Club323F • View topic - fuel filter on 1.8
It is currently Fri Nov 13, 2026 12:46 pm
bigs
 Post subject: fuel filter on 1.8
PostPosted: Sat Jun 18, 2005 4:13 pm
Think im goin blind!!!!! Can anyone tell me where the fuel filter is on the 1.8 GLX?
Shmulik
PostPosted: Sat Jun 18, 2005 4:16 pm
on the fire wall. near the brake booster.
it's hard to change the fuel filter on BA models.
shmulik
PostPosted: Sat Jun 18, 2005 7:50 pm
Its not had if you have long thin hands and can see round corners lol... took me about an hour to do mine :oops: got there in the end tho. phil did his a week before and he said it wasnt too much of a problem, he took the battery out so he had more room.
Stuart McB
PostPosted: Sat Jun 18, 2005 8:06 pm
How often do they need changing? Mine was done last November 2004.
PostPosted: Sat Jun 18, 2005 10:11 pm
Ahhh but who said it was done ???? apparantly its a trick of the trade they say they do it ... but dont.. Fuel filter can be a pain in a**e to do, best thing to do is to mark it before it goes for service and check it afterwards..
Stuart McB
PostPosted: Sun Jun 19, 2005 2:35 pm
GOGOBROOM. Can confirm it was done. Done by a garage in Derby some where. When I spoke to him (try to speak to last owner of car, last service mechanic befor buying the car) they complained that it took over and hour to remove and re-fitt. Also said that the car was good for it's MOT and only needed a few things doing. This is backed up the service history file that came with the car. :D
bigs
PostPosted: Tue Jun 21, 2005 11:48 am
What are the affects of a blocked fuel filter? Do you lose much power?
bigs
PostPosted: Sat Jul 30, 2005 2:46 pm
[quote="bigs"]What are the affects of a blocked fuel filter? Do you lose much power?[/quote]
Can a blocked fuel filter cause the car to hesitate or "jib" on over run? basically when i take my boot off the trottle the car kangroo's slightly untill the throttle is re applied. I can get round this by touching the trottle very lightly when decelerating......but this is a bit of a pain! Any answers?
essex-lad
PostPosted: Sat Jul 30, 2005 3:01 pm
Yeah a blocked fuel filter can cause that. Causing low fuel delivery. If it was totally blocked then i dont think you'll get very far. Without looking at the service schedule its usually advised to change it every 2 yrs or 24000 miles.
I had a similar problem with my ZXi ..... changed the plugs to Iridiums and that sorted it.
PostPosted: Sat Jul 30, 2005 4:34 pm
[quote="bigs"][quote="bigs"]What are the affects of a blocked fuel filter? Do you lose much power?[/quote]
Can a blocked fuel filter cause the car to hesitate or "jib" on over run? basically when i take my boot off the trottle the car kangroo's slightly untill the throttle is re applied. I can get round this by touching the trottle very lightly when decelerating......but this is a bit of a pain! Any answers?[/quote]
Most probably a coked up butterfly valve. Remove the throttle body and give the butterfly valve a scrub with a tooth brush until it's all nice and clean. This will improve your throttle response.
Probably needs doing every 15-20K miles anyway ideally.
foye
PostPosted: Mon Aug 01, 2005 5:40 pm
how much do the fuel filter cost?
