Club323F • View topic - Air con not working
It is currently Wed Nov 11, 2026 9:55 am
andymazdaman
 Post subject: Air con not working
PostPosted: Tue May 17, 2005 11:33 am
I have reciently bought a 1998,1.8 323 exec, I came to use the air con over the weekend the button aluminates but the pump does not kick in.
I have checked fuses conections etc all seem to be OK but I can not even hear a relay activating.
Is it worth bothering with as it is so seldom needed???
Any ideas please
Andy
PostPosted: Tue May 17, 2005 11:48 am
It might need re-gassing. Some aircons have a pressure switch to prevent it from operating if the pressure drops too far ...
andymazdaman
PostPosted: Tue May 17, 2005 12:44 pm
Thanks Smotter for your quick responce, I will have that checked first.
Andy
PostPosted: Tue May 17, 2005 12:52 pm
Has it got AC?
They all have the switch that illuminates, but some have no AC. One way to check is to look for two fans behind the radiator - if there's only one, you don't have AC. I don't.
PostPosted: Tue May 17, 2005 2:10 pm
[quote="Mark.T"]They all have the switch that illuminates, but some have no AC. One way to check is to look for two fans behind the radiator - if there's only one, you don't have AC. I don't.[/quote]
They'll probably pick that up when he goes for a re-gass ...
PostPosted: Tue May 17, 2005 2:39 pm
lmao @ smotter ... but you do look rather silly when you go get it regassed and they say errmmm but you dont have aircon :| ... I know from experience :oops:
Best bet is to look on inside of driver door sill and see if the label says A/C yes or no ... if no then you aint got it :P
fil_auto
PostPosted: Tue May 17, 2005 2:45 pm
Surely the extra pipes around the head (left side) should clear this one up.... or not?! 8)
andymazdaman
PostPosted: Wed May 18, 2005 2:30 pm
Yes I did make sure air con was fitted, as my previous 626 mazda was sold to me as having it fitted but in fact did not.
Andy
Stuart McB
PostPosted: Wed May 18, 2005 8:17 pm
Had this on mine when purchased. It turned out to be a loose connection around the pump it self. Where the wirirng goes in to the pump. Now woork relly cooooool 8)
mmpob
PostPosted: Wed May 18, 2005 11:46 pm
dammit - that did confuse me, why I had an A/C button, but it said A/C N on the door panel
dammit!!!!
