It is currently Thu Aug 27, 2026 9:30 am
Post new topic Reply to topic  [ 27 posts ]
 Post subject: hard starting
PostPosted: Mon Nov 29, 2010 6:11 pm
Right i went through Steves thread he had as it sounds like the exact same problem he had but i have checked all the connectors to the throttle body which is what was causing his problem.
I have here a video of starting it earlier and if you listen carefully you can here it misfiring and then backfire and then rev perfectly untill i lift off the throttle and then start misfiring again.
Now i did start the car breifly before i took the video so it did start up a fare bit quicker than when completely cold.
I will upload another video tomorrow of exactly what it is like when cold in the morning trying to start it.
PS. I have new spark plugs in it. battery is fine, and alternator is fine. I have cleaned the contacts in the distributor and checked HT leads already.
PLEASE PLEASE HELP ITS BEEN ANNOYING ME FOR FAR TOO LONG
Stuz
 Post subject: Re: hard starting
PostPosted: Mon Nov 29, 2010 7:00 pm
Nice picture. . .
You need to visit me. .
PostPosted: Mon Nov 29, 2010 7:08 pm
I cant anytime soon due to previous comitments and cash being low at the moment Stuz
also it aint a pic its a video
Stuz
PostPosted: Mon Nov 29, 2010 8:56 pm
Ahhhh, it's ok, when you have the time, Pop over and see me :)
Lethagized
PostPosted: Mon Nov 29, 2010 9:08 pm
I would say ignition leads and/or dizzy cap.
PostPosted: Mon Nov 29, 2010 9:32 pm
already checked them.
steven
PostPosted: Wed Dec 01, 2010 10:40 am
My Car: 1998 Imola
Did you try changing the HT leads? See if you can borrow a set off a members car to swap over and test.
My misfire and backfiring was when the throttle was pressed, the higher the revs the worse the backfire and when i let go of it it sort of puttered for a while. With the video i can tell its a similar problem.
11r Cars are the fastest
PostPosted: Wed Dec 01, 2010 10:16 pm
I havent changed HT leads as I got no one around with a v6 to change with but i will be getting a multi meter to check their resistances. but here is the video of starting yesterday
steven
PostPosted: Thu Dec 02, 2010 10:07 am
My Car: 1998 Imola
Sounds very rough ego mate. My only other idea would be o2/lambda sensors. There are two on the V6.
http://www.picoauto.com/applications/lambda-sensor.html
PostPosted: Thu Dec 02, 2010 12:34 pm
well this morning i am going to attempt reseting the ecu. if that doesnt work i am going to put my old throttle body on and if that doesnt work i will look at getting lambda sensor
PostPosted: Thu Dec 02, 2010 12:39 pm
Not that I know a great deal Ayrton but id hazzard a guess its the leads :dontknow:
PostPosted: Thu Dec 02, 2010 2:04 pm
well i just went and reset the ecu and it started up a bit faster but still had the miss but only when you reved it so i pulled the leads off one at a time noticed it was cylinders 2 and 3 so i took the Distributor cover off and they were coked up again after i cleaned them a month ago so i cleaned them and bent them inwards so they are closer to the rotator arm and it started up and sounded better but i need to wait till it is ice cold again to see if it really has helped or not.. might be an idea to look at getting a new distributor cap i think unless someone says otherwise
steven
PostPosted: Fri Dec 03, 2010 2:53 pm
My Car: 1998 Imola
Even just try taking the dizzy cap off and use a flat screwdriver (gently) to clean the 4 brass coloured points and clean the rotor arm too. I did this to mine and it did help a bit. The dizzy itself will most likely be clean but there i found a powdery residue on the arm and points.
PostPosted: Fri Dec 03, 2010 3:19 pm
I did do that to all 6 and then when i checked again there was 2 coked up again and they were on the problem spark plugs that were misfiring.
I have just just bit the bullet and placed a HUGE 3 figure order with mark at FPS as i cant leave my car like this with my parents they will end up making it worse lol
Mobiius
PostPosted: Fri Dec 03, 2010 3:20 pm
6 Brass coloured points. lol
I'm better than you, because I drive a Lexus AND a BG-GT! Image
Like Cars or Video Games? Go Here!
Lethagized
PostPosted: Fri Dec 03, 2010 4:04 pm
When did you last replace the cap? It's recommended that you change the leads, cap, rotor arm and plugs all at the same time.
PostPosted: Fri Dec 03, 2010 4:06 pm
I havent replaced any of it before. All the things mentioned were on the car when i got it over a year and a half ago but I got all new stuff on its way..
Changing my colour coding in my engine bay from red to blue as well
steven
PostPosted: Fri Dec 03, 2010 9:41 pm
My Car: 1998 Imola
I stand corrected Mr Mobiius, i keep forgetting that it is a V6! ;)
I agree with Lethagized, it certainly wouldnt do any harm replacing all. I have a 1.5 and i have done everything but the cap, however if i had a type r, money would be no object.
PostPosted: Fri Dec 03, 2010 9:56 pm
I'd love to feel the same and if I had the money, and a TypeR, it would be no object, but sometimes the cash just isn't there :( I say sometimes not there... it's never there it seems :D
eogbaker wrote:
http://blog.sloth.org.uk
PostPosted: Fri Dec 03, 2010 11:37 pm
I honestly do wish money was no object but you got to remember that i am still on cadet pay. when i qualify at the end of next year and will be on +£26000 per year as well as it being tax free and only have to work 6 months out of the year then it will be going off the road for a proper strip down and rebuild but now i struggle through every month so it gets what it can when i can afford it.
PostPosted: Sat Dec 04, 2010 9:34 am
If you can, do a diagnostics check before you reset, this should eliminate any faulty sensors etc and reduce the amount of possibilities for you :thumbright:
PostPosted: Sat Dec 04, 2010 12:09 pm
I did get the car connected to a computer last week and everything was fine with no faulty sensors which i find strange as my fans still start up as soon as the engine has started which still makes me think that the ecu temp sensor is faulty but i replaced it as well ?!?
PostPosted: Tue Dec 07, 2010 3:01 pm
I have also just thought that it might be the inlet manifold gaskets as they were in a shabby state when i last had the inlet off so ordered some new ones of them as well
Stuz
PostPosted: Wed Dec 08, 2010 1:00 pm
That would explain alot, I personally change any gaskets when I remove a part.
PostPosted: Wed Dec 08, 2010 1:02 pm
I know but i thought i could get away with it but obviously i didnt.. hope it is just that but still going to fit all my other goodies :D
Stuz
PostPosted: Wed Dec 08, 2010 1:40 pm
Fit everything one at a time, and see how it is, the only reason I say this is so you can identify the problem and keep the other parts as spares :thumbup:
PostPosted: Wed Dec 08, 2010 1:47 pm
not sure if i am going to have the time to do all this so might get my dads local garage to fit everything when i am at sea but we shall see
Users browsing this forum: No registered users and 20 guests
