Unfortunately this is a 'fail' post, however I still hope youse (great Aussie word, that) can still get something out of it.
I have found the hardware, software and (most importantly) instructions to connect to readout from a BA ECU through the 17-pin diagnostics port. However, I have also found (less entertaining) information that explains why I can't use it on *my* car.
It seems you can now connect to certain OBD-I (yes that's dash-one) cars and the BA Lantis may be one of them. What you need is [list]
[*] An android, iOS or PC (windows) device[/*:m]
[*] An OBD-II (yes that's dash-two) ELM327 compatible device ('dongle') that will talk to the android/iOS/PC device[/*:m]
[*] 3 Small connector wires suitable to connect the dongle pins to the appropriate sockets in the diagnostics port. These could be finicky as one end needs t be a small socket and the other a small probe/pin.[/*:m]
[*]"FORScan" program (free version available for testing)[/*:m][/list:u]
By the way, the 'FORScan' program looks more capable than Torque Pro. Connected to my Mazda 3 a cursory look identified more than just the general parameters- it seems to be able to get into some of the other systems as well.
There are already instructions and diagrams on the net so I'll link to them below. However the main issue I encountered was this (quote from snapontools Australia):
[quote]Mazda started introducing live data on Australian vehicle engines and
automatic transmissions in late 1995, starting with 4 cylinder 323/Astina
models. [/quote]
And unfortunately mine's a 6/94! Grrrr!
I assume late-95 is when the Ford-owned swapover / BA-mkII happened.
Anyway, here's some links to help those of you who may be able to get it to read out. If anyone wants photos of my setup let me know and I'll see what I can do.
[list]
[*][url=http://www.snapontools.com.au/__data/assets/pdf_file/0006/19257/AUS_Eunos,_Mazda,_Mitsubishi,_Nissan_Vehicle_Communication_Software_Manuals.pdf]Snap-On Tools scanner manual[/url] with some useful info, in particular around page 15 & following for Mazda.[/*:m]
[*][url=https://play.google.com/store/apps/details?id=com.astech.forscandemo&hl=en&referrer=utm_source%3Dgoogle%26utm_medium%3Dorganic%26utm_term%3Dforscan+demo&pcampaignid=APPU_1__qdiV4e7JoHyvgS_xIvIBQ]FORScan Demo for Android[/url][/*:m]
[*][url=http://forscan.org/forum/viewtopic.php?f=4&t=5]How to connect to pre-CAN Mazda inc. pin-out diagrams.[/url] Note the OBDII pin out is for the socket and NEEDS TO BE REVERSED (i.e. reflected in a mirror, right-to-left instead of left-to-right) for the dongle[/*:m]
[*][url=http://forscan.org/documentation_Android.html]FORScan docs for Android version[/url][/*:m]
[*][url=http://forscan.org/forum/viewtopic.php?f=5&t=1407]Mazda 323 BA 1.5 16V 1996[/url]. includes pics of the connections in-situ.[/*:m]
[*][url=http://forscan.org/forum/viewtopic.php?t=5&p=5]How to connect FORScan to pre-CAN Mazda[/url] And again, pics of the connections in-situ.[/*:m]
[*][url=http://mechanics.stackexchange.com/questions/13021/mazda-lantis-323-1997-obdi-or-obdii]Connection to 1997 BA[/url]. Lists success in a comment underneath.[/*:m][/list:u]
Hope this helps,
[b]Patrick[/b]
