It is currently Thu Aug 27, 2026 4:02 am
N47han
 Post subject: need to reset my idle
PostPosted: Thu Dec 30, 2010 11:45 am
does anybody have a picture of an open diagnostic port with GDN and TEN marked as my idle is sitting rather high on start up 1600-1800rpm have searched through a few guides but none are opening or do not exsist any more
Thanks Nathan
ziggy323f
PostPosted: Thu Dec 30, 2010 12:15 pm
Mate, i reckon its just a case of adjusting the dizzy till it sits properly..
You person job.
PostPosted: Thu Dec 30, 2010 7:17 pm
If you open the port, you might have a diagram on the inside of the lid. If not, this should be right :)
Stuz
PostPosted: Fri Dec 31, 2010 10:23 pm
I have a diagram, As does Darren, Hughie doesn't though. . . :lol:
PostPosted: Fri Dec 31, 2010 10:27 pm
Made no difference resetting mine.
Stuz
PostPosted: Fri Dec 31, 2010 10:31 pm
mine neither, need to look further into it...
RY4N
PostPosted: Fri Dec 31, 2010 10:48 pm
Thanks Nathan
It is normal to rev up high on start up on a cold weather, sometimes even higher if its really cold. It is so that the engine can reach its normal operating temperature quicker.
Where does it sit when the engine has warmed up? I wouldn't worry if it's between 750 - 800 rpm.
Then again it won't do any harm if you reset the idle, just make sure you do it only when the engine has reached it's normal operating temp.
N47han
PostPosted: Mon Jan 03, 2011 10:30 pm
ok thanks for all your advice
Users browsing this forum: Bing [Bot] and 18 guests
