Club323F • View topic - 1.5 turbo
It is currently Sun Nov 01, 2026 1:50 pm
Elmo3d
 Post subject: 1.5 turbo
PostPosted: Sat May 26, 2007 9:49 am
I was looking at muy friends corsa diesel turbo yesterday... its got a little baby turbo ight afterthe manifold and form just looking at it (with my eyes) it looks like it will fit the 1.5!
A lot of people have been talking bout the fastest 1.5 and how much more fun it is to have a 1.5 whoop a 1.8 so i thought it would be a good idea to let ppl know (if they didnt already)
I havent done any measurements of any sort but if you know of a turbo corsa at the scrappy you should take a look, i want a turbo!!!!!
basically the turbo is on the manifold is just larger than your fist so wont blow the engine up andgoes back up the same side as our air filter goes
p.s. what does a breather pipe actually do?
Joe
PostPosted: Sat May 26, 2007 10:01 am
Wont a petrol car kill a diesel turbo??
I thought because the petrol car revved higher than a diesel it would simply kill the turbo?
Joe
Artermis
PostPosted: Sat May 26, 2007 10:17 am
tractor turbos do have different characteristics and dont always fare well on petrols, but most of the time u can get away with it, though the characteristics of them aint always fantastic for the power you want out of a petrol, it all depends on personal preferacne really.
i do remember seeing a vid of a supra with a truck turbo on it, big power, bigger bang when it let go too!
xp67
PostPosted: Sun May 27, 2007 2:15 am
There's actually a bit of space behind the manifold. If you're clever and make an angled piece you could get a larger turbo in there (you would need to make an adapter anyway to have it fit on your manifold). I wouldn't run a turbo designed for a diesel in a petrol engined car.
Elmo3d
PostPosted: Sun May 27, 2007 11:40 am
Aye, but it would be cheap ;)
I dont think the high revs will do any damge to the turbo, i think diesels push it faster coz of pressure of the exhaust gas (diesels are very high pressure engines)
Yer, i think you're right about the whole custom manifold thing, it would be way to easy to be a straight swap lol but perhaps in the future ill be one of the only turbod 1.5s about coz i cant find any others!
PostPosted: Sun May 27, 2007 1:05 pm
Most deisels only rev to about 4500 or 5000 rpm.
If you ask the turbo to take 6500 rpm its more than likely gonna make not nice noises. :wink:
xp67
PostPosted: Sun May 27, 2007 3:58 pm
[quote="Elmo3d"]I dont think the high revs will do any damge to the turbo, i think diesels push it faster coz of pressure of the exhaust gas (diesels are very high pressure engines)[/quote]
High pressure as in high compression yes, but this doesn't affect the speed of the exhaust gasses. The exhaust is pushed out by the piston on the exhaust stroke. The faster the engine is revving, the faster the pistons are moving, so the faster they push the gas out.
However things like the volume of the gas should be taken into account. I'd personally get a turbo which is designed for a small petrol engine, and not a diesel! Saying that you could almost certainly get away with using a diesel one, just don't be surprised if it shortens the life of the turbo! ;)
Lantis-Dio
 Post subject: Re: 1.5 turbo
PostPosted: Mon May 28, 2007 3:56 pm
[quote="Elmo3d"] and from just looking at it (with my eyes) it looks like it will fit the 1.5!
lol
dont think this is quite exact enough mate ;)
plus diesel engines rev much lower so this will be a major problem wont it?
DaVe0r
PostPosted: Thu May 31, 2007 11:36 am
dont forget that diesel turbo's are designed for the exhaust temps that a diesel runs at!!! not enough heat is bad..too much is bad also
the metal is ment to expand at a certain rate at xxx temps etc......petrols run some what...err HOT and can causing cracking in the turbine housings.., causing wicked turbo deaths :)
best option is to get a vj20 GTX turbo (small) on a 1.5 will give enough top end for you
Canthinkof12
PostPosted: Sat Jun 02, 2007 3:29 pm
just get one off an RS turbo, simple fairly similar size engine rev about the same, but then again n that not a 1.5 revs to 5750rpm at best im guessing if u put a turbo on ur not gonna go up to or past 6000rpm's much and my mates 306 turbo diesal revs to 6000rpm comfitably unless hes a lier, (could be the case) he did tell me he went 115 in it the other day and there was still loads left >.<
Elmo3d
PostPosted: Sat Sep 15, 2007 4:13 pm
Just an update to this thread...
