diesel323 wrote:
Maybe worth checking the vacuum lines, located around the battery box area..
Cannot actually see ANY vacuum lines 'near battery box'. And if one was split why would it run perfectly once actually started?
Am 90% sure that air is getting into the pump after switching off.
Today :-
Changed fuel filter head (in case primer diaphragm had developed a pinhole).
Primed system, then opened bleed plug on banjo above the injection pump, pressed primer 2 or 3 times till neat fuel came from bleed plug then tightened it. So system pretty full.
Engine started normally with no need for Easy Start.Switched off for a few seconds, then restarted as per normal. Switched off.
THEN waited about 5 minutes. The crunch test ...
Would
not start at all - which makes me think air might be getting into pump ?
Done many searches on the net but there is some really dodgy advice out there!
One chap thought diesels had coils ...
Another thought 323 glowplug light flashing was ONLY to show faults in glowplug circuitry.
(It actually shows stored faults are in the ECU. Downloading them shows they can cover many aspects of the engine and not just glowplugs)
Autodata list all the possible codes to be found via DLC on PFL 323s.
[Confession. Yes I have downloaded error codes but they do not conform exactly to the format Autodata led me to expect !!]
I got :-
Long flash
Pause
Long flash No pause 4 short flashes
Pause
Long flash
Pause
Long flash No pause 3 short flashes
then about 5 or 6 seconds wait and the sequence starts flashing again.
Question for Denso-pumped diesel owners ... is there a seal or seals on the pump that would let air in ?
Car has done 160,000 so fair by diesel standards, no black or white smoke, no untoward rattles, new glow plugs and airfilter. Not leaking diesel into sump.
And just to emphasise, when started on Easy Start it immediately runs perfectly, no missing, no smoke.
