Serviced the front calipers on the Sport today, thought I'd take a few pics, and write up a guide - it really is an easy job, nowhere near as scary as it seems
I bought the service parts from
http://www.brakesint.co.uk/ - each side is £16 for the seals and silicon grease, and £15 for the piston - I bought new ones, as I wasn't sure what condition the old ones would be in.
Firstly, loosen the wheel nuts, jack up that corner, remove the wheel, and stick an axle stand under there
Pop the bonnet, and loosen the brake fluid reservoir cap.
Pull off the plastic cap on the lower fixing - then use an 8mm hex key to remove the bolt - best thing to do is loosen it, but leave it in place while you undo the other fixings
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101771.jpg[/img]
Then remove the retainer clip
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101768.jpg[/img]
and push the flexi hose through the bracket
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101769.jpg[/img]
Use a hose clamp, nice and tight, this will stop you losing too much fluid
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101770.jpg[/img]
Use a 12mm to remove the banjo bolt, and pull the fitting from the back of the caliper - be careful with the copper washers - although it's best to replace them if you can
Catch the brake fluid in a pot - don't want it going everywhere
Then fully remove the bottom fixing - you might need to pull it out while turning as it'll probably be a bit stiff - and pull the caliper forwards to loosen its grip on the pads - if it's seized badly, a gentle tap with a hammer works a treat
You can then pivot the caliper upwards
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101773.jpg[/img]
and slide it backwards, off the top slider
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101774.jpg[/img]
not much left
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101765.jpg[/img]
Now it's off the car, take it to the workbench
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101775.jpg[/img]
wire brush some of the loose stuff off if necessary - I'm fitting new discs next weekend, so the calipers will get a clean and paint then
To remove the old piston - use a punch (or in my case, the handle of some strange tool, couldn't find my punch anywhere
) through the hole where the banjo bolt goes, and hammer it out.
You can force the piston out with the brake pedal while it's still on the car, but you lose more fluid that way.
If you're not replacing the piston, it might be worth considering a more gentle approach, but the hammer method works a treat, and doesn't do any real harm
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101761.jpg[/img]
Here's my slightly rusty piston - although I had already cleaned it up a bit last week when I first investigated the sticky brakes
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101762.jpg[/img]
and here is the reason for the problem, a split seal
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101759.jpg[/img]
Use a screwdriver to carefully prise out the inner seal
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101776.jpg[/img]
You can see from that pic, that there is no rust on the inside part - it is the part between the two seals, and in the recesses where the rust causes a problem - any corrosion "under" the seal lifts it towards the piston, and causes friction.
Clean out the recess with a screwdriver, and 400 grade wet'n'dry...or whatever you fancy, that's what I had, and it worked ok. Keep cleaning it with brake cleaner, and wipe it all with a cloth once you're done.
Fit both the seals, and make sure they fit nice, then remove the outer...
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101763.jpg[/img]
smear the inner seal with silicon grease, and the inside of the outer seal, and the piston. gets a bit slippery now
slide the outer seal over the front of the piston
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101778.jpg[/img]
and take it all the way down and over, so the part that fits into the caliper is not over the piston
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101779.jpg[/img]
carefully position the seal into the recess, and gently push the piston in a little way
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101766.jpg[/img]
then use a g clamp - and some wood, and wind the piston all the way in - the seal will find it's way into the recess on the piston...nearly done now
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101767.jpg[/img]
Replace the other small rubber gaitors, and smear the insides with silicon grease
Clean up the lower fixing slider bolt - this is the first bit to stick, so it needs to be clean, smooth, and greased
I use a power drill with a flap wheel, secured in the workbench, and clean it with that - takes no time or effort, then smear it with silicon grease and it's ready to go!
[img]http://i168.photobucket.com/albums/u177/marcrs323/brake%20refurb/130220101780.jpg[/img]
It's a good idea to clean and paint it while it's off the car if you fancy - and also clean up the area around the bleed nipple, wire brush etc, makes the bleeding process easier
Then it's back to the car - remove the m clips and the pads, and clean and grease (copper this time) the clips that secure the pads to the calipers, and the backs of the pads before fitting it all back together.
Slide the caliper on the top slider, pivot it down over the pads, and fit and secure the lower slider, don't forget to replace the cap!
Re-fit the brake hose, using new copper washers - 1 on each side of the pipe fitting, and tighten fully.
Pull the hose into the bracket, and re-fit the retaining clip - gentle tap with a hammer
Then remove the hose clamp.
Use a bleeding kit, and bleed thoroughly. You know the sort of thing...Press on the pedal, loosen the bleed nipple, tighten it, let the pedal come up...and repeat - until no more bubbles come out...keep an eye on the fluid level - remember some was lost when taking off the caliper
Make sure the fixings are tight, and clean and dry the area, then pump the brake a few times and make sure there are no leaks.
Then it's axle stand out, wheel on, lower the jack, tighten the wheel nuts, check the brake fluid level, replace the cap, close the bonnet, enjoy your new brakes
Took me about an hour each side in total - well worth the money saved
