Club323F • View topic - Air Con Fault?
It is currently Tue Nov 10, 2026 12:46 pm
steve holt
 Post subject: Air Con Fault?
PostPosted: Tue Dec 21, 2004 7:01 pm
Anyone know what the sound of bubbling coming from my air con unit is. I guess it needs regassing as it has not been running cold since the summer. If it is, anyone know what price should i pay to have it regassed. Steve Holt 97 ZXI. :(
PostPosted: Tue Dec 21, 2004 8:04 pm
Dunno about the fault but regassing is usually about £80 tho you can find places as low as £50 I think
wai.cheung01
PostPosted: Tue Dec 21, 2004 9:27 pm
tricky situation: air-con.
I had a slight hissing noise and the 'coldness' kept running out too quickly. "it's a leak" I hear you say. Correct, but it cost me £130 to find out WHERE the leak was and now it looks like I'll have to pay for a new condensor so I'm now going for the option of No Air-con and reduced front-end weight!!
....just gonna have to swelter for those 2 days spread over a British summer!! :P
PostPosted: Wed Dec 22, 2004 12:05 am
About 7 months ago mine was leaking from an o-ring, repaired it and had it re-gased, worked fine for about 4 weeks then stopped, i think the compressor might have gone because when i used to turn the aircon on you could hear it kick in, but now it don't, i'v checked all the fuses and they're ok, and it looks a pig of a job to get the compressor out :(
PostPosted: Wed Dec 22, 2004 1:22 am
When I switch my aircon on there's no change in engine note or revs, and no evidence of anything kicking into life or whatever. And of course no cold air. I guess that is not good.....
The car is a '98 ZXi with all the relevant hardware.
PostPosted: Wed Dec 22, 2004 8:28 am
Last time I had my aircon regassed, the chappie in charge was telling me that they include a certain amount of some kind of lubricant in the gas to protect the compressor. So - if you have a leak and continue to run the aircon without lubricant .... draw your own conclusions !
PostPosted: Wed Dec 22, 2004 10:34 am
:shock: I had heard about that lubricant before, this could be worth checking out, cheers :wink:
nickj633
PostPosted: Thu Dec 23, 2004 6:31 pm
I think the system has a safety cut out, that will prevent the compressor from working unless there is a certain level of pressure in the system. This is supposed to prevent 'run dry' and protect the compressor.
Had mine re-gassed about 6 months ago, but its stopped working again. Think there is a leak. If the safety cut out kicks in, then whether the light on the button comes on or not, you will not hear the sys 'klick'
Nick
PostPosted: Fri Dec 24, 2004 10:33 am
Cheers Nick, i did'nt know about that, worth getting it re-gased first, i manage to get mine done free as where i work we have air-conditioning plant and some of them run on R134A (used to be R12).
PostPosted: Fri Dec 24, 2004 10:37 am
