Club323F • View topic - v6 Splitter
It is currently Sun Nov 15, 2026 9:12 pm
 Post subject: v6 Splitter
PostPosted: Sun Dec 08, 2013 11:51 am
just getting sorted to fit the v6 splitter on womble, now, with it being a 1.5 there are no holes for the splitter tabs to fit into so i have removed these, my question is....
do i fix it all together and fit?, or is it best done section at a time?
if section at a time then i would guess its a case of centre section first, and then the sides, then finish off with fixing bolts to connect into one whole piece
 Post subject: Re: v6 Splitter
PostPosted: Mon Dec 09, 2013 9:54 am
I'd attach the 3 sections together, then use some stainless steel self-tapping screws to fit the whole thing to the bumper, starting in the middle.
For me, its easier to get the bumper off to work on it rather than crawling around under the car. Bumper is dead easy to remove :thumbleft:
PostPosted: Mon Dec 09, 2013 5:09 pm
cool, ive never taken a bumper off any car before :shock: , im sure i will have plenty of fun with it :D 8)
cheers for the tip/advice
PostPosted: Mon Dec 09, 2013 5:18 pm
Well, you could always park with the nose off a kerb so you have some more room, or drive up some ramps :dontknow:
Front bumper is easy to remove from a BA though :) 3 bolts per headlight (10mm), then they wriggle out, revealing two 14mm nuts on each side behind the bumper, and a 10mm bolt attaching it to the wing. Then 3 plastic clips in each arch liner. Peel the liner back a bit to reveal a screw right in the upper corner of the bumper - undo it (or snap it :lol: ) Then there might be some bolts underneath attaching the plastic undertray (if you have one) - then pull it off :thumbleft:
Shame your so far away, I'd have it off in 5 minutes :lol:
PostPosted: Tue Dec 10, 2013 10:54 pm
[quote="HughieW"]I'd have it off in 5 minutes :lol:[/quote]
No surprise there :p
scalman
PostPosted: Wed Dec 11, 2013 3:34 pm
Just lift front of car same as u do to change wheel and u have space . I screwed renault espace splitter with screws only. Holding perfectly.just ly on back and screw bolts , i done it blindly i mean ididnt sae what im doing i just did and its done. I done it outside in cold alone no prob :D
Do center first , mesure center or bumper and splittet and screw it then rest of show one by one. Im simple person lol
PostPosted: Thu Dec 12, 2013 8:41 am
[quote="andym323"][quote="HughieW"]I'd have it off in 5 minutes :lol:[/quote]
No surprise there :p[/quote]
could have it done twice in that time! :oops:
PostPosted: Thu Dec 12, 2013 11:25 pm
[quote="HughieW"][quote="andym323"][quote="HughieW"]I'd have it off in 5 minutes :lol:[/quote]
could have it done twice in that time! :oops:[/quote]
I'm disappointed, I was expecting three times at least :badgrin:
PostPosted: Thu Dec 12, 2013 11:30 pm
When I fitted mine, and it was over ten years ago when I did, I borrowed my then girlfriends brothers garage, which had a pit :thumbright: and I used stainless bolts, but then again, I am a tad anal about fitting stuff ;)
To be fair though, it's not budged much in the last decade, had to tighten one or two bolts a few years back but basically it's been perfect, even to the point where the splitter has been bent back flat on many occasions and its always popped straight back in place :D
Bolts rock the house!!!
scalman
PostPosted: Sun Dec 15, 2013 12:47 pm
Cool to have garage bro, i didnt so just ground was enough for me. No hard to screw 6 or 8 bolts into splitter and wuala :)
PostPosted: Sun Dec 15, 2013 2:47 pm
[quote]
Bolts rock the house!!![/quote]
they do indeed :D , and once ive sorted out this blow on the zhorst then ill be hunting a few down and fitting mine today hopefully :D
