It is currently Wed Oct 07, 2026 3:25 pm
GUIDES ONLY please.
ClassicFan
PostPosted: Mon May 08, 2006 9:42 am
GUIDE WITH PICTURES NOW AVAILABLE FROM
http://www.jamesandtracy.co.uk/cambeltchange.htm
ENJOY!
OK finally a draft of the guide to replacing your cam belt as promised. There are loads of pictures but I haven’t had time yet to format them into the text. If anyone has any info on timing marks for the 1.3, 1.5 and 2 litre please add (it should be in the workshop manual). I’ll add a proper guide with pictures when I get the time in the meantime this should give you a good idea, and if you have a Haynes manual you should be able to use this anyway. – Good luck! :cheers:
ClassicFan
---------The Guide to Replacing your Cam Belt and Water pump -------
What you need
2 axle stands (you could get away with one)
1 Jack
Full box socket set
Ring spanner set
long nosed pliers (if replacing tensioner)
mole grips (like lockable pliers - dead useful!)
Screwdriver set
Spark plug remover
Envelopes
Micro tippex pen
Ruler/Straight edge
Ciggies
5 Gallons of Home Brew
Decent stereo
Recommendations
I would recommend that if you are going to do this job you should do the full monty. The job isn’t a hard one but the amount of stuff you have to take off isn’t small, so why just replace the bare minimum of stuff when it’s all lifed to about the same time? It’s going to cost you an extra £80 to replace everything – water pump, cam belt, idlers and tensioners. The whole job will come to around £120 if you replace everything, the equivalent garage job would cost you about £300 - £400 so you’ll be saving loads, and you’ll never need to worry about it again for 54K miles. However, if you just replace the cam belt, you could end up (which is what happened to me!) taking the whole thing off 3 days later to replace the water pump.
Cost
Still if you decide you can’t afford £120 then you could just replace the cam belt and the whole job will only cost you around £30. A word of warning though – don’t go to a Mazda dealer to get your parts or you’ll pay a fortune. Bog standard repro auto-factors belt £27+vat or £57 for the kit. Equivalent Mazda dealer belt £90+vat for the kit!
I ended up doing the full monty and paid:
£66.98 for cam belt kit (repro)
£54 for water pump (repro)
£4.30 for Hylomar Universal Blue gasket sealer (it’s the best)
£4 for a 18mm deep socket (I had 17mm and 19mm but not 18mm!)
Total: £129.28
Equivalent garage cost: £300 – £400
Saving you: £170.72 – £270.72
However, if you wanted to do it on the cheap:
£32 for a cam belt
Total: £32
Equivalent garage cost: £100 - £200
Saving you: £68 - £168
Time
The whole job’s going to take you around a day. It took me 4 ish hours but it did start raining half way through so I went to the pub! If you’ve not done anything like this before then start it Saturday and don’t plan to go anywhere Sunday, just in case!!
Where everything is
Before you start familiarise yourself with the location of everything under the bonnet (see picture below)
IMPORTANT: Some terms I’ll be using – A LOT!
Rather than giving myself wrist ache :) trying to type out ‘driver’s side’ or ‘left hand side of the car when looking from the front of the car’, I’ll instead use the standard terms you’d hear in a garage. These are ‘Off side’ (driver’s side) and ‘Near Side’ (passenger side – or the nearest side to the curb!). You can then combine these with things like ‘Off Side Front’ (Front of the car on the drivers side) or ‘Near Side Rear’ (Back of the car on the passenger side). You might also see ‘Off Side Rear of the Engine’ which dosen’t mean you’ve got an engine ‘stuck on your drivers side rear wheel arch’, it means the ‘Back of the engine on the drives side of the engine’.
However, these all take time to type so I’ll use the standard abbreviations which are:
OSF (Off side front)
OSR (Off side rear)
NSF (Near side front)
NSR (Near side rear)
The job:
Phase 1. Removing Stuff
Before you start pop the bonnet, put the car in neutral and start her up. Note which way the belts are turning on the OS of the engine. From that you should know whether your car’s engine rotates clockwise or anti-clockwise. Note this down you’ll need it later on. Then stop the engine before anything gets hot – you don’t want to burn yourself on the exhaust!
