It is currently Thu Aug 27, 2026 1:08 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
Stuz
PostPosted: Wed Dec 08, 2010 9:21 pm
Our's is L reg, Darren's is N
AlanK
PostPosted: Wed Dec 08, 2010 9:28 pm
mine is N reg and has it... mine is a Gxi Daz's is a ZXI
PostPosted: Wed Dec 08, 2010 9:34 pm
GLX or GXI Al?
PostPosted: Wed Dec 08, 2010 9:52 pm
This is chuffing confusing me :dontknow:
Stuz
PostPosted: Wed Dec 08, 2010 10:47 pm
It does me too. . . . Bloody cars. :lol:
AlanK
PostPosted: Wed Dec 08, 2010 11:42 pm
i cant remember. i'll look tomorrow
Simondo
PostPosted: Thu Dec 09, 2010 2:12 pm
Matt wrote:
Simondo wrote:
Matt wrote:
ice sensor was only on the preford V6 - wiring is there on the Pre ford 1.5 and 1.8
Washer level sensor wiring is on the preford, but no sensor.......
Climate control on the Lantis uses the sensor so you cant have both (without doing some rewiring)
So my Type-R should have this sensor? I never get a warning light... even when it's - 27!
Oops, jusr reread that - didnt write that very well.....
Matt wrote:
ice sensor was only on the preford V6 - wiring is there on the Pre ford 1.5 and 1.8.
Climate control on the Lantis uses the ice sensor so you cant have both climate control and the ice warning light (without doing some rewiring)
yeah you've got the sensor, but as i said (badly) - your car will use it for the climate control so you wont get the ice light on the dash
I see! You know what's a shame? I've got absolutely no idea how to work the CC and I'm pretty sure the air con doesn't work. :(
You're welcome.
PostPosted: Thu Dec 09, 2010 2:17 pm
climate control is simple. Just press auto and then adjust the temperature to the desired temp. the CC will adjust just how much heat or cold air to blow into the car and where from eg. hot air will come from the feet blowers as hot air rises so it will fill the car and opposite with cold...
PS my aircon also doesnt work.. think i got a leak somewhere lol
Simondo
PostPosted: Thu Dec 09, 2010 2:20 pm
I assume it needs the air con to work before it can regulate the temperature?
You're welcome.
PostPosted: Thu Dec 09, 2010 2:21 pm
only if you want it colder than the ambient temperature ;)
air con is just on or off - CC adjusts to regulate the temp, and uses the AC when necessary
PostPosted: Thu Dec 09, 2010 2:29 pm
only if you want the temp in the car to be cooler and even then it will still blow air from the outside in which should cool things down a little. Right now in winter it will work fine heating things up
da2el
PostPosted: Tue Dec 14, 2010 4:04 pm
guess mine doens't have it... bt there isen't enough ice to check it
nulda
PostPosted: Thu Dec 16, 2010 8:20 pm
Hi,
where is connector for connect ice sensor?
nulda
PostPosted: Tue Dec 21, 2010 7:49 pm
Nobody has ice sensor?
PostPosted: Tue Dec 21, 2010 11:08 pm
connector is in front of the radiator, near the drivers side headlight (on uk car) is near the horn
carazide
PostPosted: Wed Dec 22, 2010 11:58 am
So uhm, we have a Volvo S40, that have a temperature sensor.
When the temperature is +3 to -6, it lights up extra, to warn that you might want to take it easy.
Is this thing the same? I mean, is it temperature based, or is there something else in play? :O
