It is currently Thu Aug 27, 2026 12:07 am
shinar
 Post subject: Why isn't it there?
PostPosted: Mon Dec 20, 2010 5:08 pm
Ok here we can see a typical 323f BA engine bay
And here we can see an older generation
It has one more high votage cable... Where did it go in newer models????
 Post subject: Re: Why isn't it there?
PostPosted: Mon Dec 20, 2010 5:28 pm
If you mean the 5th HT lead, then it would be because the coil pack is a seperate unit, so the extra lead takes the high voltage from the coilpack into the dizzy which then goes out to the 4 plugs. On the BA, the coil pack is built into the dizzy cap :)
eogbaker wrote:
http://blog.sloth.org.uk
shinar
PostPosted: Mon Dec 20, 2010 5:59 pm
Interesting. I taught it could be this way ... but I was never sure. 10x
cosmos1989
PostPosted: Mon Dec 20, 2010 9:36 pm
In modern cars we don't even have Dizzys, Bulgaria are about 10 years behind with cars so you'll know about that in about 2020 ;)
"Meh, it was inside a condom and he used lots of lube, so it's fine" - Matty June 2011
