It is currently Thu Aug 27, 2026 4:30 am
JDM
PostPosted: Wed Apr 12, 2006 4:18 pm
rite people i intend to get my clutch sorted by JAE and few other mods...
After doing a few searches and research its suggested that while i get my clutch sorted out i should:
- Change thrust bearing
- Change gearbox oil
- Replace Friction plate with new one
- Replace crankshaft oil seal
- skim flywheel
is there anything else they can do while the car is there?
my famous soldier of a clutch is still slipping but its getting worse, some people say it just needs adjusting and others say just get a new one :?
bare in mind im going down the performance route soon with port n polishing etc... so is it advisable to get a heavy duty clutch or will stock be fine?
Now moving on to the flywheel..
I can get the flywheel skimmed while getting the clutch sorted but im not sure what happens to the flyweel?? and also if im going down the perfomance route and want a quicker accelerating car surely i need a proper light flywheel? as appose to just skimming it?
ive searched the web for a light flywheel for the 1.5 but didnt find anything at all and i suspect having a custom made one wud be way too expensive :?
last question... say i did get a really light flywheel and put it on my stock engine (with decat) wud i see a deff improvement on acceleration?
thank you
murray :cat:
PostPosted: Wed Apr 12, 2006 4:35 pm
I'm not 100% positive, but a ligtened flywheel is better for a very tuned engine the needs to make peak power, but you sacrifice torque for it, which, on a 1.5 iswhat you need lots more of!! :D:D
If you've got GT4 or 1, 2, or 3 for that matter, you can easily test this, just by a car, leave it stock, go put some times down, head back to the garage, whack on a ligtend fywheel, do some more runs, calculate the difference, try to use a car camparible in power too :D:D:D
JDM
PostPosted: Wed Apr 12, 2006 4:37 pm
:( i dont have that dude hehe
PostPosted: Wed Apr 12, 2006 5:36 pm
DOH, perhaps someone could do it for ya :D:D:D
PostPosted: Wed Apr 12, 2006 8:38 pm
I think for the effort, it's not worth the bother. It'll hinder your idle - depending on how far up the performance route you go.
onlinedevil
PostPosted: Wed Apr 12, 2006 8:50 pm
My clutch isn't very 'sharpe' does this mean I have to change it?
zx6r
PostPosted: Wed Apr 12, 2006 8:56 pm
I think to replace std. clutch with HD one and lightened flywheel your engine would have to be at its max internally performance wise Ezeegee - save the money for the other work you intend to do
MRK189
PostPosted: Thu Apr 13, 2006 12:21 am
Im doing the flywheel myself soon. There is only gain in it. What u will have to avoid though after doing it is slow gear shifting because since its lighter it will lose its momentum more quickly but the car will accelarate faster with a lighter flywheel.
PostPosted: Thu Apr 13, 2006 8:12 am
Just don't take too much off or you could risk having it break up ... which would be messy! :D
JDM
PostPosted: Thu Apr 13, 2006 11:13 am
whats the process of skimming then mateys????
PostPosted: Thu Apr 13, 2006 2:35 pm
You'd need to find someone with a milling machine/lathe i'd guess chap, small engineering firms are your best bet i'd wager ;)
Used to be loads round here, but BMW and Ford have sent most of 'em down :(
MRK189
PostPosted: Thu Apr 13, 2006 3:36 pm
well i looked around abit and came up with this. Im hoping that it fits our z5. It says mazda protege 1.5litre 95 - 98 which seems about right.
http://www.club323f.com/club323f/forum/ ... php?t=8534
PostPosted: Thu Apr 13, 2006 11:04 pm
By the looks of that, the 1.5/1.8 use the same clutches :D:D
