Club323F • View topic - Mobile 1 oil
It is currently Wed Nov 11, 2026 9:27 am
Lantis
 Post subject: Mobile 1 oil
PostPosted: Thu May 12, 2005 2:05 am
Hey guys have any of you's using mobile 1 0-40W??? i need to know if its alrite to use this.
iv got the 1.8 engine
Toyboy
PostPosted: Thu May 12, 2005 5:12 am
Im using the mobil 1 5-50w in my 1.8DOHC engine with no probs,its just a little tappier in the top end untill the oil warms up though :wink:
I didnt know mobil made a 0-40w oil,personally i wouldnt use it,if anything ill be looking for a 15-50w soon i think :P
PostPosted: Thu May 12, 2005 8:35 am
I used to use Castrol RS 0-40, but have gone back to 10-40 Magnetec to keep the engine a little quieter (less tappety). I've got oil seal issues as well, so I use a slightly thicker oil so that less drips down into the combustion chamber whilst not running :oops:
Toyboy
PostPosted: Thu May 12, 2005 11:15 am
[quote]I've got oil seal issues as well, so I use a slightly thicker oil so that less drips down into the combustion chamber whilst not running [/quote]
I feel ya pain mate,atm ive got a suspected rear main oil seal leak which is gunna be quite costly to fix cause the gearbox,clutch & flywheel have to be removed to get to it :cry:
PostPosted: Thu May 12, 2005 11:41 am
[quote="Toyboy"] I feel ya pain mate,atm ive got a suspected rear main oil seal leak which is gunna be quite costly to fix cause the gearbox,clutch & flywheel have to be removed to get to it :cry:[/quote]
You may as well fit a new clutch set (pressure plate, friction plate & thrust bearing) while you've got it all apart - save you the trouble of stripping it all down again later ...
:wink:
Toyboy
PostPosted: Thu May 12, 2005 12:57 pm
Funny you say that,i only had the clutch replaced about 6months ago,why couldnt the seal of been leaking then :evil:
Ill have to get it repaired within the next few months though cause i dont want it getting worse and comtaminating my fairly new clutch :(
PostPosted: Thu May 12, 2005 1:02 pm
I'm trying to put off doing mine until I have the cash for some decent headwork while it's off.
PostPosted: Thu May 12, 2005 1:08 pm
[quote="Toyboy"]Funny you say that,i only had the clutch replaced about 6months ago,why couldnt the seal of been leaking then :evil:
Ill have to get it repaired within the next few months though cause i dont want it getting worse and comtaminating my fairly new clutch :([/quote]
Last time I had the clutch done on my Passat, the garage (A Shell Autoserve Service centre) did the rear oil seal automatically. When I queeried, they told me they always replaced the rear seal when they did the clutch. Rather a good policy, I'd say ...
Lantis
PostPosted: Fri May 13, 2005 2:02 am
hmmm so the car is capable of the mobil 1 oil 0-40 hmm cos i was finking about using this wen i come to see u guys in JAE
PostPosted: Fri May 13, 2005 8:11 am
Like I say, I used 0-40 in mine with no noticable problems.
PostPosted: Fri May 13, 2005 8:48 am
I'm using 5w-30 Magnatec, very tasty ;)
PostPosted: Fri May 13, 2005 9:21 am
Have a look at the info on
http://homepage.ntlworld.com/dorothy.br ... /index.htm
It's mainly aimed at V6 motors, but the principles are the same.
Wai.Cheung
PostPosted: Fri May 13, 2005 1:16 pm
I had Castrol RS 0-40W but I was worried about rattling in the tappets so I've changed to Mobil 1 15-50W.
The engine sounds a lot smoother now but I may well change it to 10-40W the next time around (just for fun!) :wink:
Lantis
PostPosted: Sat May 14, 2005 1:51 am
thanks guys the info is useful just need to test it all out now ;)
