Club323F • View topic - MORE MONEY!!!!
It is currently Thu Nov 12, 2026 4:57 pm
v6mazzy
 Post subject: MORE MONEY!!!!
PostPosted: Fri Sep 09, 2005 10:44 am
Beeeeebies going into car hospital AGAIN!this time me thinks somethings up with the gearbox.....she is a nitemare to get into first and reverse..in fact sometimes the only way to do it is to turn her off and out it in gear..............joy,joy,joy!!!
PostPosted: Fri Sep 09, 2005 10:48 am
It might be worth checking the linkage nylon bushes (underneath the car - the linkages between the gear lever and the gear box ...) I replaced mine a while ago. I got the parts from Mazda and they were quite cheap. Installation took a few minutes. The improvement was considerable !!!
See http://www.club323f.com/club323f/forum/ ... age+bushes for details & illustration.
 Post subject: Re: MORE MONEY!!!!
PostPosted: Fri Sep 09, 2005 9:17 pm
[quote="v6mazzy"]Beeeeebies going into car hospital AGAIN!this time me thinks somethings up with the gearbox.....she is a nitemare to get into first and reverse..in fact sometimes the only way to do it is to turn her off and out it in gear..............joy,joy,joy!!![/quote]
Top tip!!!
Dump the car into neutral, pump the clutch once and then try... Works for me on reverse :cheers:
No need to restart the car
PostPosted: Fri Sep 09, 2005 9:34 pm
Mazzy check where the cluch pedal is housed in the footwell, i had the same prob and the weld on the housing had snapped, so the cluch was'nt engaging right, worth a look first.
v6mazzy
PostPosted: Fri Sep 09, 2005 9:45 pm
duffman...tried the pumping the pedal thing...aint workin :cry:
will have a look before she goes in 2mrw tis
thanks guys....and smots!!xx
v6mazzy
PostPosted: Sun Sep 11, 2005 12:09 pm
shes all better...my bulkhead had a crack in it... :flower:
PostPosted: Mon Sep 12, 2005 11:58 am
Mine had the same problem - I've heard of a few cases ... I fixed mine by making a nice big washer out of 3mm steel ... ;)
PostPosted: Mon Sep 19, 2005 1:17 pm
I often have to do the dump the clutch in neutral technique.
PostPosted: Mon Sep 19, 2005 2:18 pm
[quote="fastmike"]I often have to do the dump the clutch in neutral technique.[/quote]
That's standard good driving techniques - especially if you're hurrying through the gears ... ;)