First you need to jack the car up and whack it on some axel stands. Get it as high as you can as you’re going to be working under there. If you don’t know where to jack your car up then you’ll find help on this forum. Don’t jack it up just anywhere – use the jacking points and any large lumps of metal that look suitable (but not the engine/gearbox alright!)
Now it’s up, take off the OSF wheel.
Next you need to drain the radiator if you are going to replace the water pump. If you’re going to skip the pump then don’t bother. Most cars seem to have a drain plug on the bottom of the radiator, but I couldn’t find it, and anyway it’s a lot easier and faster to just pull the bottom hose off. That’s the big hose on the off side (driver’s side) bottom of the radiator and it goes up to the pump, which is situated behind your cam belt. When you do this remember that very soon you’re going to be lying under the car so have a bucket ready – you do not want to be lying in a large puddle. Also, there is no reason to chuck this rad water away – it contains antifreeze and therefore it’s expensive, so it can be reused if it looks ok.
Now you need to remove the two plastic shields that protect the bottom front of your engine and attach to the bumper and inside OSF wheel arch – see pictures. These panels have plastic locking screws as well as bolts. The locking screws can be opened by turning the inside portion of the screw head, while holding the outside ring of the screw head. It actually is easy and you’ll see what I mean when you come across them!
Now remove your spark plugs and mark the spark plug leads so you know to which ‘hole’ they apply. Don’t drop anything down these holes once your sparks are out or you are in for a world of pain as they go right into your engine cylinders. Everyone does something like that once in there life, if they work on enough motors, and once you’ve done it you never ever forget! The best way is to put the leads back into the holes as you remove each spark.
Next it’s time to remove the power steering and alternator belts. These are the external belts on the OS of the engine. Before taking them off, get your tippex pen and mark each belt for direction and for what it is (Alternator, Power steering). Also note which pulleys each belt goes around – write it down in a diagram so you don’t forget! The belts can be removed by loosening the tensioning bolts at the power steering pump (OSF of engine) and alternator (OSR of engine). To make your life easier I’d also suggest you loosen the pivot bolts that allow your alternator and power steering pump to pivot and so tension the belt. Once all is loosened then you should be able to rock both the alternator and water pump forward and hence loosen the belts so you can remove them.
Once you have the belts off you need to inspect them for damage. Cracks running across them are fine, missing ridges less than 1 inch in length are fine. But if you have missing ridges greater than 1 inch in length or have two adjacent ridges missing then you need to replace the belt.
Now this probably only applies to the 1.8 but it could apply to other models too, so take note! Basically you’re trying to get access to the whole of the cam belt. The cam belt is protected by a large plastic cover on the OS of the engine. The plastic cover is split into 4 sections to allow easy access, but on the 1.8 the top section is cut short and the two cam gears (the belt runs over them) are partially hidden under the rocker cover. The rocker cover is the big metal case that covers your engine and protects your valves and rockers from dirt – it has the oil plug in it through which you add engine oil if you are topping up your oil. If your engine is like this then you need to now remove the rocker cover. It’s easy and is held in by about 11 bolts – undo these in sequence a ½ a turn at a time until they are loose so you don’t warp the cover. Before you remove the cover pull off the two rocker cover feed pipes that go into it, and unbolt the pipe that is attached to it on the OS. Now take the cover off and putt it to one side. Remember to remove all the bolts from it so there is no chance of them falling into the spark plug holes – once it’s off put the spark plug leads back into the (now exposed) holes in the engine.
With the rocker cover off you can now see your cam/cams. If like mine you have a twin overhead cam (2 cams at the top of the engine), you’ll see two gears poking out on the OS of the engine with a belt over the top of it – this is your cam belt and cam gears.
Next you need to remove the water pump pulley. There are three blots on the pulley and they will be on tight so if you’re having problems getting them off while holding the pulley still to prevent it from turning, use the following technique: Get two ring spanners which fit the pulleys bolts. Put both on a bolt. Now you can use one spanner to give you the necessary leverage to hold the pulley still, while using the other to loosen a nut. Repeat this trick on all nuts until they are loose. The final nut is always a bit of a bugger as by the ‘holding’ spanner tightens one of the other loosened nuts when you attempt to undo it, but persevere!
