It is currently Wed Oct 07, 2026 10:50 am
Post new topic Reply to topic  [ 310 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11  Next
PostPosted: Sun Apr 05, 2015 8:57 am
Legs doing fine chap thanks, bit stiff but I'm mobile again :)
I might have a bit of a problem with the engine swap as it goes, I was checking the emmisions control stuff on the EPC this morning, just had a niggling doubt and it transpires the intake I got from Matt is completely different from the intake on M1tch's car, basically, a pre/post Ford problem :(
Looks like there are two extra three way valves on the pre Ford, and all the EGR pipes on my intake manifold have been cut :(
PostPosted: Sun Apr 05, 2015 9:01 am
Just block off all the EGR stuff :)
PostPosted: Sun Apr 05, 2015 9:39 am
Yeah block it all off Andy :) we blocked off the egr pipes on Vulcan when we fitted the stainless headers and she runs fine no problems what so ever
PostPosted: Sun Apr 05, 2015 10:49 am
Thanks guys, it had crossed my mind but its always good to havea second and third opinion :)
The engine might actually be better without anyways as its a pre '91 engine :)
Just about to take the first load of bits over to Mum and Dads ready for next weekend, exhaust stuff mostly but I'm going to take the emmissions loom over as well so I can check to see if the dizzy connector is right, if not I'll have to find a pre Ford dizzy PDQ!
I also need to check whether M1tch registered the BG engine when he fitted it, I've never thought to check until Nathan mentioned the run around they had getting the DVLA to give them docs because they didn't know what car their GTR cam from!!!! :shock:
PostPosted: Sun Apr 05, 2015 8:32 pm
Evening upodate:-
The dizzy, coolant temp sensor and the lambda are all different on the crossover/post 1.8, luckily, the dizzy, coolant temp sensor, heat sensor and oil pressure sensor can all be used from Meanie :D
I might be able to use the lambda sensor from Meanie as it might be a universal fit one, its got 4 wires and I've only wired up three to match the block connector, so it stands to reason ;)
As Lerch and Hughie have suggested, I shall more than likely delete the EGR system, its a pre 1991 engine so doesn't need a cat for an MOT emmisions test. My only concern is without the missing three way valves.......
........oh , lucky, lucky, LUCKY me :D
On checking the EPC, it turns out the 1.5 has the same 3 way valves :D WooHOO :D I'll just need a bracket making to mount them to the inlet manifold :D
marshymob
PostPosted: Sun Apr 05, 2015 8:39 pm
My Car: Julie - 1994 BA
does fitting an older engine then mean you dont need a cat?
if so i'm doing this sooner :)
PostPosted: Sun Apr 05, 2015 8:51 pm
I don't think it does actually! I think its the age of the VIN, but I could be wrong!!
PostPosted: Thu Apr 09, 2015 4:20 pm
I spoke to Nathan about this the other day, he said it's the age of the engine not the chassis, so I won't need a CAT in theory even though I'm fitting one anyway :-)
PostPosted: Thu Apr 09, 2015 4:26 pm
Just looked it up, we're both wrong but you're more right :lol:
It's whichever is oldest :) So if you put a BA engine into a pre-cat BG, it would need a cat :thumbleft: but you're putting a pre-cat engine into a BA, so you don't need one :)
PostPosted: Thu Apr 09, 2015 4:28 pm
Quick update as well....
The intake manifold has been stripped cleaned and painted, just a coat of clear lacquer now before I start reassembling tomorrow night, pics to follow.
Sundries have been order, difficult seals, injector seal, new fuel filter etc.
Last night Nathan and I started disconnecting the engine in the donor car, the only things we'll be using are the engine, exhaust and some of the vacuum piping, all that's left to do is remove the drive shafts and exhaust from the CAT unbolt the mounts and lift it out :-D
G series shafts are ready to be greased and reassembled and tonight I'll have a go at cleaning the box up a bit and maybe Hammerite the mounts.
I also need to clean the loom.
We'll be starting to strip Meanie tomorrow night ready to get properly stuck in Saturday morning :-D
Oh, and we hand cranked the engine as well, turned sweet and smooth :D
PostPosted: Thu Apr 09, 2015 7:37 pm
Fingers crossed that everything goes smoot and good!
