Club323F • View topic - Mazda Engine codes
It is currently Sun Nov 08, 2026 10:26 pm
Post new topic Reply to topic  [ 27 posts ]
 Post subject: Mazda Engine codes
PostPosted: Thu Mar 17, 2005 1:27 pm
12A - Twin-rotor Wankel rotary/573cc x 2
13B - Twin-rotor Wankel rotary/654cc x 2
20B - Triple-rotor Wankel rotary/654cc x 3
JE - V6 piston engine/3.0 litre
J5 - V6 piston engine/2.5 litre
KF - V6 piston engine/2.0 litre
KJ-M - V6 piston engine (Miller cycle)/2.2 litre
KL - V6 piston engine/2.5 litre
K8 - V6 piston engine/1.8 litre
B6 - Four cylinder piston engine/1.6 litre
B6T - Four cylinder piston engine/1.6 litre Turbo
BP - Four cylinder piston engine/1.8 litre
BPT - Four cylinder piston engine/1.8 litre turbo
FE - Four cylinder piston engine/2.0 litre
F2 - Four cylinder piston engine/2.2 litre (turbo only)
F8 - Four cylinder piston engine/1.8 litre
Further information on the engines can be found here: [url]http://www.autospeed.com/cms/A_2098/article.html[/url]
PostPosted: Thu Mar 17, 2005 2:51 pm
Z5 - 323F/Protege 1.5 DOHC 16v
PostPosted: Sat Mar 19, 2005 5:14 pm
ZL - 1.6 Litre In-line 4 Cyl. 8)
PostPosted: Sat Apr 02, 2005 10:20 am
For info:
http://members.aol.com/solomiata/MX5Engine.html
PostPosted: Sat Apr 16, 2005 12:49 am
For Info
[u][b]Contents [/b] [/u]
1 B3
2 B5
3 B6
4 B6T
5 B6D
6 B8
7 BP
8 BPT
9 BP-4W
10 BP-Z3
[b]B3[/b]
1.3 L B3 - 1324 cc (71x83.6 mm) - Mazda's first B-family engine. It was available in SOHC and DOHC variants and was found in the Mazda-built Ford Festiva, the 1987-1989 Mazda Familia and the 1987-1989 Ford Laser. Later variants were used in the Mazda Demio microcar as late as 1999.
[b]B5[/b]
1.5 L B5 - 1498 cc (77x80 mm) - The SOHC B5 upped the displacement to 1.5 L and was found in the rear-wheel drive 1977 Familia/GLC, the 1987-1989 Mazda Familia and the 1987-1989 Ford Laser. Later variants were used in the Kia Sportage, Ford Festiva and Mazda Demio microcar as late as 1999.
[b]B6[/b]
1.6 L B6 - 1597 cc (78x83.6 mm) - This was a bored-out version of the B3. The 8-valve SOHC B6 was found in the 1985-1989 Mazda 323 and 1990-1992 Mazda Protege. The B6 produced 82 hp (61 kW).
In Japan and Australia a fuel-injected version called the B6F was available.
An unusual SOHC 16-valve head was later added for the 1992-1993 Mazda MX-3 and dubbed the B6-2E.
[b]B6T[/b]
1.6 L B6T - 1597 cc (78x83.6 mm) - The ubiquitous turbocharged, fuel-injected and intercooled 16-valve DOHC B6, released in 1985 and used in numerous models worldwide including the 323 GT-X, 1985-1989 Mazda Familia GT-X/GT/Infini, 1985-1989 Ford Laser TX3 turbo, and later Mercury Capris. This engine was most commonly found mated to a 4WD drivetrain although FWD models were also available. Power and torque outputs varied across markets due to emission and fuel standards, but the Japanese version of the B6T was the most powerful, producing 147 hp (110 kW) and 137 ft.lbf (186 Nm).
[b]B6D[/b]
1.6 L B6D - 1597 cc (78x83.6 mm) - The same strengthened and fuel-injected DOHC B6 as the B6T, but with no turbo. Most commonly found in the Japanese market Familias, Etudes and Lasers, this engine was also used in the '89-'93 Mazda Miata and Mercury Capri.
[b]B8[/b]
The 1.8 L (1839 cc) B8 is not just a bored- and stroked- B6. Rather, a new block with widened cylinder spacing is used. The bore was 83 mm and the stroke was 85 mm. This SOHC engine was used in the Mazda 323.