OK, now it’s time to get on the ground! To get the cam covers off you need to remove the crank pulley. The crank pulley is attached to your crank shaft. Behind it, it has a gear over which your cam belt runs. The trouble is that the nut that holds your crank pulley on is very tight, and attached to a rotating object. If you try to loosen it you’ll just rotate the engine instead! You can get round this by jamming a screwdriver/tyre iron in the teeth of the flywheel (large geared wheel attached to the crank on the other side of the engine). Now when you try to loosen the bolt the screwdriver stops the flywheel from turning which prevents the engine from rotating – hey presto! You can get at the flywheel easily. The normal method for manual cars is to remove the starter motor (which turns the engine over by contacting with the teeth on the flywheel) – you can then get access to the flywheel teeth. Alternatively you may well find that your car is equipped with a flywheel access hole underneath the engine/gearbox and you can use this to jam the teeth. Either way approach this carefully – the flywheel is a big mother and you’re unlikely to do it damage, but you really don’t want to damage any of the teeth on it (so no hammering things in there)!
Now you’ve jammed the flywheel you can remove the crank pulley nut – use a breaker bar or torque wrench, it’s a big one! You should now be able to carefully tap/pull the pulley off. Note there’s a woodruff key (sticking up ridge) in the cranks end that the pulley slots on to – it can fall out and get lost so be careful!
With the pulley off you now have total access to the plastic cam belt covers. These are held on with about 8 bolts so undo them and remove the covers. They are a bit fiddley but they will come off – if you’re having problems check you really have removed all the bolts! Once off put them to one side and remember how to assemble them again.
Now you can relax, get a smoke, a beer and pat yourself on the back – you’re now looking at the cam belt!!!!
Finally you may find as I did that you have to remove one of the supports for the engine to get the cam belt off. I found that a engine support which attached it to the chassis was attached directly through the middle of the cam belt! If this is the case you need to get a jack under the engine and carefully raise it until it is supporting the engine at the correct height. Now you need to remove the engine support section which fits into a hole in the cam belt housing and onto the chassis at the other end. This is where the 18mm deep socket cam in! Once you’re removed it be careful not to loose the two dishes that are put on the bolts holding it to the chassis.
That’s it you now have all the bits off that you need to get at the water pump and cam belt. You may of course at this stage choose to perform a little victory dance – this is entirely optional, and if you fail to get the whole thing back together again, it could make you look really stupid.
Phase 2. Getting down to Business
So how does a cam belt work? Well, the idea is that your crank pushes the pistons in your engine up and down as it turns, and in order to let exhaust gasses out/petrol air in to the engine the valves have to open and shut at the right time. Your rocker gear and cams (inside the rocker cover) take care of this but they need to be told when to open and shut. This is done by running a belt (with teeth) over the crank and over the cams so joining them together – your ‘cam belt’ or ‘timing belt’. As the crank rotates it pulls the belt round, which in turn pulls the cam gears round, which turns the cam which then drives the rocker gear which opens the valves! This of course all needs to be done at the correct time so it is *very* important that the belt is placed in exactly the right teeth on each gear it connects with, otherwise your cams may be opening the valves as your petrol in your cylinders goes bang or they may be shutting them when your cylinders want to get rid of exhaust gas – not what you want!
The picture below if from my Spit (done at the same time) and shows a timing chain not a cam belt. This is the way it was done in the old days – with good old, unbreakable (yeah right!) metal chains. However, it gives you an idea of how it all works. The big gear is the one attached to my Spit’s single cam, the smaller geared wheel is the one attached to the crank. The white marks have been put on there (remember the tippex) so that I can be sure that the new chain will go on with the gears in exactly the same position as the old one. The same principle applies to cam belts, and this is how you’ll approach the Mazda cam belt.
Right, take a deep breath and let’s start the cam belt replacement. The first thing you need to do is rotate the engine to the correct position. This is achieved when the timing mark on the crank gear lines up with the mark on the engine block (12 O'Clock mark) and the marks on the cam gear(s) align with their marks on the engine block or cam clamps. The easiest way to rotate the engine is to refit the crank pulley and lightly bolt it on. Then use this bolt and a box spanner to turn the engine clockwise. You may need to rotate the crank wheel several times until *all* the marks line up simultaneously.
