Club323F • View topic - FM Radio Not working but LM and AM OK
It is currently Thu Nov 19, 2026 3:42 pm
sparkfishes
PostPosted: Wed Jan 06, 2010 5:49 pm
I have recently bought a 323f 52 - 2002 GSi ( only 26 000 miles)
The day I bought it the radio was set on FM ( SAGA because he sets them to his impression of the buyers profile )and it worked I remember it was SAGA FM!
I had a play around with the controls and the steering stalk and the manual control worked OK
The next day the Radio seems to be stuck on LM and AM
FM does not come up on the screen.
If I press FM/1/11 nothing hapens If I press Am it moves back and forth between LM and Am
The radio works fine - except it will not play/ tune into FM
I do have a warrenty but the dealer "radio man is away on a months holiday and I really do miss Radio 4
Any suggestions please.
Just is case any one answers with words like head set - I have read some posts you see- what is the head set ?
errnee
PostPosted: Wed Jan 06, 2010 6:31 pm
a head unit is the stereo , I cant really answer your problem as its been awhile since Ive used the std factory unit. are you pressing it or holding fm in? a quick press should select Fm them 1 to ... your preset channels. Do you have the manual? If not I can scan mine :thumbright:
lewp91
PostPosted: Wed Jan 06, 2010 7:33 pm
sounds silly but disconnect the battery for a min then reconect it will then reset so long as you have the code!
then you have a factory reset rad which should be good????
or am i talking crappp?:)
Gaz6076
PostPosted: Wed Jan 06, 2010 8:13 pm
A reset sounds like a good idea to me. As said make sure you have the code first!
purkyuk
PostPosted: Wed Jan 06, 2010 9:25 pm
Follow the re-coding procedure in your manual which came with the car so you can set your own personal code, if you there's any problems follow 'Errnees' procedures as follows:
http://www.club323f.com/club323f/forum/ ... hp?t=36433
It does work!!! code for mine was 1414
Good luck!
2002 (52) 2.0L Sport.
sparkfishes
PostPosted: Thu Jan 07, 2010 11:47 am
[quote="errnee"]a head unit is the stereo , I cant really answer your problem as its been awhile since Ive used the std factory unit. are you pressing it or holding fm in? a quick press should select Fm them 1 to ... your preset channels. Do you have the manual? If not I can scan mine :thumbright:[/quote]
Yes! I have all the documents from the original sale ,thanks!
sparkfishes
PostPosted: Thu Jan 07, 2010 11:53 am
Thanks to those that answerd:
1)Yes I have all the original document - but there is not a radio code. I phoned the original dealer and they said they go out un coded and the owner codes them -if it had not been done then it was still as per the factory setting
2) I have now disconnected the battery ( neg) for a few seconds and reconnecting it but it has not cured the problem - surprisingly it did not come up with error or code in the display either
Shold I disconnect for a few minutes perhaps?
If it does need a code will the previous post on how to reset it work - the people who posted seemed to have had some sucess ............ I miss Radio 4, and I hate cricket (LM)
sparkfishes
PostPosted: Thu Jan 07, 2010 12:06 pm
I have disconnected the Pos for a minute and reconnected - still the same : no FM and err nor CODE came up in the display
I might try the Ernee recode procedure thatis on the sticky note - unless some one has had this problem and knows the cure
Gaz6076
PostPosted: Thu Jan 07, 2010 12:57 pm
See if there's a reset button on the radio itself. Like those ones you have to stab with a pen. My aftermarket headunit has one so you never know.
purkyuk
PostPosted: Mon Jan 11, 2010 1:50 pm
What happens when you press the MODE button on the steering controller? it should flick between AM, LM, FM, CD
Also if you have disconnected the battery and there's no code then the antitheft is disarmed, probably selected by a previous owner