[b]BP[/b]
The BP is an improved DOHC variant of the 1.8 L B8.
Applications:
1990-1993 Mazda 323
1991-1996 Ford Escort GT
1994-1997 Kia Sephia GS
1994-1998 Mazda Protegé
1994-1998 Mazda MX-5/Miata
[b]BPT[/b]
The BPT is a turbocharged and intercooled variant of the BP. It produced 179 hp (134 kW) and 174 ft.lbf (237 Nm) of torque. A detuned variant of the BPT with considerably less power (due to fuel standards) was sold in Australia. The hottest version was used in the Mazda Familia GT-R, producing 206 hp (154 kW) and 184 ft.lbf (250 Nm).
Applications:
1989-1994 Mazda Familia GT-X (Japan)
1989-1994 Ford Laser TX3 turbo (Australia)
Ford Laser GT-X
[b]BP-4W[/b]
The 1999 Miata uses a modified BP, the BP-4W, which adds a VICS intake, replaces the old Hall Effect Cam Angle Sensor with a magnetic unit at the front, and has an improved intake system. The United States 2004-2005 Mazdaspeed MX-5 turbo is based on this engine rather than the newer BP-Z3 and produces 178 hp and 166 ft.lbf with slightly-reduced compression.
Applications:
1998-2000 Mazda MX-5/Miata
2004-2005 Mazdaspeed MX-5 (turbo)
[b]BP-Z3[/b]
In 2001, Mazda introduced the BP-Z3 (also called BP-VE) variant of the BP engine with S-VT variable valve timing on the intake side, but no more VICS. This was found in the 2001+ Miata. The Z family is an evolution of this engine.
In Australia, a turbocharged version of this engine produced 201 hp (150 kW) and 206 ft.lbf (280 Nm) in the Mazda MX-5 SP. The United States 2004-2005 Mazdaspeed MX-5 turbo is a BP-4W, not a BP-Z3.
Applications:
2001-2005 Mazda MX-5/Miata
Mazda MX-5 SP (Australian turbo)
PostPosted: Sun Aug 07, 2005 12:38 pm
http://projectmazda.com/tech/b-seriesengine.htm
PostPosted: Sun Aug 07, 2005 12:42 pm
The Mazda 323 (called the Familia in Japan) was a subcompact car produced by Mazda in Japan between 1976 and 2003. In the United States it was originally known as the GLC, then the 323, then finally from 1990 on as the Proteg¨¦. In South Africa it was known as the Etude. The Ford Focus-based Mazda 3 replaced this series of platforms for 2004, though Mazda still contributed much to the project.
323s were built in Hiroshima, Japan, although they were also assembled in Taiwan, Malaysia, South Africa, Colombia and New Zealand.
In North America the 323/Proteg¨¦ was always more expensive than its entry-level competitors such as the Toyota Corolla and Honda Civic, partly due to its manufacture in Japan, and therefore is not as ubiquitous. It was also the first small Japanese car to cross over to the EPA "compact" class in 1990 when the 4-door started going by the name Proteg¨¦.
It formed the basis of the Ford Laser and Meteor in Asia, Australia and other markets, (known as the Mercury Tracer in the United States) and from 1991, the Ford Escort in North America.
1976
The first Mazda 323 was a rear wheel drive model. It was known in the United States as the Mazda GLC (which stood for 'Great Little Car') and was a version of the fourth-generation Japan-market Mazda Familia.
Engines:
1.0 L PC, 45 hp (33.6 kW)/51 ft¡¤lbf (69 N¡¤m)
1.3 L TC
1.4 L UC
Production of the van variant only continued after 1980 (still with round headlights), as there was no front wheel drive replacement.
Wheelbase: 2311 mm (91 in)
Front Track: 1295 mm (51 in)
Rear Track: 1311 mm (51.6 in)
Length: 3820 mm (150.4 in)
Width: 1595 mm (62.8 in)
Weight: 812 kg (1790 lb)
1980
The 1980 323 featured a 1.5 L engine, and was front wheel drive. It was available as a hatchback and sedan. The 1980 Carol/323 was the first front-engine, front-wheel drive vehicle from Mazda since the rare R130. A wagon version, which was simply a facelifted version of the previous rear-drive model, was also sold. The 323 was Wheels magazine's Car of the Year for 1980.
