It is currently Thu Aug 27, 2026 4:15 am
GUIDES ONLY please.
chris_speed
 Post subject: Poor idleing 1.5 1998
PostPosted: Sun Dec 12, 2010 2:35 pm
i no what i need to do conect ten and ground to geva in the dianostic port then fiddle with the screw, i just need a picture of the dicnostic port with the numbers on so i dont connect the wrong 1's if any 1 could help would me mutch apreached :D
Stuz
PostPosted: Tue Dec 14, 2010 12:35 am
have you cleaned your maf ?
chris_speed
PostPosted: Tue Dec 14, 2010 3:55 pm
ive not will this help??
Simondo
PostPosted: Tue Dec 14, 2010 5:17 pm
Won't do any harm. Unless you break it. Then you're buggered! :evil4:
You're welcome.
shinar
PostPosted: Sun Dec 19, 2010 7:39 pm
What is the procedure for cleaning the MAF?
Stuz
PostPosted: Sun Dec 19, 2010 8:38 pm
Buy a can of carb cleaner from haldords / fps/ and motor factors.
1. On the intake side of your engine remove the big bulky looking piece of plastic with the wires going to it.
2. Spray carb cleaner through it making sure you get the small thin piece of wire running trough the middle, DO NOT touch this as you will break it.
3. Spray the other parts of the intake system ( throttle body etc)
4. Replace and take the car for a drive and see if it's any better.
This should cost no more that £6 and take less than 20 mins.
Stu
