Club323F • View topic - Front Door Speaker Replacement
It is currently Sun Nov 01, 2026 1:54 am
Terland
PostPosted: Thu Nov 19, 2009 1:44 am
Hey guys just some advice on this would be great
how easy are the doors to take apart?
what size speakers are in the doors?
anyone recommend some front speakers?
Thanks in advance
Ter
PostPosted: Thu Nov 19, 2009 8:48 am
Door panels are easy enough - there is a guide on here somewhere I'm sure?
Lift the window switch panels at the backs, and then slide backwards to release them
Screws in the handles, (and behind the handles once you've removed them) and in the door release handle
Look for small popper type clips as well, then prise panel off (popper clips behind into door) and lift over the locking button
Speakers are 5" x 7" in the front doors, I have JBLs in mine, not bad for the money, if you get really stuck I have some standard ones that are still in very good condition.
hope this helps, good luck!
Terland
PostPosted: Fri Nov 20, 2009 2:16 pm
Thanks marc so 5x7 are we talking 13cm and do u cut the grates and pop the speaker shroud over or jus leave it with the grates on
PostPosted: Fri Nov 20, 2009 2:43 pm
I didn't cut the doors at all, plenty of room :)
he11boy07
PostPosted: Tue May 10, 2011 7:33 pm
what are good replacement speakers for the rear ?
i was thinking of getting a set of jvc 5x7's for the front but not sure what will go in the back ?
easy assembly once you take the door card off once its really easy to do again if needed
i will do a little demo in the next few week's when i ahve to take ine off again to replace mine
as i have blow the right hand side front and back speaker and also my lefthandside eletric window motor has just died :(
