It is currently Sun Sep 13, 2026 12:01 pm
Poultergeist
 Post subject: Drivers window sits out
PostPosted: Fri May 27, 2016 12:10 am
Ive looked through the guides to sort this but where can I get the rubber washer from? Or does anyone know the size of it so I can just get a universal one?
MadazInBris
PostPosted: Fri May 27, 2016 5:40 am
There's 4 used on the REAR of the glass rails that collapse.
They are $18.37 each here AUD
To replace that end bush:
Wind the window down.
Remove the two window stoppers held on with 10mm bolts.
Wind window up past the door frame, then tilt the window forward exposing the bush.
The bush is held on using a bolt through the middle and washer on the back of the window.
Using a Torx attachment and pliers undo the washer and the bush comes off.
Then just put it back together.
Try to align the stoppers in their original position, otherwise the window wont close properly.
If there isn't a bush, bolt or washer there, check the bottom of the door, they often fall out !
The vertical wire guide rail also has one that can be replaced with a 27mm shower/door
roller guide. Just haven't done that yet myself - How to guide to come shortly..
What's needed - 4 shower door rollers & a pair of 'slip joint' pliers as well as the correct rear roller bushes.
The rollers need to be with the attached post & come with a 10mm nylock nut, the pliers are available at a lot of $2 shops for $2 (lol) & the jaw end of the pliers need to be ground down both sides by about 50% so that you can firmly grab the post of the roller whilst tightening the 10mm nut.
Obviously you need to grind,cut off the existing post & punch it out thereby just leaving a hole in the frame where you then bolt on the shower screen roller
Photo guide in Japaningrish (lol)
Page 1: http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=bg&ie=UTF-8&u=http%3A%2F%2Fminkara.carview.co.jp%2Fen%2Fuserid%2F273614%2Fcar%2F402822%2F1917616%2Fnote.aspx
Page2: http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=bg&ie=UTF-8&u=http%3A%2F%2Fminkara.carview.co.jp%2Fen%2Fuserid%2F273614%2Fcar%2F402822%2F1917616%2Fnote.aspx
Poultergeist
PostPosted: Mon May 30, 2016 10:48 pm
$18.37 EACH?! Do I need all 4??
MadazInBris
PostPosted: Tue May 31, 2016 10:07 am
Just one for each window you want to fix ;)