Now this information only applies to the 1.8, you’ll need to check what your indentifiers/marks are if you do not have a 1.8. The marks on the cam gear on the 1.8 are found on the spokes of the gear and under the rocker cover behind the gear on the cam clamps. The OSR gear has an ‘I’ on one it’s spokes – this needs to align with the ‘I’ on the cam clamp behind the gear. The OSF gear has an ‘E’ on one it’s spokes – this needs to align with the ‘E’ on the cam clamp behind the gear. The crank gear at the bottom of the engine has a notch on its back plate, this needs to align with the embossed arrow on the engine block behind it. You may need to rotate the crank several times until all the marks line up – even once you have them all aligned, don’t remove the belt yet!
You now need to mark up the belt, gear and block with your tippex so that you know the belts teeth will mate with the gear teeth on all three wheels in exactly the right position. If you’re really lucky you’ll find that some kind past mechanic may have blobbed paint on the gears already, if not mark all the gears in *two* places against suitable stationary bits of metal (eg. Engine block, back plate) so that if they move once you’ve taken the belt off, you’ll know and can move them back to *exactly* the right position – this is very, very important. Also just in case you can’t figure out the correct settings for the new belt, mark up the old belt in two places for each gear (mark the gears as well and which place applies to which gear) so that you can always put the belt back on in the same position with the same gear teeth mating to the same teeth on the belt. The easiest way to do this is to mark the belt on it’s side – this gear tooth to this tooth on the belt, kind of thing! Also you ned to mark the direction of rotation on the old belt (you should be able to work this out from your notes – remember you ran the engine at the beginning of this job to find out which way it rotaed). Finally, let me stress again – mark everything, do this for all gears (crank, cam, second cam if you have one) and don’t remove anything until you are absolutely sure, you have to be sure you can get everything back in *exactly* the same position!!!!
Right, on to the easiest bit – removing and replacing the cam belt. Undo the cam belt tensioner blot a little (this is the round pulley that runs against the belt about half way down at the OSR of the engine, it has a spring clipped onto it to pull it against the belt). Now you’ve undone it a bit you should be able to rotate the tensioner back and away from the belt. The belt should now be loose enough to prise off. Now you have the belt off if you are replacing the water pump or the tensioner and ideler then you need to undo the single bolts holding both the tensioner and ideler pulleys completely (the ideler pulley is the one that looks like the tensioner pulley but has no spring and is located at the OSF of the engine that contacts with the cam belt). Once you have the bolts out you should be able to pull off the ideler pulley and unclip the spring and pull of the tensioner pulley. Next, if you are replacing the water pump you need to undo the bolts which hold it onto the block and also remove the two blots which hold the adapter for the pipe that goes to the rad (this is just bolted onto the end of the water pump). Once the bolts are undone you should be able to tap the water pump off with a soft block. With the pump off clean the hole and the whole cam belt area, so everything is free from muck and grease. These don’t mix with either cam belts or water pump gaskets!
Step 3 – Refitting
If you removed the water pump, start with that. Reattach the fitment for the rad pipe and then get the new water pump gasket and put a thin layer of Universal Blue gasket seal on both sides, then fit it to the new pump. You’ll find theat the sealer holds the gasket to the pump in the correct position so that you can fit it. Now refit the pump. Tighten the nuts fully, then wait 5 mins then tighten again. Finally refit the rad pipe.
Now fit the new tensioner and idler pulleys. Then pull the idler pulley back against the spring to it’s fullest extent and lock it, so that when you fit the new cam belt it won’t be tensioning it.
