Club323F • View topic - Engine rebuild kit?
It is currently Sun Nov 08, 2026 5:07 am
james323f
 Post subject: Engine rebuild kit?
PostPosted: Sat Nov 20, 2010 9:46 pm
I found on ebay a rebuild kit for the 1.8 bp engine, its comes with:
pistons, rings, main bearings, gaskets, valve seals, oil pump, cambelt kit
its in the states and will be £300 with P&P, is it worth it? The only other thing i'll need is the water pump. the pistons cam come oversized too which is a bonus.
Ive got the engine in my garage, Im yet to start on it, but I want to strip clean rebuild it, then put it into my mx3. without starting work on it yet though I dont know the condition of the internals, so im holding off ordering the kit until I find out the state of the bores.
Stuz
 Post subject: Re: Engine rebuild kit?
PostPosted: Sat Nov 20, 2010 11:01 pm
Try [url=http://www.fordprobestore.co.uk]Ford probe store[/url]
Usually best prices around :)
Roc
PostPosted: Mon Nov 22, 2010 11:51 am
[quote="_stuz_"]Try [url=http://www.fordprobestore.co.uk]Ford probe store[/url]
Usually best prices around :)[/quote]
I do try to be as cheap as possible. Being a small company with low buying power that often means almost cost price, lucky I enjoy doing it!
Some of those parts I probably wouldn't have.
Buying kits like that from the USA often works out cheap, but quality is variable in the extreme. Stick with known names.
ph3n1x
PostPosted: Mon Nov 22, 2010 9:39 pm
Stay away from topline gaskets as far as you can. They are rubbish!
I had wiseco pistons, it is a very known company, toga is a jap tuner wich i had for conrods, bearings and hv oilpump.
Taylor ignition wires are good, but need to take care of them, they damage easily with disconnecting your leads from the pluggs.
