It is currently Sat Sep 12, 2026 12:37 pm
jmdrake
PostPosted: Mon Oct 19, 2009 12:24 pm
Hi All - I am new to the Mazda experience and I have a Premacy Sport - I know its not a 323 but I have been told it has the same 2.0L Engine as your BJ model and as I cant find any Info on the Premacy I'm hoping you guys may be able to help???
I have an eratic tickover (Misfire) - I have taken it to Mazda and they are having no luck finding the problem..
There are no fault codes reported and when I took it to the main dealer and they ran a diagnostic test they came back with a faulty CAT and both oxygen sensors - I have changed both sensors and the fault is better but still there. I have been looking at many forums and am looking for any additional info - The timing has been checked by the dealer 3 times and they say its O.K - I found a posting on another forum about the Camshaft position sensor - but not checked it out as yet - Can anyone throw suggestions as to what it could be please...
PostPosted: Mon Oct 19, 2009 1:48 pm
Welcome, the premacy has the same engine as the 323f sport :thumbright:
A misfire is normally down to the coil packs but I suspect the dealer would have checked these as they are a common problem.
I also would think the camshaft sensor would throw up a code :dontknow: One little trick we have found for sorting out some running problems ( the dealerships dont know about it) is to clean the Maf sensor. There should be a few posts floating around about it.
The Mighty BeeJay
jmdrake
PostPosted: Mon Oct 19, 2009 1:55 pm
Many thanks for your reply - i will check out some MAF cleaning posts - There was a suspect Coil Pack as there seemed to be a breakdown on the short lead to the plug but the dealer not tested it as far as I know - Its going back in on wednesday so will ask them to test. I replaced the MAF with a second hand one But it wasnt tested but it didnt make any change to the running so either its faulty as well or they are both working but I will try the clean anyway - Thank for your post - Does the 323f sport also only have 2 coil packs feeding 2 plugs?
PostPosted: Mon Oct 19, 2009 1:59 pm
yes, have a look at www.fordprobestore.co.uk for the packs, much much cheaper that mazda ( if you end up needing them) I would clan the MAF anyway as its cost free and DIY ;) - but if youve changed them and its the same then its probably not this anyway.
Strange they didnt test or suspect the coilpacks as when they break down they can cause cat problems...
The Mighty BeeJay
jmdrake
PostPosted: Mon Oct 19, 2009 2:10 pm
I wish you hadnt said that - The last visit Mazda said i needed a Cat & both o2 sensors - I went to longlife to get the cat changed and they said which one - Mazda told me there was only one initially - Turns out there are 2 - the first on fixed to the downpipe with sensors Pre & Post Cat and a second traditonal Cat further down the system - I have changed the Precat sensor and Longlife said the Cat is probably not damaged as so rattles ? - Mazda is changing the Post Cat os sensor on wednesday - I hope its not the CAT as £589 + vat & fitting - thanks for the website , not heard of them , great to know..
PostPosted: Mon Oct 19, 2009 2:35 pm
If you need the first cat then it might be worth shouting about it in our wanted section, as a few of us have them lying about.
I have one in my attic, as I've fitted an OBX stainless manifold to mine. :wink:
jmdrake
PostPosted: Mon Oct 19, 2009 3:04 pm
Thats great to know - if required will definetely be posting for bits if needed - many thanks for the heads up.. - found the MAF cleaning post will try this later - got to worth a shot
EDWUMASTER
PostPosted: Mon Oct 19, 2009 7:48 pm
Be very carefull not t damage it while you clean it mate!! :thumbright:
http://s42.photobucket.com/albums/e313/edwumaster/
http://www.youtube.com/profile?user=edwumaster
jmdrake
 Post subject: Update
PostPosted: Wed Oct 21, 2009 5:47 pm
Car taken into Mazda this moening for them to do checks to try and find out what is wrong - Phoned than 5pm this evening and they are still working on the car to find the fault - wondering what this is going to cost???
They said they are still working on the car - Will phone them back in the morning some time for an update..
Users browsing this forum: No registered users and 27 guests
