Club323F • View topic - HT Leads
It is currently Thu Oct 29, 2026 8:49 pm
Reevezie
 Post subject: HT Leads
PostPosted: Thu Feb 28, 2008 2:20 pm
Hello all im thinking of changing my HT leads, i would like to put some better ones on if you will lol, im not sure if more expensive ones will benifit my car ect, wot do you all think? Also is there any advantage of changing dis cap? Is there any better one that could improve the car, maybe make it run smoother? All Info appreciated, thnx :D
Jody
 Post subject: Re: HT Leads
PostPosted: Thu Feb 28, 2008 6:09 pm
[quote="Reevezie"]Hello all im thinking of changing my HT leads, i would like to put some better ones on if you will lol, im not sure if more expensive ones will benifit my car ect, wot do you all think? Also is there any advantage of changing dis cap? Is there any better one that could improve the car, maybe make it run smoother? All Info appreciated, thnx :D[/quote]
Hope this helps
http://www.club323f.com/club323f/forum/ ... hp?t=24037
Probably wont make a difference unless you have some serious tuning or power to start off with.
I have some on order from Performance leads.
Reevezie
PostPosted: Fri Feb 29, 2008 7:37 am
nice one for that, they are talking about V6 though, i only got 1.8. Is there anybody who changed there leads on 1.8 who could recomend some High Quality ones? :)
PostPosted: Fri Feb 29, 2008 9:10 am
I'd say changing HT leads, plugs and dizzy cap are all service items and should be done at some point to retain good ignition.
www.formulapower.com are another source. Gold Club Members get a discount too.
Reevezie
PostPosted: Fri Feb 29, 2008 9:31 am
is there a certain brand i should go for? Thmx Mark.T looked at the site ;)
scott5050
PostPosted: Fri Feb 29, 2008 11:32 am
I got Splitfire but Magnecor are supposed to be good as well.
You won't see a noticeable improvement unless your current ones are knackered. The stock leads aren't great and they're nearly as expensive as the aftermarket ones (especially if you hunt about).
Reevezie
PostPosted: Fri Feb 29, 2008 11:59 am
so splitfire/magnecor are good, what size do i get i seen 8.5mm and on the link above were they talking bout the V6 they speak bout 10mm?
scott5050
PostPosted: Fri Feb 29, 2008 1:21 pm
I'm pretty sure that Magnecor do 7mm, 8mm and 10mm.
Splitfires are 8.8mm but have two separate conductors.
Eire323f
PostPosted: Fri Feb 29, 2008 1:51 pm
You can get Kerr Nelson ones from fordprobestore for the 1.8 that are 10mm quad core :thumbright:
http://www.fordprobestore.co.uk/store/p ... ts_id=1194
Reevezie
PostPosted: Fri Feb 29, 2008 2:58 pm
so would you say that the wider the cables are the better they are or????
scott5050
PostPosted: Fri Feb 29, 2008 3:38 pm
The greater the cross-sectional area of the conductor, the less resistance it will create. Also, thicker insulation prevents arcing and damage.
Reevezie
PostPosted: Fri Feb 29, 2008 4:10 pm
[quote="scott5050"]The greater the cross-sectional area of the conductor, the less resistance it will create. Also, thicker insulation prevents arcing and damage.[/quote]
Sorry, i need telling basic lol by cross sectional area do you mean the thickness of the lead IE 7mm 8mm 10mm ect, by less resistance what exactly do you mean? :P
scott5050
PostPosted: Sat Mar 01, 2008 3:53 pm
Yep, thicker cable means more electricity flowing down it more easily.
Less resistance (easier flow) means less current (power) needed to do the job so less stress on alternator, leads, distributor, etc.
Reevezie
PostPosted: Tue Mar 04, 2008 10:38 am
I see whatyou mean Scott5050, thanks for that :)
MaRNz
PostPosted: Thu Mar 06, 2008 12:02 am
Can recommend Magnecore KV80s - do the business on my one-eight :)
Reevezie
PostPosted: Thu Mar 06, 2008 9:13 am
[quote="MaRNz"]Can recommend Magnecore KV80s - do the business on my one-eight :)[/quote]
thnx mate :)
DaveMc
PostPosted: Fri Mar 14, 2008 1:10 pm
heres the Magnecor ones for 1.8
http://www.europerformance.co.uk/pages/ ... uct=628725
