The spark plugs started working again ... 3 mechanics already denied to work on the car, I finally found someone willing to do it.
https://youtu.be/4Rje8VFvVYcThese are the simptoms. I can get it to accelerate and max revs if I slowly accelerate and don't force the pedal down.
As soon as I step on it it chokes like the engine misfires or something slips and the revs won't go up, the stay there. So basically if I'm in second and I step on it, it just stays at 2k and a misfire sound can be heard.
Slow acceleration works fine but it does randomly misfire sometimes putting pressure on the transmission and drive shafts especially when it comes back to normal.
Idle is normal.
Help ?
Sensor ? I remember removing the spark leads from the distributor, though maybe I shorted the lambda or something.
ECU doesn't read up any codes I did the led TEN GND test. No error codes.
Then I disassembled the distributor cap and found out that the plastic piece under the rotor arm is fissured and metal can be seen. Still, it should cause constant mess not only when stepping on it ? I've checked vacuum with a little smoke nothing seems to come out ... maybe a hole into the air plastic intake where the air filter is ... but I checked , I can t see any.
