It is currently Thu Aug 27, 2026 4:38 am
GUIDES ONLY please.
Drew
PostPosted: Tue Dec 14, 2010 7:48 pm
i know the green interior is different from the black. so anyone got a guide on removing the front door cards as i need to unplug my snapped off (due to an idiot) passanger side elec mirror.
if its the same as removing black interior just call me a n00b and laugh! :lol:
“Look at life through the windshield, not the rear-view mirror”
http://s1228.photobucket.com/albums/ee458/drewwales/ - My Photobucket 323f Gallery
hotstuffdave
PostPosted: Tue Dec 14, 2010 8:49 pm
from memory i believe theres a screw inthe handle, another towards the mirror underneath a little plastic thing that lifts up, two in the box, then gently pull the card away and lift up.
Hope this helps mate (if you can follow it! I know what im talking about at least! lol) ;)
When the last Angel has fallen, and Evil has had it's day. Standing at the gates of Heaven will be one lone Green Beret
Per Mare Per Terram
hotstuffdave
PostPosted: Tue Dec 14, 2010 8:53 pm
don't forget to unplug the electrics :D
Per Mare Per Terram
PostPosted: Tue Dec 14, 2010 9:26 pm
I'll steal Hughie's explanation as its a lot shorter and simpler than mine :D
Quote:
Post ford doors (no bin with lid):
One screw behind the handle/locok
One screw under the cap near the dashboard
One screw inside the pull handle
One screw in the top corner of the pocket
The unclip from the bottom (stick your fingers between the door and card, then tug it until the clips pop out). Once the card is just hanging, lift it upwards, and unplug the connectors behind it.
Pre-ford (with the big bin and lid):
One screw behind handle/lock
One or two screws inside the big bin
One screw under a cap near the dash
Same unclip and lift procedure as post ford door card :thumbleft:
eogbaker wrote:
http://blog.sloth.org.uk
Drew
PostPosted: Wed Dec 15, 2010 1:16 am
Thanks guys as always a great help!
Shayne
PostPosted: Wed Dec 15, 2010 3:11 am
Drew, your door cards are pre-ford.
New beginnings.
ChrisClarke
PostPosted: Wed Dec 15, 2010 4:34 pm
i can give u a hand later if u want drew?
Drew
PostPosted: Thu Dec 16, 2010 2:53 pm
to dark by the time i finish work. are you working tomo night if not fancy doing it sat?