Next it’s time to fit the new cam belt. First check that all your gears are still in the correct (tippexed) positions, if they are not, carefully rotate them a little until they are. Now cam belts are handed for rotation, you’ll find arrows on the new belt specifying which way it rotates – fit the belt so that it rotates in the direction of these arrows when the engine starts. Now starting at the crank pulley/gear end and working anti-clockwise slip the new belt on. You can hold it in place on each cam gear by clamping it lightly in place with the mole grips before moving on to the next pulley. Make sure the belt is tight between each pair of pulleys before moving on. Once you have fitted the belt it’s time to tension it. You will find a tensioning marker at the crank gear end of the block, it looks like the timing marker explained earlier but it 60 degrees anti-clockwise from it. You need to rotate the crank gear, belt etc. through 1 complete turn anticlockwise and then rotate it that extra 60 degrees until the timing notch in the crank gear lines up with this tensioning marker. When it’s there release the clamp on the tensioner pulley so that it clamps onto the belt, then do up the bolt on the pulley so that it is locked in place. Now you need to rotate the crank, belt etc anti-clockwise until it lines up again with the timing marker at the top of the crank gear and then rotate again an extra turn until it lines up again with the timing marker (basically 1 and 5/6 turns in total). Now check all the tippexed markers all line up again on all pulleys/gears simultaneously. If they do – congratulations, you’ve just fitted the cam belt!!! If the tippex marks are really well out, then you probably just have not rotated the crank gear, belt etc. fully so just turn it through another turn to check if that’s the case – if all the marks line up then you’re ok and just couldn’t count! However, if they don’t line up, loosen the tensioner, remove the belt, realign the tippex marks and repeat the whole process until they do.
That’s all there is to it! If you’ve got to here then just refit everything else in reverse order and you’ve done it. Remember to really tighten that crankshaft pulley nut and if you had to remove an engine mount then remember to replace it before removing the jack supporting the engine. Also if you did the water pump don’t forget to refill the rad. Oh and for the love of god remember to remove the scredriver you used to jam the flywheel - it's always impressive seeing a smug mechanic starting a car and watching his £1.50 screwdriver strip the teeth of a £150 flywheel! Congratulations – you just did a cam belt change and saved yourself a fortune!
maylander739
PostPosted: Mon May 08, 2006 12:46 pm
looks pretty detailed, i've only read some, but it looks pretty good
only thing is, some bits refer to pics that aren't shown?
:thumbright: well done mate
PostPosted: Mon May 08, 2006 12:47 pm
Had a really good read of that :D:D:D
VERY comprehensive, and funny too :D:D:D
Looks like i may be doin this soon :?
PostPosted: Mon May 08, 2006 1:21 pm
ClassicFan wrote:
There are loads of pictures but I haven’t had time yet to format them into the text. ...
.... I’ll add a proper guide with pictures when I get the time in the meantime this should give you a good idea, and if you have a Haynes manual you should be able to use this anyway. – Good luck! :cheers:
ClassicFan
maylander739
PostPosted: Mon May 08, 2006 1:42 pm
ClassicFan
silly me, like i said, i only read certain parts :D
Dragon Rob
PostPosted: Mon May 08, 2006 8:32 pm
Excellent guide, fancy doing my V6 for me and writing a guide for that one? :thumbright:
(Or maybe I'll get off my a**e and sort it out) :badgrin:
Full Circle:-
PostPosted: Mon May 08, 2006 11:40 pm
I might get there before you Rob .. think the waterpump on my green F has started leaking :( ... already done one on my old Silver one ...
Anyway wheres this guide for door replacement lol ;)
srr
PostPosted: Tue May 09, 2006 1:12 am
Is the procedure for the V6 totally different from the 1.8 ?
PostPosted: Tue May 09, 2006 9:32 am
Ta, mate - that's an excellent guide - looking forward to seeing it with the pictures !!
ClassicFan
PostPosted: Tue May 09, 2006 12:57 pm
Just to clarify this point:
The procedure will be the same for all engines, however, the details will be different.
The timing marks WILL be different and you must know these to do the replacement. For example for 1.8s its ‘I’ and ‘E’, but for 2.0 it might be ‘X’ and ‘Y’ and for 1.3s it might be ‘*’ and ‘*’.
Minor details may be different. For example on a 2.0 you might be able to replace the water pump without removing the timing belt. For 1.3s you might not have to remove the rocker cover to get at the cam belt.
Minor details are not a problem as they can be worked out, but you must know the timing marks for your engine.
If you know the timing marks and have a modicum of experience, you should be able to use this guide on your engine.
