Club323F • View topic - ABS/TCS Lights
It is currently Wed Nov 18, 2026 10:12 pm
Domff
 Post subject: ABS/TCS Lights
PostPosted: Thu Feb 04, 2010 6:44 pm
My MOT is up soon and whilst my 1998 323f (newer shape) stops well, the dreaded abs/tcs lights have started appearing and disappearing. Is this an MOT failiure does anyone know? The car has driven perfectly for three years but this is quite worrying. Some times (very rarely) I will go to brake and pedal seems to dip to floor, and then it will be fine again. Any advice would be greatly appreciated.
Dom
PostPosted: Thu Feb 04, 2010 7:10 pm
I moved this to the correct section ;)
alfajerry
PostPosted: Fri Feb 05, 2010 11:31 am
The brake pedal should never get near the floor, I'd have got it looked at immediately.
Could be low fluid, air in fluid, or more serious.
What do you mean with the lights coming and going?
They should only light on startup and when ABS or TCS are operating.
PostPosted: Fri Feb 05, 2010 9:13 pm
ABS and TCS lights are usally caused by a dodgy wheel sensor. A fairly easy fix once you find which sensor!
A pedal t ofloor scenario is a pretty serious issue though, and probably completely unrelated to the lights on the dash.
Could be a faulty servo or worn master cylinder seals. Get it checked ASAP! :wink:
lee morris
PostPosted: Sat Feb 06, 2010 12:51 am
both are MOT failures
Domff
 Post subject: abs/tcs
PostPosted: Sat Feb 13, 2010 5:12 pm
thanks for the reply guys
car has been great until now
the lights for abs / tcs come on and go off on start up, and sometimes wont come on when driving all day, other times it will come on after a few minutes of driving.
The very rare instances when the brake pedal goes soft is accompanied by a electric wurring sound, and can come from no where, and the next time i press the brake it is solid as it should be.
I have stopped using the car.
Could problem have anything to do with handbrake not being tight, and when I took drums off I wasant sure if shoes were worn too low, though there is still pad on shoes(I fitted new pads on front not long ago, despite old pads not being low) not sure how thick they are supposed to be.
No idea where to start if the scenario is worse i.e seals etc, as I do not have a manual, but am quite a competent fitter. any further advice gratefully received
Dom
alfajerry
PostPosted: Sat Feb 13, 2010 6:26 pm
Are you sure this isn't the noise made when the ABS is working?
Domff
 Post subject: abs / tcs
PostPosted: Sat Feb 13, 2010 9:49 pm
I appreciate your interest.
I have heard abs makes a noise, but this is quite bizarre(sounds like an electric motor wurring) as it only started happening recently, hence the reason I changed the front pads,(not sure how to tighten handbrake).
although it rarely happens, it can start as soon as I leave my house, and slow down at the first junction.
Doing my head in as MOT is imminent, and my keyfob has stopped working as well, and both my door locks have ceased it would seem, and I can only unlock car from lock on boot, although it activates central locking perfectly. I do not know if this is a fail also, despite doors being able to be opened from inside.
brilliant car, but not in a position to spend more than it is worth.(its the 1998 onwards model)
Dom
lee morris
PostPosted: Sat Feb 13, 2010 10:06 pm
as long as you can open all four doors from the outside and both front doors from the inside, and the doors close secure, doors pass MOT.
as for the noise from the brakes, check the servo for an air leak, you will hear this when you press the brake pedal with the engine running
Domff
 Post subject: ABS / TCS
PostPosted: Sat Feb 13, 2010 10:34 pm
Cheers for the info.
Would this be an expensive / hard fix?
Really glad for the advice here
Dom
lee morris
PostPosted: Sat Feb 13, 2010 11:20 pm
the servo should be easy enough to change if it is the servo at fault, you say the noise has only recently started, it,s possible the servo diaphragm is at fault, and it,s showing up now because of the very cold weather, the diaphragm being made of rubber goes hard and shows up the fault
alfajerry
PostPosted: Sun Feb 14, 2010 10:40 am
As far as the ABS noise goes, on my 1999 car it sounds different from any other ABS car I've had.
Of course, if it is just the ABS noise, you'll only hear it when you're actually braking and your tyres have lost grip.
Domff
PostPosted: Sun Feb 14, 2010 9:23 pm
Thanks for the help.
I forgot to say that as well as the wurring, there is a twaging noise, a bit like the sound of a heavy spring being stretched
Dom :?
Domff
PostPosted: Mon Feb 22, 2010 8:03 pm
Hi
Still no further with discovering braking problem.
But thinking I am going to have to do the inevitable and put it on the computer.
I knew I was going to have to have this done, but wanted to go to tester with some prior Knowledge.
So was wondering if the machine will pick up faults with the ABS pump?
Cheers Dom
PostPosted: Mon Feb 22, 2010 11:22 pm
A diagnostic machine should pick up any recorded faults in the ABS system yes. :wink:
TheMAN
PostPosted: Tue Feb 23, 2010 5:37 am
only if it can access mazda specific modules, otherwise it will only access engine related systems
rz1k06
PostPosted: Tue Feb 23, 2010 6:06 pm
Hi Domff,
You can get the abs/tcs system checked without having a computer or a service tool. The way is to use a DLC (do not cofuse with dlc-2 socket) socket under the bonnet. In RHD (uk) 323f sport 2.0 it is located just behind right column. Looks like a grey box size of a box of matches. All you have to do is to open the top cover and short one of the pins to car chasis or battery (-) and turn the ignition on. It will start displaying list of abs/tcs errors codes by making the ABS light blink in a certain pattern. Everything is pretty clearly written in the service manual with number of blinks translated into err. codes. I can send you a PDF file if you want. The procedure is very easy and diagnoses all solenoid valves and abs sensors separately. I have tried it and it works.
alfajerry
PostPosted: Tue Feb 23, 2010 6:32 pm
You say the noise/pedal to floor started happening recently; is this since the snowy/icy weather started?
rz1k06
PostPosted: Tue Feb 23, 2010 10:41 pm
Domff, can you try bleeding the calipers to see if there's any air. I had similar problem - the pedal went all the way down to the floor, but I had air getting consistenty to the system - had replaced master cylinder, but still problem was the same, finally I had abs unit replaced and the problem with air is finished. However now rear left wheel locks up when I slam the brakes, and again, i have no abs/tcs lights on the dash, and the ABS ECU's error list is empty... I reckon It must be a mechanical fault on a part which has no sensor attached to it, maybe dual proportioning valve, or a sticky solenoid valve in abs unit, or piston in the caliper gets blocked, or its a tricky electrical problem with ABS ECU...
Wish you good luck. Let us know if you find where the problem is.
Rob
alfajerry
PostPosted: Sat Mar 27, 2010 4:04 pm
Have you sorted this yet?
