Club323F • View topic - Get your rattling windows to work again...
It is currently Thu Oct 29, 2026 7:02 pm
cba6p
PostPosted: Mon Nov 18, 2013 4:43 am
Someone could have done the front door before but I will be covering the rear door and will try to make it more comprehensive.
All the problems are caused by the 5 pieces of rubber parts that turned into pieces.
1. Remove door card.
2. Remove plastic sheet, partly, as shown below.
3. Remove the 2 circled screws as shown. Size = 10mm. Hold the stopper bracket at the back while unscrewing. Keep both brackets. You need to do something about them later.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_141928_zpsec4d836a.jpg[/img]
4. Plug the window switch back and move the window glass up or down so that you can see the below 2 nuts + 1 screw. Remove them with a 10mm socket wrench.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_142029_zps956f534c.jpg[/img]
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_142039_zpsaefebd66.jpg[/img]
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_142050_zps5be86982.jpg[/img]
5. Now, slide the glass upward. Be careful not to scratch your tint film (if any).
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_144204_zpsb96d27b3.jpg[/img]
6. Next 2 photos show the sliding rubber and roller turned themselves into sh!t-look-alike stuff.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_144211_zpsee65f3dd.jpg[/img]
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_144233_zps0fa560af.jpg[/img]
7. Wrap the stopper brackets with rubber taken from an F-clamp and secure each of them with a cable tie.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_144309_zps955f95bf.jpg[/img]
8. Now, remove 5x nuts (14 and 10mm) shown below.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_1419282_zpsf17d4730.jpg[/img]
9. Disconnect power window motor and remove the whole power window assembly out of the door.
[img]http://i85.photobucket.com/albums/k73/cba6p/20131110_154746_zpsfed0e255.jpg[/img]
10. Roller disappeared!!!
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_154907_zpsad987c77.jpg[/img]
11. Grind off the head of the roller pin with a disc grinder and knock it out with a punch.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_172254_zpsf91e30a0.jpg[/img]
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_172247_zps14fcbae1.jpg[/img]
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131110_174927_zps5828c70d.jpg[/img]
12. Drill Ø3.3 and tap an M4 x 10 deep hole at the centre of the pin. Get ready a button head M4 x 8 screw, a thin M4 washer and a new (reverse engineered) roller.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131111_191718_zps38570e6f.jpg[/img]
13. Insert the pin into the roller and slot the assembly into the guide rail. Apply some Loctite 242 on the threaded hole.
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131116_183600_zps16d73657.jpg[/img]
14. Fasten the screw and it is how it looks like:
[img]http://i85.photobucket.com/albums/k73/cba6p/lantis/20131116_183822_zps83592d61.jpg[/img]
We are done with the power window assembly. Ready to put it back into the door.
TBC...
HMT
PostPosted: Mon Jun 25, 2018 12:46 pm
Hi,
does anybody know how / where to get new replacement bushes?
Cheers,
Chris
CSR
PostPosted: Mon Jun 25, 2018 9:55 pm
amazing tutorial dude... I have two windows ratlling, and with this, you help a lot know how to solve it... only left to know how get the buches (don't say Mazda cuse not worth the money they ask ;) :blackeye: )
CSR
CSR
PostPosted: Wed Dec 26, 2018 9:00 pm
buches? XD
Isaac Burlo
PostPosted: Sun Dec 30, 2018 3:31 am
great work thank you :)
jakobie
PostPosted: Wed Mar 13, 2019 6:43 am
Nice write up. I will try your method since my windows are rattling a bit.
CSR
PostPosted: Tue Apr 06, 2021 9:05 pm
I still looking for those buches... only can fins for mx-5, witch seems to be the same issue. But only can find in US, and the price of postage is more than the set of 2 buches...
can someone know how to find a set in Europe?
HMT
PostPosted: Fri Apr 09, 2021 11:58 am
I can halp u with that. I am currently importing a few sets. I'd need a down payment via Paypal until the weekend to include you. It should work out at about 80€ plus shipping from germany to portugal.
Feel free to DM me on insta if possible @lantisdoc
da2el
PostPosted: Fri Aug 08, 2025 10:35 am
This is one of the most annoying and difficult things to fix in this car
