It is currently Thu Aug 27, 2026 5:23 am
Post new topic Reply to topic  [ 23 posts ]
MAZER
PostPosted: Sun Dec 05, 2010 2:28 pm
Just moved wifes car about 30 feet to clear other half of drive, and have noticed it is leaking droplets of oil.
Upon investigation the following where note
(1) Oil pressure light goes out straight away]
(2) Engine sounds bit tapperty but engine was still cold
(3) Coolant level in bottle has dropped slightly
(4) Checked oil level which is slightly over the full mark but will check again when engine is cold
(5) Oil seems to be leaking around filter then running down onto the ground pass what I presume is the sump
(6) Oil drips are quite fast.
I think it could be the following
(a) Oil filter is leaking
(b) Head gasket is going
(c) Sump is leaking
(d) Oil pressure switch
(e) Crack in engine block
Any other ideas, will arrange for someone to come out and look at car once the snow has gone.
Thanks.
Cyntax
PostPosted: Sun Dec 05, 2010 2:35 pm
I had this a while ago, and found that my sump had a rather large crack in it. Even though it looks to be leaking from the top end I'd still check!
If you jack the car up (use some stands, not just the sissor jack!), you should be able to see where its coming from. Check things like the sump plug, and see if there are any dimples in the sump (use an old rag to wipe away the crap - if it is leaking, oil will flow quite quickly).
I'd also chuck an oil catch pan underneith to a) stop the road / your driveway getting covered and b) to see how much is leaking out over a period of say 12 hours.
MAZER
PostPosted: Sun Dec 05, 2010 2:45 pm
Thanks, have put cardboad underneath but will put drip pan underneath to see how much drips out, how much did it cost to fix yours and what caused the sum to fail?
Cyntax
PostPosted: Sun Dec 05, 2010 2:54 pm
Ice was the main cause. The sump is quite low, and I must have hit it.
I bought one in from the states for around £65 inc tax & shipping.
Clicky
If you have the tools, I'd suggest doing this yourself. You will need to have the car jacked up a wee bit, as you need to take the front section of the exhaust off.
Just be weary of the bolts that connect the exhaust to the first cat. When mine went, I got a garrage to do it for me, and I nearly had to get a new cat, as the muppet sheared the bold head off! (I kindly suggested that he drill it out!)
MAZER
PostPosted: Sun Dec 05, 2010 3:31 pm
Can't think it was ice as car was left on drive in the snow and can;t think its been driven anywhere it could of hit something
How long did it take to carry out the repairs.
Cyntax
PostPosted: Sun Dec 05, 2010 4:14 pm
If you take your time, it shouldn't be much more than an hour.
TheMAN
PostPosted: Sun Dec 05, 2010 4:30 pm
if it just started all of the sudden, then it could be the sump
otherwise, it is pretty common for older mazdas to have a failed oil cooler gasket (no oil cooler if you don't have the diesel or sport) which is sandwiched by the oil filter
failed head gasket is unlikely... the coolant will be even lower and you may get bubbling in the reservoir, plus the engine may run like rubbish... coolant levels in the reservoir go low after some time due to temperature changes and evaporation
at this point all anyone can do is guess what is wrong... it is best to actually look for the leak
Protege FAQ, the best 323/Protege/Mazda3 resource enjoyed worldwide for 10 years
MAZER
PostPosted: Sun Dec 05, 2010 8:12 pm
Thanks for the info.
MAZER
PostPosted: Sun Dec 05, 2010 8:20 pm
The engine is 1.5 petrol so no oil cooler, only noticed it was dripping oil when we moved the car, and the oil was quite quick flowing
The level in the radiator is fine the level in the plastic bottle is low enough so I can't put my small antifreeze tester in but checked quality of anti freeze in radiator and it is fine, if I have time in morning I will check oil level then to see what level it is when cold.
As mentioned above in other posts the oil possibly could becoming from the filter then dropping to the ground just behind the sump along a metal rail
TheMAN
PostPosted: Sun Dec 05, 2010 9:48 pm
if you think that is where the oil is coming from, get a spray can of brake cleaner and rinse the engine block off around where the oil filter is.... that way any residual oil will be gone and you can know for certain whether it's the oil filter that's leaking or just whatever was there from an oil change :)
if it's the filter leaking for sure, replace it if it's already tight... don't even chance using it by tightening it more!
the sump on the 1.5 is aluminium I think, so you might also want to check for cracks/damage
MAZER
PostPosted: Sun Dec 05, 2010 11:04 pm
Thanks for tip re brake cleaner, would be replacing and not tightening up as cost of filter is not too much, other thought is the oil sump plug or washer has gone.
Car is off road for time being and may have a better look at weekend, by the way where are the jacking points and axle stand points on a 323
thanks.
Cyntax
PostPosted: Sun Dec 05, 2010 11:23 pm
Anywhere there isn't rust!
Matty
PostPosted: Mon Dec 06, 2010 12:28 pm
My God man, are you suggesting he uses the windows as a jacking point?!
:badgrin:
Prestige Car Valeting | Virtual Office | David Bell Jewellery | Fama Moon Chair
Cyntax
PostPosted: Mon Dec 06, 2010 1:51 pm
:badgrin:
Its a Mazda, they may be rusty too! :lol:
PostPosted: Mon Dec 06, 2010 8:09 pm
I usually put axle stands under the bolts for the rear inside lower arm bushing.
MAZER
PostPosted: Wed Dec 08, 2010 7:50 pm
Decided due to lack of time, cold weather etc to book car in, turns out the filter had rusted and was weeping oil, so having filter and service carried out.
Glad it was nothing serious and will tell wife to get car serviced more regularly.
Thanks.
PostPosted: Wed Dec 08, 2010 9:48 pm
I've heard everything now!!!
A bloody oil filter rusting??? Jeez, these babies really do enjoy a good rusting!!! :lol:
Glad you got it fixed buddy! :thumbleft:
TheMAN
PostPosted: Thu Dec 09, 2010 7:52 pm
How long has that filter been on there? I think it has to be on there for a while for it to rust!
PostPosted: Thu Dec 09, 2010 9:05 pm
Yep, A friend of mine had his filter on his car for 3ish years and it rusted :lol:
MAZER
PostPosted: Fri Dec 10, 2010 10:43 pm
Shamed to say it had been on for 2.5 years :oops: all now fixed and car serviced
TheMAN
PostPosted: Sat Dec 11, 2010 6:42 pm
I think you're supposed to change the oil every 6 months regardless of mileage...
PostPosted: Sat Dec 11, 2010 7:20 pm
Oil and filter every 9000 miles or 1 year, whichever comes first. :wink:
TheMAN
PostPosted: Sat Dec 11, 2010 10:20 pm
Close enough!
