Club323F • View topic - Short Shifter Fitting Guide
It is currently Mon Nov 02, 2026 6:59 am
Matty
PostPosted: Mon Mar 28, 2011 1:17 pm
I didn't write this, but I figure it's pretty valuable. Found it floating the net, was looking for a diagram of how the bushings go back together and found this bit of gold for anyone apprehensive about fitting a short shifter:
[url=http://www.twmperformance.com/manuals/Mazdaprotege-escort-mx-3manual.pdf]Short Shifter Fitting Guide (PDF)[/url]
[url=http://www.dbtints.co.uk][img]http://www.dbtints.co.uk/images/dbtints.png[/img][/url]
[url=http://www.24-7lucente.co.uk]Prestige Car Valeting[/url] | [url=http://www.officefront.co.uk/virtual_switchboards/default.aspx]Virtual Office[/url] | [url=http://www.david-bell-jewellery.co.uk/]David Bell Jewellery[/url] | [url=http://www.qualitysuites.co.uk]Fama Moon Chair[/url]
Clarky
PostPosted: Mon Mar 28, 2011 3:36 pm
See im sure you didnt have bushes that were two different sizes under the car mate.... if they were different there was a tiny difference. Worth checking tho that if they are different they are in the right way round?
Wonder where you'll be this weekend before Hobsons!?
Matty
PostPosted: Mon Mar 28, 2011 3:42 pm
[quote="Clarky"]See im sure you didnt have bushes that were two different sizes under the car mate.... if they were different there was a tiny difference. Worth checking tho that if they are different they are in the right way round?
Wonder where you'll be this weekend before Hobsons!?[/quote]
I wonder too... Begin's with 'Be' and ends with 'n'. If not, I'll be slipping the lads at Kwik-fit a fiver to use their ramp for half hour.
PostPosted: Mon Mar 28, 2011 5:32 pm
The bushes are handed, and only fit one way ;)
Clarky
PostPosted: Mon Mar 28, 2011 5:34 pm
in which case they're already in the right way - Matty - its the white bits inside that you need to look at...
PostPosted: Mon Mar 28, 2011 5:38 pm
They are the TWM bushes though, the kit you have might be different :dontknow:
PostPosted: Mon Mar 28, 2011 5:39 pm
No poly bushes with this kit?
Matty
PostPosted: Mon Mar 28, 2011 6:50 pm
[quote="errnee"]No poly bushes with this kit?[/quote]
Nope. This is the kit and everything that came with it:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_922
It must be the white bits inside that are causing the problem then...
paul323f
PostPosted: Mon Mar 28, 2011 8:33 pm
What a brilliant guide. My kit came with some big round bushy things, don't know what they were for though, just used the originals. Also in the guide it says to remove the plastic inserts at the bottom of the original lever, haven't got a clue why as you don't use these on the short shifter?!
Matty
PostPosted: Mon Mar 28, 2011 8:50 pm
[quote="paul323f"]What a brilliant guide. My kit came with some big round bushy things, don't know what they were for though, just used the originals. Also in the guide it says to remove the plastic inserts at the bottom of the original lever, haven't got a clue why as you don't use these on the short shifter?![/quote]
Has yours got any play?
paul323f
PostPosted: Mon Mar 28, 2011 9:35 pm
Doesn't appear to. I made sure everything I took off went back in the same way I took it out. Think the big round spacers are for the mx3?
PostPosted: Mon Mar 28, 2011 10:35 pm
No, you don't need to take the old bushes out for the TWM kit either, no idea why they say to do that :dontknow:
did you take yours out Matty, that would give you lots of side to side play...
Matty
PostPosted: Mon Mar 28, 2011 10:47 pm
[quote="Marc S"]No, you don't need to take the old bushes out for the TWM kit either, no idea why they say to do that :dontknow:
did you take yours out Matty, that would give you lots of side to side play...[/quote]
Not 100% sure, will get it up in the air over the weekend and take a look! All my kits at home and I'm stuck in Watford until friday now.
he11boy07
PostPosted: Fri Jun 17, 2011 9:07 pm
will this kit fit my 1.5 bj ? anyone else have the same car and fitted it yet ?
PostPosted: Sat Jun 18, 2011 8:55 am
Fitted this to a few BJs, seems to fit well, should fit the 1.5 no probs :)
Cyntax
PostPosted: Sat Jun 18, 2011 12:02 pm
Just make sure that when you're taking the bolts out of the heat shield, you don't f*** the captive nuts like I did!
Now my cross members are filled with epoxy resin, and the damn heat shield is still rattling!
paul323f
PostPosted: Sun Jun 19, 2011 10:01 pm
mine is fitted to a 1.5 bj :thumbright:
he11boy07
PostPosted: Wed Jul 06, 2011 7:58 pm
what short shifter would be best for me to install ?
Matty
PostPosted: Wed Jul 13, 2011 5:40 pm
[quote="he11boy07"]what short shifter would be best for me to install ?[/quote]
This is what you're after mate:
http://cgi.ebay.co.uk/Mazda-MX3-323-Pro ... 4aa8ed4434
he11boy07
PostPosted: Thu Jul 14, 2011 11:46 am
cheer's bud!
i shall be buying my self this item once i have my car sorted from my little dink!
i noticed alot of side wobble when in any gear
is this due to clutch wearing or the bushing's wearing out ? as it is a 11 yearold car i would think it was bushing's ?
lucas-87
PostPosted: Sat Jan 28, 2012 11:41 am
Hey guys just been reading this thread will this kit fit a bj 2.0 td ???
thanks
PostPosted: Sat Jan 28, 2012 12:23 pm
I'd see no reason why not? worth a punt at £20 or so anyway...you'll easily sell the kit on if it doesn't ;)
