/a600/sarexrandall/Brake%20upgrade%20300mm%203_zpsx0prhnpf.jpg[/img][/url]
And finally job complete.
[url=http://s1285.photobucket.com/user/sarexrandall/media/Brake%20upgrade%20300mm%204_zpsglhhxmib.jpg.html][img]http://i1285.photobucket.com/albums/a600/sarexrandall/Brake%20upgrade%20300mm%204_zpsglhhxmib.jpg[/img][/url]