Engine options:
1980-1987 - 1.1 L E1 I4, 55 hp (41 kW) and 79 N¡¤m (58 ft¡¤lbf)
1980-1987 - 1.3 L E3 I4, 60 hp (44 kW) and 95 N¡¤m (70 ft¡¤lbf)
1980-1987 - 1.5 L E5 I4, 75 hp (56 kW) and 116 N¡¤m (86 ft¡¤lbf)
1985
The 1985 323 again featured a 1.5 L engine. It was available as a hatchback, sedan and wagon (this time also front wheel drive). The Ford Laser version of this model also formed the basis of the Mercury Tracer.
The model remained in production in South Africa until 2003, as an entry level model, also being sold as the Ford Tonic, and was briefly sold in the UK as the Sao Penza. A locally designed pick-up called the Hustler was also produced, and sold as the Ford Bantam.
This generation was sold through the 1989 model year in the United States. The station wagon continued in many markets and was not cancelled until 1995.
Engine options:
1980-1987 - 1.1 L E1 I4, 55 hp (40 kW) and 55 ft¡¤lbf (75 Nm)
1980-1987 - 1.3 L E3 I4, 60 hp (44 kW) and 70 ft¡¤lbf (95 Nm)
1980-1987 - 1.5 L E5 I4, 75 hp (56 kW) and 86 ft¡¤lbf (122 Nm)
1987-1989 - 1.5 L E5c I4 catalyst, 73 hp (54 kW) and 83 ft¡¤lbf (113 Nm)
1.5 L B5 I4, 75 hp (56 kW) and 86 ft¡¤lbf (117 Nm)
1988-1989 - 1.6 L B6 I4, 82 hp (61 kW)
1988-1989 - 1.6 L B6T I4 turbo, 148 hp (110 kW) and 144 ft¡¤lbf (195 Nm) GTX
Dimensions:
Wheelbase: 2400 mm (94.5 in)
Length: 4194 mm (165.1 in)
Width: 1643 mm (64.7 in)
Weight: 936 kg (2063.5 lb)
1990
The 1989/1990 BG 323 was available in hatchback or sedan formats, with front- or all-wheel drive and a 1.3 L, 1.5 L, 1.6 L, or 1.8 L gas or 1.7 L Diesel engine.
The GT model came with the 1.6 L B6 engine also found on the Mazda Miata.
The GTX model featured all wheel drive and a turbocharged 1.8 L BP engine. In 1992, the rare GT-R version was added, featuring a number of performance enhancements over the GTX model.
The car donated its basic mechanicals to the 1991+ Ford Escort and Mercury Tracer and 1994-1997 Kia Sephia in North America, as well as the Ford Laser.
In America, the LX version of the Proteg¨¦ became known for its vast interior room (for its class), sporty handling, and revvy 125-horsepower engine. LX models also had 14-inch wheels, all-disc brakes, and dual stabilizer bars.
Production of the 1994 model ended on May 24, 1994.
engine options:
1.3 L B3 I4, 75 hp (56 kW) and 76 ft¡¤lbf (103 N¡¤m)
1.5 L B5 I4 DOHC, 110 hp (82 kW) and 93 ft¡¤lbf (125 N¡¤m)
1.6 L B6 I4 DOHC, 82 hp (61 kW) USA
1.6 L BPT I4 turbo
1.8 L BP I4
1.7 L PN I4 Diesel
Dimensions:
Wheelbase: 2450 mm (96.5 in)
Front Track: 1430 mm (56.3 in)
Rear Track: 1435 mm (56.5 in)
Length: 3995 mm (157.3 in)
Width: 1675 mm (65.9 in)
Weight: 955 kg (2105.4 lb)
1995
The 1995 BH model was available internationally with both front wheel drive and all wheel drive. Production of this generation started on August 8, 1994, and ceased on June 18, 1998.
Americans will want to stick to the rare ES model, the only Proteg¨¦ that came with the Miata's 1.8-liter twin-cam engine, 4-wheel disc brakes, and dual stabilizer bars.
Models:
4-door sedan (called the Proteg¨¦ in the US)
2-door hatchback (Familia Neo in Japan, 323c in Europe)
A tall wagon, called the Familia Van, was also available in Japan. In South Africa, this model was known as the Mazda Etude.
