Club323F • View topic - Radiator Water Hose
It is currently Mon Nov 09, 2026 12:40 pm
ctclothbagco
 Post subject: Radiator Water Hose
PostPosted: Sat Oct 16, 2010 9:19 am
Does anyone know where I can get a new water hose to go from the radiator to the thermostat under the distributor?
Mine has started to bulge due to oil leaking from the distributor, and I went to the garage but the hose is on back order and could be up to 3 months before it comes in.
steven
PostPosted: Sat Oct 16, 2010 10:37 am
My Car: 1998 Imola
Scrapyard is always good mate. Have you replaced the distributor o ring mate?
ctclothbagco
PostPosted: Sat Oct 16, 2010 12:00 pm
Not yet, I've ordered a new one and will replace it when it arrives.
PostPosted: Wed Oct 20, 2010 10:41 pm
you could try fitting a pair of silicon hoses instead of the standard Mazda part chap. The reason the oil leaks is because the o-ring gasket in the distributor leaks, no mater how many times you replace them, in fact, the only solution 've fpound that works is a bit of silicon sealant around the o ring! The silicon lasts alot longer and won;t bulge if the dizzy does leak :D CAn't remember who made my hoses ofthe top of my head, but Stu or Matt might :D
ctclothbagco
 Post subject: Re: Radiator Water Hose
PostPosted: Thu Oct 28, 2010 9:23 pm
Thank's for the tip.
I was having a look at my mum's C-max and noticed that some of the cooling pipes are metal with rubber for the bends, so I'l have a bash a doing that.
PostPosted: Mon Nov 08, 2010 10:30 pm
Not a bad plan but how do you plan to fit a metal pipe over the metal fittings on the engine? :)
PostPosted: Mon Nov 08, 2010 10:40 pm
silcone couplers :dontknow:
PostPosted: Mon Nov 08, 2010 10:45 pm
It'd have to be, but wouldn't it just be easier to go all silicon? :)
ctclothbagco
PostPosted: Tue Nov 09, 2010 10:27 am
I plan to cut up parts of the old pipe that are ok, and use them for linking the metal parts of the pipe together and to the engine fittings.
But if I find any silicon hoses then I will go for that.
PostPosted: Tue Nov 09, 2010 10:23 pm
I have silicon and so does Matt :D
Can't ofr the life of me remember what the company is called though :?
nick
PostPosted: Wed Nov 10, 2010 1:06 am
Halfords do a universal pipe for about £20 which works. Its what I did when I found I had the same problem as you.
Halfords sell about 3 sizes, each only a couple of mm different. So you want to get the kid to take the mostly likely one out to the car and see if it looks about the right size.
Red cars go faster
www.club323f.com/nick
PostPosted: Wed Nov 10, 2010 6:38 am
[quote="andym323"]I have silicon and so does Matt :D
Can't ofr the life of me remember what the company is called though :?[/quote]
company is viperperformance
Hose type is supaflex :thumbright:
cosmos1989
PostPosted: Tue Nov 16, 2010 1:10 pm
[quote="Matt"][quote="andym323"]I have silicon and so does Matt :D
Hose type is supaflex :thumbright:[/quote]
Oh I might treat myself to a few red hoses, how big is the radiator hose?
PostPosted: Wed Nov 17, 2010 10:56 am
28mm internal diameter for the top and bottom hoses :thumbleft:
8/9mm internal diameter for the expansion hose
3/4mm internal diameter for the screenwash hose
cosmos1989
PostPosted: Wed Nov 17, 2010 1:14 pm
Tanks :D
cosmos1989
PostPosted: Wed Nov 17, 2010 7:37 pm
Hmm looks like viper don't do the ones I want...
PostPosted: Wed Nov 17, 2010 7:57 pm
what do you want/need?
If you are after the big rad hose then they are made "special order"
you need to drop them a line - usually a 10 day wait i think :thumbright:
cosmos1989
PostPosted: Wed Nov 17, 2010 10:03 pm
Might give em a quick call, yes rad would be replaced, just see how much they are first, nothing over £40 being bought till new year anyway so I shouldn't punish myself!
PostPosted: Thu Nov 18, 2010 2:25 pm
I just used a straight bit of pipe and bent it :lol:
PostPosted: Sat Dec 11, 2010 7:23 pm
[quote="ctclothbagco"]Thank's for the tip.
I was having a look at my mum's C-max and noticed that some of the cooling pipes are metal with rubber for the bends, so I'l have a bash a doing that.[/quote]
Just remember that the engine mountings have a lot more play than the radiator mountings, so you need play in the radiator hoses to allow for movement.
trouble^uk
PostPosted: Sun Dec 12, 2010 5:04 am
is this the right size pipe for the rad as i have been everywhere looking for 1 to no avail http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1434wt_905 or this 1 http://cgi.ebay.co.uk/28mm-Silicone-Fle ... 1558wt_905
want to make sure before i buy it
PostPosted: Sun Dec 12, 2010 11:03 am
[quote="HughieW"][b]28mm internal diameter for the top and bottom hoses[/b] :thumbleft:[/quote]
[quote]Hose ID: 28mm 1 1/8"[/quote]
Yep should do the trick ;)
trouble^uk
PostPosted: Sun Dec 12, 2010 11:00 pm
thanks mate got 1 ordered now then can change my o ring while am at it :)
