It is currently Thu Aug 27, 2026 5:12 am
deep2005
PostPosted: Mon Dec 27, 2010 4:34 pm
Hi guys as some of you may know ive bought a 1.8 s reg F. however after a week or so of owning it the driveshaft popped out ruining the gearbox, as the bit the shaft goes into got mangled!!
Now ive looked high and low and cant find a box, for a reasonable price!just before i got this one i got a box for maisey with 50k on it for £100!
Will the 1.5 box go on?looks similar, not sure if itll fit though, although i have tried a 1.5 shaft on the 1.8 and it fitted :S.
Also the 1.8 use to be automatic so not sure what manual box is in it now the number on the box at the mo is....F5C7 if that helps?
i really need help urgently as i need it back on the road! anyone seen a F in a scrappy.....around or near northamptonshire, willing to travel if the price is right too.
The subject ive writeen isnt meant to offend anyone i just know some members like andym etc will have knowledge of all this.....
cheers guys
deep2005
PostPosted: Mon Dec 27, 2010 4:35 pm
also my mates garage has a 1.8 626 on a m reg, will that box work?even if it needs adapting...
deep2005
PostPosted: Mon Dec 27, 2010 10:55 pm
anyone?
Shayne
PostPosted: Mon Dec 27, 2010 11:21 pm
I am not sure mate, but check the motor out and see if it is the same as yours, DOHC, if so it should fit,
New beginnings.
lewp91
PostPosted: Mon Dec 27, 2010 11:24 pm
i found a box for £100 with 3 months G from a mazda specialists cant remember the name but it included postage on a pallet next day! :)
deep2005
PostPosted: Tue Dec 28, 2010 3:49 pm
could you try dig up any details at all mate?
Had a look at my 1.5 box and has the same part number as my 1.8,
does andym still come on herE?
lewp91
PostPosted: Tue Dec 28, 2010 4:12 pm
Lost it all mate sorry :/ mine was out a demio
deep2005
PostPosted: Wed Dec 29, 2010 6:51 pm
ok no worries,
Can someone with a 1.8 BA see what the part number on their gearbox is?? and also does anyone know if the driveshafts for the F series boxes are the same? cant work out what gearbox my car has :S
deep2005
PostPosted: Thu Dec 30, 2010 7:29 pm
anyone help? :( wish i never bought another F now should off moved on lol
lewp91
PostPosted: Fri Dec 31, 2010 3:33 am
have you got a g of f gbox?
theyre in alot of other cars
best bet phoning breakers
i did a gbox and 2 clutches on my BG one was because of the oil leak though tbh:P
RHRH
PostPosted: Fri Dec 31, 2010 11:23 am
Only 1.8's prior to 1995 have the Gseries box... Where it said F5... it should read G5M...
The rest of the 1.8's are using the same gearbox as the 1.5's the F series box, which you
mentioned you already have as you stated the F5 bit...
So just get a box out of any 1.8 or 1.5 FBA and your good! Maybee do the clutch while your
at it... :)
deep2005
PostPosted: Fri Dec 31, 2010 6:16 pm
thank you ever so much mate! weight off my mind, so are the clutches all different??
ph3n1x
PostPosted: Tue Jan 04, 2011 5:03 pm
yup, the 1.8 uses a 200mm clutch where the 1.5 uses a 190mm clutch.
