It is currently Sat Sep 12, 2026 2:51 pm
PostPosted: Thu Dec 13, 2007 8:32 pm
If you change the battery in the remote central locking fob, you'll need this procedure to re-code the fob.
You can also use this for coding spare or new fobs.
1. All doors closed, but unlocked.
2. Open drivers door, leave it open.
3. Put key in ignition, and turn it between ON and LOCK 3 times.
4. Remove key from ignition.
5. Press the drivers door switch 3 times (the switch that operates the courtesy light).
6. The doors should lock and unlock.
7. Press any button on the remote twice.
8. The doors should lock then unlock again.
Thats it. :D
johnno243
PostPosted: Wed Jul 22, 2009 9:07 pm
i'll say something, i have never been as surprised to hear that locks operating after the 3 presses of the door switch....very impressive!! cheers guys
MAZER
PostPosted: Sun Jul 26, 2009 2:40 pm
Very good instructions, we now have two remotes that work with our car. :D :D
tbevins
 Post subject: remote key fobs
PostPosted: Tue Sep 29, 2009 10:12 pm
hi , does anyone know the best place to get a new or secondhand remote key fob ? cheers , tony.
PostPosted: Tue Sep 29, 2009 10:16 pm
Ebay.
The two button ones are quite rare, so therefore a bit more expensive. The three button jobs do not work.
Be prepared to spend maybe £30 to £40. :wink:
tbevins
PostPosted: Thu Oct 01, 2009 8:51 pm
cheers , i'll keep a look out on ebay . :D
PostPosted: Sat Jan 23, 2010 1:42 pm
dustmonkey wrote:
(correct fob product code is on page 3-12 of the owners' manual)
This information is if your car didnt come with an alarm fob and needed to buy from ebay.
The Mighty BeeJay
xchaotic
PostPosted: Mon Sep 06, 2010 10:23 pm
hi, am I right in thinking that if I code a 2nd fob from ebay, the 1st is still going to work?
PostPosted: Mon Sep 06, 2010 10:44 pm
Yes, it should, but its always worth doing both at the same time, just in case. :wink:
waj
PostPosted: Sat Aug 13, 2011 4:03 pm
excuse for me being dumb! but which button/switch operates the courtesy light?
i have bought a visteon 41601 and need to program it for my 03 mazda gsi, will this procedure make it work?
PostPosted: Sat Aug 13, 2011 4:08 pm
Yes,, thats the one you need, and the courtesy light switch is on the door latch pillar (B pillar), its a black pin switch.
waj
PostPosted: Sat Aug 13, 2011 4:28 pm
ok i still dont know which switch it is lol and in the process i have just buggered something up as the car door is open and the locks are up and its not locking or letting me shut the door! please help i try and shut it with the key aswell as manually and it just keeps popping back up :(
waj
PostPosted: Sat Aug 13, 2011 4:54 pm
at the moment i cant shut my door as the latch seems to be closed, ive tried to force it up i need to drive my car and i cant with the door opn please help!
PostPosted: Sat Aug 13, 2011 5:32 pm
If your door keeps unlocking it sounds like you have a door that isnt shut correctly, try your boot . The curtasy light switch is your door pin. Open your door look at the bottom of the door piller, the black thing sticking out is the door pin which operates the light ;)
The Mighty BeeJay
Rob H
PostPosted: Sat Jun 16, 2012 11:11 am
I thought something was broken tried the above guide just in case. I was well impressed fixed again many thanks :D :D :D