Waiting the pics without paitience :lol:
PostPosted: Thu Apr 09, 2015 10:14 pm
Good luck madgers, hope it all goes well!
PostPosted: Fri Apr 10, 2015 9:04 am
Me too, all packed and ready, just gotta get wifey to pick up the diff seals and some GB oil, load the car when I get home and its game on :D
Nick Cara
PostPosted: Fri Apr 10, 2015 9:32 am
Hi there your car was along with smurf's got me into this 323f stuff, you have done a MEGA job with the transformation love it :thumbright: Nick Cara :salute:
PostPosted: Fri Apr 10, 2015 10:17 pm
Thank you Nick, that's most kind of you :-D
OK, so, finished work at half four, Meanie packed and ready to go by six! My cave looks no emptier :-P
At 7.30pm and with 286,575 miles on the clock, Meanie was switched off for the last time (for now) as a 1.5 and work commenced, Nathan and I spent 2 hours on her tonight, Plus Gassed everything, drained engine and gearbox oil, loosened drive shaft mount, intake and airbox off, diff off, wheels off, emission loom disconnected engine side, power steering pump off plus some other stuff I can't remember right now :-P
We reconvene at 7 tomorrow morning, hope the weather holds :O
PostPosted: Fri Apr 10, 2015 10:43 pm
Good luck with the swap Andy, take a million pics, ill be taking close note :D
on a side note, a mate of mine makes table lamps......from crankshafts, so if you would like a bit of meanie to live on in the cave just let me know and ill get in touch with him
PostPosted: Sat Apr 11, 2015 9:15 am
A sad moment indeed :sad:
sneakz
PostPosted: Sat Apr 11, 2015 10:28 am
Good luck mate!
I hope everything goes smoothly.
Arne
PostPosted: Mon Apr 13, 2015 12:45 pm
:sleepy2:
The 323F GTR 1.8 Turbo
PostPosted: Tue Apr 14, 2015 12:41 am
Yup, can't argue that, we did a 3_2_1 countdown and a last rev and switched off, many many miles of fun on that engine, as I said though, for now ;-) the supercharged 1.5 may yet live :-D
Nathan said I should have counted 3_2_3,that would have been cool, and, we didn't film it, that was a mistake :-/
However, the GT looks great in her, fills the bay nicely, there are pics but mobile faffiness stalls me till I get on the PC :-P
I must take a moment to thank profusely, Lee and Nathan for their support and drive in getting Meanie back on the road ASAP, as usual they have both gone above and beyond in their efforts :thumbright:
So far, the engine is in complete with refurbished manifold, engine bay wiring done extremely neatly, interior wiring done but needs tidying up before refitting the centre console, intake needs work, the Stephen's intake is a bit brash for me, I'm desperately looking for a standard pre Ford intake pipe and airbox if anyone has any ideas :-D
The exhaust is an issue, we've got most of it hooked up, including my existing back box, thanks to some deft filing :-D unfortunately the spring bolts are too short from the down pipe to the cat, trip to the exhaust people is needed!
We had to retro fit the alternator which required some pully nodding, and a new V belt, making a complete set of Gates belts all round.
The main issue is the drive train, we were going to run G series box and shafts BUT I don't have the right flywheel, so we're having to run F series, however, we intended to fit the parts from the 1.8 BA but sheared one of the slave cylinder bolts, so we switched to Meanie ''s existing box only to find 1.5 drivers side shafts don't fit a 1.8 :O
So we decided to fit the F series shaft from the donor, only it's welded to the hub (bad memories for all three of us with guys problem), solution fit all of it to Meanie as a temporary fix!