Engines:
1.3 L B3
1.5 L Z5
1.5 L B5
1.8 L BP
1.7 L 4EE1 Diesel (Japan)
323F/Astina
Mazda 323F sedanA five door hatchback and four door sedan, both featuring pillarless doors and distinct sheetmetal from other 323s was sold in Japan as the Mazda Lantis, in Australia and South Africa as the Mazda 323 Astina, and in Europe as the Mazda 323f. They were built on platforms distinct from the other 323s. The bodyshape was designed by former Porsche designers. The Lantis was on the CB, a minor update of the CA that underpinned the luxury Mazda Xedos 6 and Eunos 500. The European 323f was designated BA, but was actually almost identical to the CB, and had little to do with other B platforms. These models were sold with the 1.5 L and 1.8 L engines seen in the rest of the 323 range, as well as a 2.0 L V6 shared with the Eunos 500.
1999
BJ 323 wagonThe 1999 BJ platform was updated with a 4-door sedan or 5-door hatchback chassis based on the larger Mazda 626 and more engine choices. The Japanese Mazda Familia again got all wheel drive as an option. In America, the ES's engine was still 1.8 liters large but was a shrunken version of the 626's engine rather than the Miata's more exciting motor. Disc brakes on the ES were also lost.
Engines:
1.3 L B3
1.5 L ZL
2.0 L FS, 130 hp (97 kW) and 135 ft¡¤lbf (183 N¡¤m)
2.0 L FS-ZE (2001 Sport 20)
2.0 L RF Diesel
A 2.0 L gas engine appeared in 2001 on the Japanese market Sport 20. An tall wagon version of the Familia called the Mazda Premacy was also available, and which was sold in Japan as the Ford Ixion. In 1999, Ford of Japan ceased to market Mazda-based models, and the Ford Laser, along with the Ixion, Telstar and Festiva, was dropped.
For the 2001 model year in North America, Mazda introduced the limited-edition Proteg¨¦ MP3 featuring a new sport-tuned suspension, 17 in wheels, 10 hp (7.5 kW) extra for a total of 140 hp (104 kW), and a 450-watt Kenwood MP3 stereo. 2001 also saw Proteg¨¦s getting a sharper face lift, the ES getting its rear disc brakes back and a stiffer suspension, and the 1.8 L engine growing to 2.0 L.
2002 saw the introduction of a station wagon version called Proteg¨¦ 5. All Proteges got the 2.0 L engine this year.
In 2003, Mazdaspeed introduced the Mazdaspeed Proteg¨¦, an update to the Proteg¨¦ MP3 that had a 170 hp (127 kW)/160 ft¡¤lb (217 N¡¤m) turbocharged engine, 17 in wheels, larger four-wheel disc brakes, and a Kenwood stereo system that included an amplifier, and 8inch sub. Mazda then followed with a mid year change dubbed the "2003.5." This model included a different aero-kit, darker painted wheels, and custom interior pieces. In total, there were only 4,750 Mazdaspeed Proteg¨¦ models produced. This was the last year for the production of the Proteg¨¦. ES models got a manumatic transmission.
2003 Ford Activa sedan, TaiwanThis generation went into production on September 29, 1998, and the very last model rolled off the assembly line on October 2, 2003. It remains in production in Taiwan, where it is also badged as the Ford Activa, which, unlike the Ford Laser, has no styling changes from the 323, except for the badges. (In Southeast Asia, a version of the last Laser is still assembled in Indonesia, Malaysia Thailand and the Philippines as the Ford Lynx.)
In Colombia, production of the Mazda 323 continued well until 2003, built by its local subsidiary, the Compañ¨ªa Colombiana Automotriz. The 323 remains to this day one of the most successful cars made in the country and many models made across the years can still be seen in the streets of most Colombian and Andean cities. Oddly enough, the "boxy" look that characterized the vehicle during the early 1990s and the 1980s remained until production's end due to the demand of the local market for the car's lines.
2004
The 323 has been replaced in Mazda's lineup by the Mazda3, which shared a platform with the latest generation Ford Focus. The "3" comes in both 4-door sedan and 5-door hatchback varieties.
PostPosted: Thu Dec 15, 2005 11:23 pm
There's a great list of Jap-Spec engines used here http://corksport.com/store/category/9bp ... gines.html
It gives approximate bhp ratings for each engine and their applications
"1.8L T4cyl (BPturbo) - * Installation can be difficult and expensive. (ECU wiring, mounts, transmission)"
lmao, sorry Ben ;) 180bhp tho :)
PostPosted: Fri Dec 16, 2005 9:15 am
No i agree, it is tricky! :D
mmpob
PostPosted: Fri Dec 16, 2005 10:10 am
hehehe, "wankel"
sorry, it had to be done - delete me now ;)
joshm25
 Post subject: Rotary
PostPosted: Sat Jul 15, 2006 12:45 pm
anyone know how much power that 20B triple rotor wankel engine puts out? :toothy5:
Ruthless
 Post subject: Just Bought a 323F
PostPosted: Mon Jul 17, 2006 11:00 pm
Hi all,
Now going to purchase a 323F BA on a 1998 plate, Previous owner said its a 15cc engine 97bhp. Come on its got to be an injection!