I've just been to this guys house and hes got a cioen ax andthe manifold off a saxo and the turbo off a xsara and it works! apparently
hes welded the downpipe himself liek and its a bit crap but hes getting new exhaust system anyway.
better news though...he has a spare mercedes turbo! So i'm thinking of maybe seeing how is goes when he gets to puttign it on the road and firing the merc turbo on mine coz its gonna cost next to nothing (probably get the turbo free) and should get me over the 100bhp mark. Exciting thought it is i know i need to buy extra things for it which wil add up so im jus gonna see how his runs for the next few months and then maybe get it done with loads of other engine mods to make it work better :(
tmac2610
PostPosted: Tue Oct 28, 2008 11:31 pm
i have a 1.5 323 imola and i have raced 2 vw golf tdi's , and kept with them both, so deisel turbos i dnt think are as good as sum people seem to think, get a garrett turbo instead
paul323f
PostPosted: Wed Oct 29, 2008 10:23 am
Believe it or not there is a 1.5 ba that has already been turbo'd!
Kash
PostPosted: Wed Oct 29, 2008 1:33 pm
I would upgrade the head gasket, fuel pump, injectors, clutch, etc etc etc before just slapping on a turbo - which is the easiest bit i think? 'Fabricate new headers to accommodate the turbo' but making the Z5 get along with it is another story. I'm sure your ECU will walk home :lol: - maybe look into a Dastek to mate.
Jody
PostPosted: Wed Oct 29, 2008 2:05 pm
[quote="tmac2610"]i have a 1.5 323 imola and i have raced 2 vw golf tdi's , and kept with them both, so deisel turbos i dnt think are as good as sum people seem to think, get a garrett turbo instead[/quote]
They were probably 90 PS diesels or not trying to race you!!
You would have no chance against 115PS or above.
As far as a turbo is concerned, why not source a T3 from a Mini/metro turbo. Cheap, easily overhauled and will easy push 15-18 PSI. Or a T2 from an Fiesta turbo as the spool time will be less.
Dont put a diesel turbo on a petrol as most people have said as your compressor ratios are going to be wrong. It will run out of puff by about 3.5-4K
nat1979
PostPosted: Wed Oct 29, 2008 2:26 pm
so will these t3/t3 turbos still require alot of internal work on the engine?
offshore4ft
PostPosted: Wed Oct 29, 2008 5:19 pm
I'm surprised at the fact a 1.5 ba could out run a 90ps golf. I don't reckon i'd pull away from my mums 110 passat in a hurry, the amount of torque when that turbo kicks in is nuts.
Kash
PostPosted: Wed Oct 29, 2008 5:52 pm
[quote="offshore4ft"]I'm surprised at the fact a 1.5 ba could out run a 90ps golf. I don't reckon i'd pull away from my mums 110 passat in a hurry, the amount of torque when that turbo kicks in is nuts.[/quote]
I have a run with my mates 53plate 90ps golf...I was ahead a wee bit, say no more.
PostPosted: Wed Oct 29, 2008 11:50 pm
[quote="paul323f"]Believe it or not there is a 1.5 ba that has already been turbo'd![/quote]
Where is it hidden then? :dontknow:
Jody
PostPosted: Thu Oct 30, 2008 12:56 pm
[quote="Neil F"][quote="paul323f"]Believe it or not there is a 1.5 ba that has already been turbo'd![/quote]
Where is it hidden then? :dontknow:[/quote]
Ireland I believe. I can remember reading it when I first joined on here. Its a right tool for a 1.5.
Nat - Any turbo will require work on the internals. You might get away with a low boost 4-5 PSi without working internally. But it also might go pop depending on how its driven! Boost temps, extra pressure on the crank and rods and dont forget the poor old gearbox.
Kash - Thats what I mean. A 1.5 would have no chance against a 100PS + engine. 90PS couldnt even pull the skin off a rice pudding. I had a tussle with a 130 six speed and the V6 only just sat on its bumper.
