It is currently Sat Sep 12, 2026 12:49 pm
cba6p
PostPosted: Mon Nov 18, 2013 4:43 am
Someone could have done the front door before but I will be covering the rear door and will try to make it more comprehensive.
All the problems are caused by the 5 pieces of rubber parts that turned into pieces.
1. Remove door card.
2. Remove plastic sheet, partly, as shown below.
3. Remove the 2 circled screws as shown. Size = 10mm. Hold the stopper bracket at the back while unscrewing. Keep both brackets. You need to do something about them later.
4. Plug the window switch back and move the window glass up or down so that you can see the below 2 nuts + 1 screw. Remove them with a 10mm socket wrench.
5. Now, slide the glass upward. Be careful not to scratch your tint film (if any).
6. Next 2 photos show the sliding rubber and roller turned themselves into sh!t-look-alike stuff.
7. Wrap the stopper brackets with rubber taken from an F-clamp and secure each of them with a cable tie.
8. Now, remove 5x nuts (14 and 10mm) shown below.
9. Disconnect power window motor and remove the whole power window assembly out of the door.
10. Roller disappeared!!!
11. Grind off the head of the roller pin with a disc grinder and knock it out with a punch.
12. Drill Ø3.3 and tap an M4 x 10 deep hole at the centre of the pin. Get ready a button head M4 x 8 screw, a thin M4 washer and a new (reverse engineered) roller.
13. Insert the pin into the roller and slot the assembly into the guide rail. Apply some Loctite 242 on the threaded hole.
14. Fasten the screw and it is how it looks like:
We are done with the power window assembly. Ready to put it back into the door.
TBC...
HMT
PostPosted: Mon Jun 25, 2018 12:46 pm
Hi,
does anybody know how / where to get new replacement bushes?
Cheers,
Chris
CSR
PostPosted: Mon Jun 25, 2018 9:55 pm
amazing tutorial dude... I have two windows ratlling, and with this, you help a lot know how to solve it... only left to know how get the buches (don't say Mazda cuse not worth the money they ask ;) :blackeye: )
CSR
CSR
PostPosted: Wed Dec 26, 2018 9:00 pm
buches? XD
Isaac Burlo
PostPosted: Sun Dec 30, 2018 3:31 am
great work thank you :)
jakobie
PostPosted: Wed Mar 13, 2019 6:43 am
Nice write up. I will try your method since my windows are rattling a bit.
CSR
PostPosted: Tue Apr 06, 2021 9:05 pm
I still looking for those buches... only can fins for mx-5, witch seems to be the same issue. But only can find in US, and the price of postage is more than the set of 2 buches...
can someone know how to find a set in Europe?
HMT
PostPosted: Fri Apr 09, 2021 11:58 am
I can halp u with that. I am currently importing a few sets. I'd need a down payment via Paypal until the weekend to include you. It should work out at about 80€ plus shipping from germany to portugal.
Feel free to DM me on insta if possible @lantisdoc
da2el
PostPosted: Fri Aug 08, 2025 10:35 am
This is one of the most annoying and difficult things to fix in this car
Users browsing this forum: No registered users and 28 guests