Despite the heroic effort to get her moving for Sunday evening though, we had to admit defeat, we lost half a day Saturday to rain and it was the same from about 6 on Sunday :-( If we hadn't had to faff with the gearbox options so much we'd have made it, but, we stuck at it till 10 last night before suspending play ;-)
We were very cold and very tired but we got a lot done :-D
Thanks must also be given to my compatriots for the lift home, all the way to Dudley :notworthy:
I will properly document the event with pics when I get the chance but for the moment, we desperately need an F series drivers side driveshaft assembly, if we could obtain a G series flywheel, the G series transmission is back on plus a standard 1.8 airbox and intake pipe would be nice :-D
Meanie will ride again...... Very soon :-D
PostPosted: Tue Apr 14, 2015 12:07 pm
pesky rust monkeys make everything harder :(
Glad to hear you made excellent progress Andy :)
PostPosted: Tue Apr 14, 2015 2:16 pm
Cheers mate :thumbright:
Forgot to mention the PS pump, the fricking adjuster is rusted solid, so until thats freed off, we can't get the belt on, what I shall try and do this evening is remove the adjuster, clean the rust off, paint it, then grease it liberally when I stick it back on :)
Tonights other job, finish tidying up the interior wiring :)
PostPosted: Wed Apr 15, 2015 12:59 pm
Update from last night....
Did a couple of hours last night on me tod, turns out the exhaust bolts will fit, the problem is the flanges on the CAT and the centre pipe are slightly misaligned, if we take the CAT out and refit it downpipe end first it should all bolt up nicely, its a two man job though so it'll have to wait till tomorrow night ;)
Made a start on the PS pump adjuster as well, managed to get the adjuster lock nut freed up with deft use of Plus Gas, a 14mm ring spanner, a lump hammer and much wriggling about ;) However, the pivot nuts for the adjuster plate and the pump pivot are another matter, the plate nut is just about accessible from underneath the car in the same fashion as the lock nut, but, with less room to swing the hammer I realised I was in danger of rounding the nut and so prudently backed off. The pump pivot nut was I am sure, designed as a joke!!!!!! :/ its accessible through a slot in the pulley, but with only about 30-40mm clearance between the frame rail and the pulley, there is no WAY of getting a socket in there, even my Vortex drive sockets will fit, looks like we'll have to whip the pump off again and one of us will have to hold it while the other tries to undo the nuts, NUTS!!!!!!! :p
I'm off outside to spray them with Plus Gas..... again ;)
PostPosted: Wed Apr 15, 2015 10:19 pm
I've just had one of those moments where you think 'why the he'll didn't I think of that' :banghead:
Just watched this clip https://youtu.be/GJLgmOqFoPk whilst doing a bit of research on 'difficult' CV joints :-P
We have a good hub, we have a brand new CV joint, we have the right drive shaft with a rusty old CV that won't budge probably because it's been sat on my drive for 7 years, can it really be that simple?
Simply knock the hole hub off the end of the shaft, fit the new CV, bang the good hub back on and Bob's your Uncle :-D
Let's just hope the internal spline counts the same eh :-P
P.S. We'd have thought of this on Sunday, but being cold, wet and tired probably didn't do us any favours :p
CSR
PostPosted: Sat Jul 25, 2015 2:20 pm
dude can you tell me what is that hole in black in the front bumper? i'ts not the firstone i see with that... =X
J_Akhter
PostPosted: Sat Jul 25, 2015 5:38 pm
Its for a cold air feed
Nick Cara
PostPosted: Sun Jul 26, 2015 12:08 am
Hi Andy just reading your thread then i came to thinking have still got any stuff from your 1.5 engine like induction kit, exhaust rather than me buying from fpstore and waiting ages for it to arrive,just a thought as i know i said i want to swap to a 1,8 but that's a long way ahead and i just need a bit more grunt through the gears so if you have anything lying around that i can use on my Faithful i would be very happy to buy it from you. cheers Andy and may all my f--- ing dreams come true :lol:
CSR
PostPosted: Sun Jul 26, 2015 12:33 pm
oh thanks ;D
I thought it was it but i ask to be sure ;)
CSR
Nick Cara
PostPosted: Thu Aug 06, 2015 11:14 am
Hi Andy you can have parts of this if it suits you mate
i am in Black[pool mate all the best mate :salute: Nick
Nick Cara
PostPosted: Thu Aug 06, 2015 11:57 am
If it helps you out mate get my mobile of Lerch ok