PostPosted: Thu Oct 30, 2008 1:07 pm
There is a 1.5 turbo in holland also, a red one I seen a few times. I dont know if a B6T manifold would fit a Z5. The US and Aus mazda forums are a really good place to research :)
tmac2610
PostPosted: Wed Apr 15, 2009 11:06 pm
my mate from work owns a tdi and we had bout 200 meter race to end of the road and we were side by side all the way, they kak, trust me, a few days later i drove his car and i was shocked how kak it was, not what i expected from a turbo
and he rekons his is 110 bhp, also that was with my clutch slightly slipping.
Patrick323
PostPosted: Thu Apr 16, 2009 5:33 pm
[quote="tmac2610"]my mate from work owns a tdi and we had bout 200 meter race to end of the road and we were side by side all the way, they kak, trust me, a few days later i drove his car and i was shocked how kak it was, not what i expected from a turbo
and he rekons his is 110 bhp, also that was with my clutch slightly slipping.[/quote]
2 very different cars and engines mate.. ;)
Makz2008
PostPosted: Fri Apr 17, 2009 4:43 pm
well well wenever one of these threads come up i get excited and start dreaming of my Z5 with a turbo,
now come to think of it, if the smaller turbos dont damage the internals when driven in a sensible-ish mannerthen i would definitley be interested in investing....as in my area you cant really push the car much due to speed cameras/speed bumps/traffic police/POTHOLES/traffic etc...
and as for taking on a tdi golf with a z5 iv tried it got ripped apart and put my hands up in shame....maybe your mate was racing whilst the turbo was cold?? but believe me when the turbo kicks the Z5 struggles BIG TYM...
Makz2008
PostPosted: Tue Apr 21, 2009 6:40 pm
http://cgi.ebay.co.uk/Silvia-Turbo-s12- ... 240%3A1318
seems extremely cheap and is almost come to the end of the auction thought someone thinking of doin a conversion maybe interested?
second of all would this turbo work well with a Z5? which has stock internals?
jasonwoolcott
PostPosted: Tue Apr 21, 2009 7:32 pm
i think the turbo from a silvia would be too powerfull still, but i dont have much knowledge on this stuff. you not interested in it makz? though you were keen for a turbo build of some sort?
Makz2008
PostPosted: Tue Apr 21, 2009 7:42 pm
yess indeed i am but i dont have the knowledge base to do it
i think maybe summer time project? but at that it would be an extremely slow and money consuming job
money being the key factor unfortunately:(
but i think i will be purchasing few parts here and there to spread the cost :P
oh i didnt even clock it was from a silvia lol...
so im guessing that the turbo from an escort RS turbo would also be too powerful?
jasonwoolcott
PostPosted: Tue Apr 21, 2009 8:43 pm
oh yea id imagine that too, a litre turbo car like that would need alot stronger internals and gearbox id imangine. i reckon you should speak to shaggy or someone with a turbod car. just think how much silvia and rs turbos and subys for expampel being 2 litre turbos compared to our measly horsepower. a corsa VXR which is a 1.6 turbo i think..? could be quite close on BHP before they add the turbo but once again im not that clued up on this stuff, just what i would guess!
Makz2008
PostPosted: Tue Apr 21, 2009 10:25 pm
right....
out of curiosity...
the metro GTA had a turbo engine i think? well could someone confirm that and whether the turbo from a metro GTA would be worth installing to a Z5 for a small gain?
i dont really want to mess around with the internals of the engine to have a turbo..nor do i want my car to fly, really i like the sound of the dump valves :P:P:P but i dont want the fake whistler either..
oh im soo fussy lol so neways metro GTA???
PostPosted: Tue Apr 21, 2009 10:47 pm
This is [url=http://www.club323f.com/club323f/forum/viewtopic.php?t=8781&postdays=0&postorder=asc&start=0][b]THE THREAD[/b][/url] you want to be reading :thumbright:
[img]http://img372.imageshack.us/img372/4599/p7260011pv4.jpg[/img]
[img]http://img372.imageshack.us/img372/3936/p7260013tt6.jpg[/img]
the pics above are from that thread about a Z5 Turbo project, but the pics belong to [url=http://www.clubprotege.com/forum/showthread.php?t=31581][b]THIS THREAD[/b][/url]
