Recently, there was a discussion on the Miata board regarding their BP valve cover's baffles and modifying them to help reduce oil consumption. Linked from that thread was this how-to:
http://mx5unleashed.com/tech/valve-cover.htmlI followed its ideas but modified it to suit my needs.
Yesterday I went ahead and did the valve cover mod... it was a b*tch because of the cleanup involved, the modification part was easy... cleanup sucks!!!
Buying the materials involved wasn't exactly easy. No store here carried washing machine discharge hose lint traps, of any kind. I special ordered the aluminum ones from Ace Hardware for less than 4 bucks with tax. Took about a week to get them. Then I bought a pack of Scotchbrite stainless steel pot scrubbers from Home Depot for just a little over 2 bucks.
So first I took the valve cover off and laid it on a clean smooth surface to keep the top side from getting messed up. I took off my JDM Mazdaspeed oil cap also to prevent damage also.
I removed ONLY the large baffle cover carefully. The RTV silicone sealant sticks to the steel cover like glue and in order to keep it from bending, I pried it off slowly with a small pry bar alone the entire length. Pulling on the cover as I pried on it.
Now came the hard part.... clean up! I scraped off the old black RTV sealant with a razor blade then cleaned the rest up with a rag soaked with brake cleaner. The pieces of sealant clings to the cover really well and it was very hard to get 99.9% of them out! In the process, I also made sure I cleaned out the sludge in the area right around where the PCV valve goes. Despite using synthetic oil, a slight build up was still there. Not entirely surprised.
After more than an hour cleaning up the valve cover and being higher than heaven on the brake cleaner fumes, I finally stuffed the valve cover's baffles with the "oil separators":
For the PCV side, I massaged and stretched one of the Scotchbrite pot scrubbers to a long sausage shape, then I carefully placed it inside the lint trap sack. It wasn't easy because the lint trap tends to collapse on itself. I also didn't want to put too much force because the lint trap is aluminum and the thin wires can break easily. Hindsight, it probably would have been easier to first roll a piece of paper around the pot scrubber and slide it into the lint trap and then pull the paper out in order to avoid snagging. Anyway, the idea of using the lint trap sack is to help keep the pot scrubber from coming apart and help trap oils better. Then I tied up the sack's opening with a piece of aluminum safety wire. Both ends of the sack are folded towards the center as shown in the pic. I also inspected the lint trap sack carefully of any broken wires and removed any loose pieces found. This was very important because I don't want any of them going into the engine!!!
For the breather side, I just simply stretched and stuffed one Scotchbrite pot scrubber into the baffle. No lint trap needed and no space for it anyway.
Finally, I drilled a 1/16" (1.5mm) hole in the breather side of the baffle cover. Right at where the 2nd air passageway is. This is to allow oil to drain back into the head while the small hole doesn't cause any major air flow disruptions in the PCV air exchange system.
Unlike the MX-5 Unleashed how-to, I did NOT cut any notches in the valve cover itself because of the differences in the FS's valve cover design. A notch will cause oil to pool over to the outer baffle and cause oil to easily get blown out the breather hose under boost.
Then I closed it back up using liberal amounts of black RTV silicone sealant. Sealing all divider walls just like it was originally, again, unlike the MX-5 Unleashed how-to. New valve cover gasket and Mazda branded Dow Corning SH780M gray RTV silicone sealant used on the valve cover gasket humps over the cam caps of course.
I put about 15 miles on the car so far, with lots of boosting and engine braking. The PCV valve remains dry so far! It will take me many months to see if this really works because I don't drive my car often, but I'm confident it will cut down oil consumption a lot. I was only burning half a quart every 3000 miles, so it wasn't not too bad, just annoying.
