Club323F • View topic - sticking front caliper
It is currently Sun Nov 01, 2026 12:39 am
Twade76
 Post subject: sticking front caliper
PostPosted: Thu Mar 03, 2016 10:47 am
My front right caliper is sticking in a bad way, is it better to refurb it or replace?
Don't have much experience with messing around with the braking system so a replacement would seem like a more straight forward option, also looking at the service history it looks like they were refurbished a couple of years back so it seems like the caliper itself is a bit dodgy!
Zippy
PostPosted: Thu Mar 03, 2016 2:39 pm
Pretty normal on these cars, well just sliding caliper brakes in general. I refurbed mine, and first time round I nipped the dust seal, so after a couple of years it stuck again. Next time round, they're still working.
Refurb ain't much more difficult than swapping, there's a guide on here somewhere. I would almost advise a refurb yourself and taking your time to make sure it's done right.
This and rust are about the only real bad points on these cars... ;)
Twade76
PostPosted: Thu Mar 03, 2016 6:29 pm
Cheers.
Refurb kits on ebay are around a tenner so I figure its probably worth a try. I'll have a look for the guide.
Zippy
PostPosted: Fri Mar 04, 2016 10:15 am
Here's the guide: viewtopic.php?f=35&t=37797
Couple of things I'll add now having had a bit of experience with it all.
-Check your sliders are working nicely. New fitting kit on the brake pads will help a lot (well so will new discs and pads, and flexi lines etc, but stuff being clean to work helps the most).
-If you have access to an air compressor, that's an easier and less potentially damaging way of getting the piston out.
-I found seating the dust seal inside the caliper first, then putting the piston into the dust seal and then pushing the piston into the caliper a better way round of installing the seal than the way suggested in the guide - you can be a bit more sure that everything is sitting where it should be.
- Push the piston in completely square - obvs...but easy to start going on the wonk and that's bad.
Good luck :)