ClassicFan
PostPosted: Tue May 09, 2006 4:09 pm
No! :blackeye:
ClassicFan
PostPosted: Mon May 15, 2006 2:58 pm
The guide has now been formatted to include pictures and can be found here:
enjoy and allow time for download!!! :cheers:
RockRockMcRock
PostPosted: Tue May 16, 2006 5:05 pm
Nice one! Perfect - I can do the car now
:bigsmurf:
Broads
 Post subject: - MANY THANKS -
PostPosted: Mon Oct 02, 2006 2:29 pm
This was a really great help over the weekend and I managed to do the cambelt change and oil change and filter in 6 hours, including lunch and cake break. (and I'd never done this before)..
:cheers: :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
Whilst the guide was great there were a few things I would like to add my 2 pence worth on..
After searching around stores in 2 counties I finally found a 18mm Deep Socket. Only to find for my 1.8 16v Exec I didnt need it.. - Was that put in for a laff.. ? But hey if I had needed it would have been a real pain trying to find one with out a car... So anyone else attempting this better get one just incase,, seems the 18mm deep is an odd one to come by and I eventually found mine at a motor cycle dealers.
Lose is spelt LOSE not LOOSE ;) , at a couple of points in the guide I was unsure if I should remove the bolts.
But here is the real thing that could help many people..
When trying to remove the crank pulley, a much better way to give you the leverage and to stop the pulley rotating is to get a mate (if available) to stick the car in 5th gear and stomp on the breaks whilst you undo the bolt. This will effectivly lock the pulley from moving as you are in a really high gear and locking the breaks should stop the gearbox and anything attached to it from moving. Remember at this point there is no servo assistance, hence the stomp on the breaks.
Thanks again, your guide was invaluable.
PostPosted: Mon Oct 02, 2006 2:36 pm
Well, when Dan and i did my cambelt (1.5) the only way we could find to get the crank bolt undone, was to stick the socket on a breaker bar, and stick THAT inside a 5 foot scaffolding pole, then with the pole resting on the ground out in front of the car, give the ignition a quick turn, undoes it nicely :D:D
No amount of leaving in gear and brake stomping helped us :?
Broads
PostPosted: Mon Oct 02, 2006 2:39 pm
Sheesh,, that was tight..... seems I was lucky. by the way nice looking 323 you have there. (whats the plaster for?) was that where the scaffold bar came round and whacked the skirt? lol..
PostPosted: Mon Oct 02, 2006 2:46 pm
LMAO, no sir :D:D
That 's been there for like, 4 years now, its become a bit of a club totem as it goes :D:D:D
Happened one night on my way home at about 1.30 am from a friends, high winds a nd heavy rain, rounded a bend on a road i know really well, to be confronted by a very large branch across most of the road, i mananged to avoid MOST of it, but i did get clipped, the plaster was for a bit of a larf, but now its become a battle to see how long it lasts :D:D
And thanks for the compliment by the way :D:D:D
Has anyone actually welcomed you to the club yet????
If not, welcome to the club :D:D:D
Broads
PostPosted: Mon Oct 02, 2006 2:51 pm
Why thank you, do I get a sticker or badge or anything... LOL..
mmm better stop the banter on this thread as it should really be reserved for talk about cambelt changing etc... but your welcome is welcome, I'll be staying a while no doubt.
ClassicFan
 Post subject: Re: - MANY THANKS -
PostPosted: Fri Oct 27, 2006 3:06 pm
Been out of the country for a while so haven't been logging on!
Nice to know the guides been useful.
Quick comment on the need for an 18mm deep socket - I needed it to get at the nuts holding on my engine support as the bolts protruded too much and you can't get a spanner in there. Having said that, you might not have these protruding bolts on your model so you may not need a deep socket to get the nuts off. However, if you do need one and don't have it it could be a show stopper - I'd either:
1. Look and see if you have the long bolts and buy before the job if you do.
2. Buy one anyway if you're unsure as they are only a few quid.
3. resign yourself to slowly grinding down long bolts if you start and don't have a deep enough socket (done that before at the side of the A30)
Yep and my spelling is sh1t - one of the many gifts of dyslexia!! Can be amusing sometimes!
nokia
PostPosted: Sat May 23, 2009 8:10 pm
that is one great guide there mate.
A great read but i dont think i would have the balls to do something like this.
