It is currently Thu Aug 27, 2026 3:38 am
GUIDES ONLY please.
bianconero
 Post subject: 2.0 v6 sport filter
PostPosted: Sun Sep 26, 2010 7:00 pm
Sorry if there is already a topic on the same theme..
So could anyone tell me which KandN airfilter goes on the V6? (Induction kit not just a filter). Or does the 57i kit for 1.5 fit for the V6?
Thanks!
col
PostPosted: Sun Sep 26, 2010 7:05 pm
ford probe store have just developed a kit for the v6
ITS JUST NOT CRICKET
Roc
PostPosted: Sun Sep 26, 2010 10:43 pm
http://www.fordprobestore.co.uk/store/p ... ts_id=3489
bianconero
PostPosted: Mon Sep 27, 2010 9:09 am
ohh i see.
An how good it is?:) How much would be the shipping to Hungary?:)
franki323f
PostPosted: Mon Sep 27, 2010 4:06 pm
its a wicked bit of kit.
Chuck Norris once kicked a horse in the chin. Its decendants are known today as Giraffes
Roc
PostPosted: Mon Sep 27, 2010 4:11 pm
bianconero wrote:
ohh i see.
Shipping anywhere in europe isn't expensive, it's auto calculated, but should be reasonable.
FifeRED
PostPosted: Wed Oct 20, 2010 12:34 pm
looks a cool bit of kit 8)
apart from sounding much better, is there any data to support better airflow through this over standard filters?
Roc
PostPosted: Wed Oct 20, 2010 1:05 pm
No data as such, but an excellent response from those who have fitted my kits is good enough for me.
Positive feedback all round so far.
franki323f
PostPosted: Wed Oct 20, 2010 4:40 pm
worth every penny lads. if you already have your resonater box removed there aint much diffrence but if you still have it fitted then fitting this kit will make a noticeable difference, espically pullin out of junctions.
 Post subject: Re: 2.0 v6 sport filter
PostPosted: Sun Nov 14, 2010 2:29 pm
I can recommend the Rocspeed induction kit for the V6 as I have one myself, fantastic bit of kit. Much more responsive through the revs and sounds so much better than the normal air box with the restrictive resonator. Get yourself one, you wont be disapointed!
detonate
PostPosted: Thu Dec 23, 2010 7:12 pm
Hello everyone,
I've ordered the Rocspeed induction kit from Ford Probe store and i'm waiting for it arrive any day now. I already removed the original air filter box but there is a part that i can't find from the pictures above and i have no idea where i should connect it with the new kit.
The part code is K5T44094 and K5T44093 and i found a topic about it at http://forums.mazdaworld.org/94-classif ... 44094.html . It looks like an important part of the air intake system. Couple of wires attached into it and a small hollow tube going into the original air filter box. It is bolted into the original air box aswell.
Any ideas where i should connect this with the Rocspeed induction kit? Specs for the car: Mazda 323F 2.0 V6 -95.
Thanks for the help in advance!
PostPosted: Thu Dec 23, 2010 10:07 pm
Put a sticky pad on it and attach it to the side of your battery, thats what ive done, job done ;)
detonate
PostPosted: Thu Dec 23, 2010 10:33 pm
Ok, that solves the placement. Thanks! :)
How about the small (air?) tube that goes into the original box, is that important?
PostPosted: Thu Dec 23, 2010 10:37 pm
It didnt go into the air box on my V6, dont worry about it, its fine ;)
PostPosted: Sun Dec 26, 2010 1:06 pm
Originally it's plumbed into your intake so that it sucks in filtered air. It won't hurt to just stick it somewhere (like on the side of the battery tray as DMS suggested) :thumbleft:
You appear to have another large inlet on your induction piping though...I'm not sure where that's meant to go? I don't think the induction kit has this hole...check the picture of DMS engine bay compared to yours.
You've removed the MAF sensor too - you will need this, so don't get rid of it ;)
detonate
PostPosted: Sun Dec 26, 2010 8:53 pm
Cheers for the replys!
The other inlet in the piping is weird indeed. It has a pipe (taken out in the picture) that is closed at the other end. Its about 50 cm long with a curve and goes down from the intake system to the lower part of the engine bay. No idea what it is for. Anyway, that part of the inlet system will be removed when i install the Rocspeed one. And yes, the sensor is waiting to be installed aswell. :)
PostPosted: Sun Dec 26, 2010 9:04 pm
_stuz_ intakes the same where as mine was a straight bit of pipe with only the oil breather installed??
PostPosted: Mon Dec 27, 2010 2:11 am
I think the extra pipe you have there will be a very early pre-ford thing. If the pipe doesn't go anywhere, it's a resonator to help reduce induction sound :thumbleft:
Stuz
PostPosted: Tue Dec 28, 2010 6:28 pm
Yep spot of huggles, I too have another small rubber pip going INTO the airbox I will get a picture.
I'm pretty sure it will be fine dangling around next to the rest of the bits though.
Users browsing this forum: Bing [Bot] and 2 guests
