It is currently Sun Sep 13, 2026 11:58 am
dbanna
 Post subject: Spark plug cap
PostPosted: Tue Aug 16, 2016 6:33 pm
i had cause to remove the no. 1 spark plug cap but it won't go back all the way in, any tips.
stuartspel
 Post subject: Re: Spark plug cap
PostPosted: Tue Aug 16, 2016 7:40 pm
Without an obvious, visual obstruction….. a firm press should be all it needs :thumbup:
MadazInBris
PostPosted: Tue Aug 16, 2016 9:53 pm
At the end of the lead is a "pressure grip" that stops the lead falling out,
that can score the cap internally leaving a ridge - Remove cap, debur & good as new :D
dbanna
PostPosted: Sat Aug 20, 2016 5:36 pm
hey thanks for the tips, it turns out that the inner parts of the lead wire at the end came out and in doing so i damaged the lead wire. had that replaced but then accidentally dislodged the connector wires... been running around buying new lead cables with no success once changed, however, had a scan done and it revealed the issue with the coil pack connector. Secured the wires and ... VOILA!!! all is well now. power restored and i can climb hills again. Thanks guys...
Users browsing this forum: No registered users and 24 guests