By the way I used to have an astra 16i wide wheels very sporty, but it was ready for the dump (rust) and the father inlaw sold me his 20i 136bhp Mondeo. Nice drive just to expensive on juice/insurance and ugly.
[b]Anyway looking forward to being part of the exclusive 323f club.[/b]
Any info on the engine would be great or any mods that could give this car a boost would be great!
JAM
PostPosted: Mon Jul 17, 2006 11:03 pm
Hi, and welcome.......
Have a browse through the NA, and Forced induction sections for Performance Mod advice and ideas!!!
Blaine
PostPosted: Tue Sep 26, 2006 12:21 pm
I have no idea what model my engine is, anyway to find out?
JAM
PostPosted: Tue Sep 26, 2006 12:56 pm
Z5 - 323F/Protege 1.5 DOHC 16v :thumbright:
Hazardous
PostPosted: Mon Oct 02, 2006 8:58 am
BP - Four cylinder piston engine/1.8 litre want to cahnge to a 20b not too sure tho as feul prices are soo high
PostPosted: Mon Oct 02, 2006 1:35 pm
Might be possible, there's a Nova round here bing converted to run a FWD 13B engine with Peugeot or Vauxhall deisel box :D
I've been told the crank turn the opposit way to what we'ed need anyway :(
DKZ
PostPosted: Tue Oct 03, 2006 8:05 am
andym323: Spin it 180 degrees? Might work.
Drag Racer down here called Zoheb Razak has a Mitsi EVO 3 with the whole engine turned 180 degrees, I think to help with induction or something. Cant remember. But still works perfectly... Low 8's down the 1/4.
Hazardous: Why not stick a V6 in there? There was a Honda Civic in Auckland for sale on TradeMe that had a 13B in it... FWD and all. All show, No go apparently :thumbleft:
countessfenrig
PostPosted: Sat Nov 22, 2008 5:03 am
Hi,
I've just had my engine replaced and apparently I have to tell the DVLA. Where can I find the engine code/serial number on the new engine?
Hannah
plankton
PostPosted: Mon Nov 24, 2008 2:48 am
hmm the corksport link didnt bring anything up, ive got hold of a scrap eunos roadster prob pre 98, any ideas on the engine type in that
(its a 1.8 i think, looks like a bp of some sort)
PostPosted: Mon Nov 24, 2008 6:40 pm
[quote="countessfenrig"]Hi,
Hannah[/quote]
i knew i'd answered this before for another V6 owner:
[quote="Matt"]engine code is on the back of the engine - drivers side, about halfway down, from the diagram i have i cant tell if you'd be able to see it with the engine in the car.......[/quote]
Mase
PostPosted: Tue Nov 25, 2008 1:58 am
I had already sent a text message to Hannah telling her that, however I forgot to say it was difficult with the engine in the car. Just forgot to update it here.
Glad to see I was correct in my info.
Jgu
PostPosted: Mon Jun 01, 2009 8:32 pm
I wonder what engine my -97 BA has. It's 1.8 litre 16V DOHC, but only has 85/84 kW output. No mention of that in the guide. Sold in northern europe.
I guess it could be the F8, but no way mine goes to 8000rpm.
kyrnikos
 Post subject: Re: Mazda Engine codes
PostPosted: Wed May 30, 2012 3:46 pm
Z5 - 323F/Protege 1.5 DOHC 16v :thumbleft:
gooseboy78
PostPosted: Thu Jun 14, 2012 12:11 am
good article but... you skipped over the 626 / ford telstar with the fe 2.0 ohc then with the later engine with the twink in it. (of which there are no performance parts for either engine)
Scypher
PostPosted: Sun Jan 19, 2014 4:29 pm
how and where do i find information on my engine by using my engine number....i have a mazda kf an there are a few different mazda kf's i want to use my engine number to find out exactly which one i hav....KL-DE, KL-ZE etc
Denly744
PostPosted: Tue Aug 06, 2019 8:50 am
Thanks for sharing this codes list.
